Re: How do I create a Connection Profile [message #53510 is a reply to message #53482] |
Fri, 13 March 2009 14:41 |
Originally posted by: brianf.sybase.com
Hey Mark...
You're definitely along the right path.
When you talk about using the API... What are you including for dependencies
in the plug-in that's calling the API?
And what's the NPE that you're getting? That'll help me better diagnose
what's going on.
--Fitz
"Mark Leone" <midnightjava@verizon.net> wrote in message
news:20f0543b701bb5f2663988d6c0943224$1@www.eclipse.org...
> I've gotten further along on this, but I'm still stuck.
> I loaded into my target environment the DTP plug-in which provides a MySQL
> connectionProfile
> (org.eclipse.datatools.enablement.mysql_1.0.2.v200810160130. jar), and all
> it's dependencies. I see that in the plug-in's Plugin.XML it defines a
> connection profile with cateory =
> "org.eclipse.datatools.connectivity.db.category" and name = "MySQL".
> But when I query the profile manager for the profile by name or by
> category, an NPE is thrown. Below is the code I'm executing.
> ProfileManager pfm = ProfileManager.getInstance();
> if (pfm == null){
> System.err.println("No ProfileManager");
> else{
> IConnectionProfile profileByName =
> pfm.getProfileByName("MySQL"); // NPE thrown here
> System.out.println("Profile (by name) name: " + profileByName.getName());
> System.out.println("Profile (by name) ID: " +
> profileByName.getInstanceID());
> alternatively, if I execute the following code to get the profiles by
> category I also see an NPE thrown
> IConnectionProfile[] profiles = pfm.getProfilesByCategory(
> "org.eclipse.datatools.connectivity.db.category");// NPE thrown here
> for(IConnectionProfile catProfile : profiles){
> System.out.println("Profile (by Cat) name: " + catProfile.getName());
> System.out.println("Profile (by Cat) ID: " + catProfile.getInstanceID());
Re: How do I create a Connection Profile [message #53778 is a reply to message #53510] |
Fri, 13 March 2009 17:48 |
Mark Leone Messages: 123 Registered: July 2009 |
Fitz,
Thanks for your response. I'm pursuing a different implementation vector
based on some guidance I just received from my tech lead. He wants me to
define the connection profile manually rather than try to retrieve one
declared in Plugin.XML. I have some code that does that, which I'll paste
below.
I'm able to verify that the properties are set properly on the connection
profile, but when I try to create a connection on the profile, I get an
NPE thrown in
org.eclipse.datatools.connectivity.internal.ConnectionProfil e. I looked at
the source code where the NPE is thrown, and it seems to be that I don't
have a connection factory set on it. I wasn't sure what value to pass for
the connection factory parameter, so that's probably where my problem is.
My code is below. I'm also registering a driver when the workbench starts
up. The code that does that is below.
DriverManager mgr = DriverManager.getInstance()
mgr.createNewDriverInstance( "org.eclipse.datatools.enablement.mysql.5_1.driverTemplate",
"MySQL JDBC (Bundled)", jarFileURL.getPath());
Here's the code where I try to create the profile and connect through it.
String driverID =
"org.eclipse.datatools.enablement.mysql.5_1.driverTemplate";
String userName = userName;
String password = password;
Properties props = new Properties();
props.setProperty(ConnectionProfileConstants.PROP_DRIVER_DEF INITION_ID,
driverID);
props.setProperty(ConnectionProfileConstants.PROP_PWD, password);
props.setProperty(ConnectionProfileConstants.PROP_UID, userName);
try {
pfm.createProfile("MySQL", "MySQL JDBC Profile",
"org.eclipse.datatools.enablement.mysql.5_1.driverTemplate", props);
} catch (ConnectionProfileException e1) {
e1.printStackTrace();
IConnectionProfile profile = pfm.getProfileByName("MySQL");
if (profile.arePropertiesComplete()){
System.err.println("Properties are complete");
} else {
System.err.println("Properties are NOT complete");
if(profile.getConnectionState() != IConnectionProfile.CONNECTED_STATE){
profile.connect();
connection = profile.createConnection("java.sql.Connection");
//NPE thrown for statement above. See stack trace below
rawConn = (Connection)connection.getRawConnection();
Stack Trace:
Note: I simplified the code above, since I actually call a separate class
(SomeDatabase) where createConnection() is invoked. SomeDatabase.java line
25 in the stack trace corresponds to the line above where I indicated the
NPE was thrown.
at
org.eclipse.datatools.connectivity.internal.ConnectionProfil e.createConnection(ConnectionProfile.java:355)
at prophettest.SomeDatabase.connect(SomeDatabase.java:25)
at prophettest.ConnectionTest.test(ConnectionTest.java:71)
at
at
at
org.junit.internal.runners.TestMethodRunner.executeMethodBod y(TestMethodRunner.java:99)
at
org.junit.internal.runners.TestMethodRunner.runUnprotected(T estMethodRunner.java:81)
at
org.junit.internal.runners.BeforeAndAfterRunner.runProtected (BeforeAndAfterRunner.java:34)
at
org.junit.internal.runners.TestMethodRunner.runMethod(TestMe thodRunner.java:75)
at
org.junit.internal.runners.TestMethodRunner.run(TestMethodRu nner.java:45)
at
org.junit.internal.runners.TestClassMethodsRunner.invokeTest Method(TestClassMethodsRunner.java:66)
at
org.junit.internal.runners.TestClassMethodsRunner.run(TestCl assMethodsRunner.java:35)
at
org.junit.internal.runners.TestClassRunner$1.runUnprotected( TestClassRunner.java:42)
at
at org.junit.internal.runners.TestClassRunner.run(TestClassRunn er.java:52)
at
org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:45)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:62)
at
org.eclipse.pde.internal.junit.runtime.UITestApplication$1.r un(UITestApplication.java:114)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at com.tasc.swb.internal.application.SWBApplication.start(Unkno wn Source)
at
org.eclipse.pde.internal.junit.runtime.UITestApplication.sta rt(UITestApplication.java:46)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Re: How do I create a Connection Profile [message #594752 is a reply to message #53510] |
Fitz,
below.
NPE thrown in
String driverID =
driverID);
try {
} else {
profile.connect();
Stack Trace:
NPE was thrown.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
FUDForum. Page generated in 0.03800 seconds
