Home » Language IDEs » PHP Development Tools (PDT) » Install of PDT fails(Operation cannot be completed)
Install of PDT fails [message #530231] Thu, 29 April 2010 00:25 Go to next message
No real name is currently offline No real nameFriend
I followed the instructions on available on the wiki.eclipse.org and receive the following message:
Cannot complete the install because one or more required items could not be found.
Software being installed: PHP Development Tools (PDT) Runtime Feature 2.2.0.v201004270700-7L7J-F8NcJTJJwdOKOJJ (org.eclipse.php.feature.group 2.2.0.v201004270700-7L7J-F8NcJTJJwdOKOJJ)
Missing requirement: PDT Server UI Plug-in 2.2.0.v201004270700 (org.eclipse.php.server.ui 2.2.0.v201004270700) requires 'bundle org.eclipse.wst.sse.ui 0.0.0' but it could not be found
Cannot satisfy dependency:
From: PHP Development Tools (PDT) Runtime Feature 2.2.0.v201004270700-7L7J-F8NcJTJJwdOKOJJ (org.eclipse.php.feature.group 2.2.0.v201004270700-7L7J-F8NcJTJJwdOKOJJ)
To: org.eclipse.php.server.ui [2.2.0.v201004270700]
I tried to find a solution on forums, but I didn't find.
Re: Install of PDT fails [message #530358 is a reply to message #530231] Thu, 29 April 2010 13:54 Go to previous messageGo to next message
Jason Huselton is currently offline Jason HuseltonFriend
Am I right in thinking you are trying to install PDT on an existing Eclipse installation?
If you don't use Eclipse for anything else, just delete your current Eclipse installation and download the Eclipse PDT project http://www.eclipse.org/pdt/downloads/
Re: Install of PDT fails [message #530368 is a reply to message #530358] Thu, 29 April 2010 14:06 Go to previous messageGo to next message
OK, I'll do that. But, if I intend to use another plugin, it's only to proceed installing the plugin...
Re: Install of PDT fails [message #1029253 is a reply to message #530231] Fri, 29 March 2013 11:38 Go to previous message
Mircea LUTIC is currently offline Mircea LUTICFriend
I needed to install pdt on top of indigo and the following worked for me:
http://download.eclipse.org/releases/indigo/
Previous Topic:Eclipse PDT in J2ee all in one
Next Topic:Run web app on default browser doesn't work
Current Time: Fri Jun 18 09:50:30 GMT 2021
Powered by FUDForum. Page generated in 0.02147 seconds
