Home » Archived » M2M (model-to-model transformation) » [ATL]syntax source model
[ATL]syntax source model [message #529519] Mon, 26 April 2010 09:25 Go to next message
graa is currently offline graaFriend
Member
I would like to know the syntax of source model for ATL (syntax standard of fichier.xmi source).
thank you in advance.
Re: [ATL]syntax source model [message #810525 is a reply to message #529519] Thu, 01 March 2012 07:48 Go to previous message
Algar fr is currently offline Algar frFriend
Hello graa,
It depends on your input and output metamodels.
I invite you to explore some ATL examples to see how the syntax exactly is in every case. You can open for instance the Families to Persons example from here:
http: // www .eclipse.org/m2m/atl/basicExamples_Patterns/
and compare the Families.ecore metamodel with the sample-Families.xmi file, which is its respective model. You also will see that the syntax of the sample-Persons.xmi model conforms to the Persons.ecore metamodel as well.
So basically your model (.xmi file) is defined in terms of your metamodel (.ecore file).
Previous Topic:[ATL] [Solved] Calling a rule a fixed number of times
Next Topic:WSDL to UML Transformation
Current Time: Fri Jan 15 15:17:29 GMT 2021
Powered by FUDForum. Page generated in 0.02214 seconds
