Home » Archived » B3 » Initial documentation of b3 aggregator and b3 command line interface
Initial documentation of b3 aggregator and b3 command line interface [message #530247] Thu, 29 April 2010 05:21 Go to next message
Filip Hrbek is currently offline Filip HrbekFriend
here is an initial documentation of
b3 aggregator: http://wiki.eclipse.org/Eclipse_b3/aggregator/manual
and
b3 command line interface: http://wiki.eclipse.org/Eclipse_b3/cli
More work needs to be done but perhaps something is better than nothing ;-)
Filip
Re: Initial documentation of b3 aggregator and b3 command line interface [message #530741 is a reply to message #530247] Fri, 30 April 2010 16:31 Go to previous message
Henrik Lindberg is currently offline Henrik LindbergFriend
Hi have reviewd and edited the aggregator manual wiki page. There are
some questions at the end - can you elaborate a bit on those? (then we
are done I think).
- henrik
7.1 Questions
How is blame-mail handled when running in the UI? Are the options
"production" etc. available then?
How do you know what the "log output url" is? How can it be set?
Why is there a section that says "there is no hudson support" - is
hudson support needed/required in any way??
Some configurations seems to be missing - or is the list open ended?
(Sparc, Motif, etc..) - I assume user can put anything there?
It seems that it is possible to load maven repositories. I suppose the
result of aggregation is a valid p2 repository (or a combination of
p2/maven)??
On 4/29/10 7:21 AM, Filip Hrbek wrote:
> and
> Filip
Re: Initial documentation of b3 aggregator and b3 command line interface [message #606370 is a reply to message #530247] Fri, 30 April 2010 16:31 Go to previous message
are done I think).
- henrik
7.1 Questions
p2/maven)??
> and
> Filip
Previous Topic:Initial documentation of b3 aggregator and b3 command line interface
Next Topic:b3 update site built for 3.6M7
Current Time: Sat Sep 30 04:22:23 GMT 2023
Powered by FUDForum. Page generated in 0.02172 seconds
