Home » Eclipse Projects » DTP » Accessing query plan
Accessing query plan [message #529864] Tue, 27 April 2010 14:05 Go to next message
John Doyle is currently offline John DoyleFriend
I'm working on a Connectivity implementation and want to expose the query plan from my system. The only example for this I can find in DTP is the IngresExplainSQLActionDelegate that says this in its comments:
* Basically a copy of
* org.eclipse.datatools.sqltools.sqleditor.plan.ExplainSQLActi onDelegate with
* extension to be used as additional action in the SQLEditorService. XXX This class
* is for provisional usage only. It's obsolete when a menu entry for QEP generation is available.
I don't see that such a menu is there yet. Is that correct and we're left to our own devices for now as how we expose the plan?
thanks
~jd
Re: Accessing query plan [message #529979 is a reply to message #529864] Tue, 27 April 2010 21:33 Go to previous messageGo to next message
Brian Payton is currently offline Brian PaytonFriend
There is currently no plan to enhance the Query Execution Plan code in
DTP. The committers who are familiar with that part of the code are no
longer active. I'm afraid you are on your own here.
> onDelegate with
> This class
> thanks
> ~jd
Re: Accessing query plan [message #530390 is a reply to message #529979] Thu, 29 April 2010 14:43 Go to previous message
Thanks Brian
Re: Accessing query plan [message #597453 is a reply to message #529979] Thu, 29 April 2010 14:43 Go to previous message
Thanks Brian
Previous Topic:Accessing query plan
Next Topic:Problems executing a script with multiple insert
Current Time: Sun Sep 19 18:07:53 GMT 2021
Powered by FUDForum. Page generated in 0.01923 seconds
