Tomcat-6.0.26 initiation fails via Eclipse-jee-galileo-SR2-win32 [message #529713] |
Mon, 26 April 2010 21:37 |
Oğuz Çavlı Messages: 4 Registered: April 2010 |
I am not able to initiate Tomcat via Eclipse.
I am on
* Windows 7 64 bit
* Apache-tomcat-6.0.26
* jdk1.6.0_20
* Eclipse-jee-galileo-SR2-win32
I am able to launch Tomcat via C:\apache-tomcat-6.0.26\bin\start batch file. I can see the default Tomcat welcome page.
When I New --> Server --> Tomcat v6.0 Server via Eclipse, "Tomcat v6.0 Server at localhost [Stopped]" line appears at the server tab.
I right click and start the server, it does not prompt any errors but Tomcat is not running -console output is as follows, Tomcat welcome page throws" HTTP Status 404 - / The requested resource (/) is not available." error.
Apr 27, 2010 12:21:11 AM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files (x86)\Java\jre6\bin;.;C:\Windows\Sun\Java\bin;C:\Windows\sys tem32;C:\Windows;C:/Program Files (x86)/Java/jre6/bin/client;C:/Program Files (x86)/Java/jre6/bin;C:\Windows\system32;C:\Windows;C:\Window s\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\
Apr 27, 2010 12:21:12 AM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Apr 27, 2010 12:21:12 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 411 ms
Apr 27, 2010 12:21:12 AM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Apr 27, 2010 12:21:12 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.26
Apr 27, 2010 12:21:12 AM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Apr 27, 2010 12:21:12 AM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Apr 27, 2010 12:21:12 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/20 config=null
Apr 27, 2010 12:21:12 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 266 ms
When analyse my Tomcat arguments, I have the following line.
Arguments --> VM Arguments
-Dcatalina.base=" C:\workspace\jee\.metadata\.plugins\org.eclipse.wst.server.c ore\tmp0 " -Dcatalina.home="C:\apache-tomcat-6.0.26" -Dwtp.deploy=" C:\workspace\jee\.metadata\.plugins\org.eclipse.wst.server.c ore\tmp0\wtpwebapps " -Djava.endorsed.dirs="C:\apache-tomcat-6.0.26\endorsed"
Could not find anything under
* <workspace>/.metadata/.log
* <eclipse install>/configuration/<sometimestamp>.log
* <eclipse install>/configuration/org.eclipse.update/install.log --this one exist
I believe I am missing a very simple point but I couldn't detect it yet.
Oğuz
[Updated on: Mon, 26 April 2010 21:44] Report message to a moderator
FUDForum. Page generated in 0.03013 seconds
