Home » Eclipse Projects » Remote Application Platform (RAP) » Communication from RAP to JavaScript
Communication from RAP to JavaScript [message #528924] Thu, 22 April 2010 12:17 Go to next message
Maziar Khodaei is currently offline Maziar KhodaeiFriend
HI,
I have the following problem. In my RAP-Project I embedded a HTML-site, which included several js-Files.
I can send messages from JS to RAP. Actually I want open a dialog from JS in RAP and return the selected result from RAP to JS.
Is it possible and when yes, how can I do it?!
thx
Maziar
Re: Communication from RAP to JavaScript [message #528971 is a reply to message #528924] Thu, 22 April 2010 14:03 Go to previous messageGo to next message
Benjamin Muskalla is currently offline Benjamin MuskallaFriend
Hi Maziar,
did you take a look at the BrowserFunction API of the SWT Browser
widget? Maybe that could help you in that case.
Ben
Maziar Khodaei wrote:
> HI,
> thx
> Maziar
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: Communication from RAP to JavaScript [message #528991 is a reply to message #528924] Thu, 22 April 2010 14:46 Go to previous messageGo to next message
Hi Ben,
yes, I read the API of browser widget but unfortunately I couldn´t find any solution for this problem.
Maziar
Re: Communication from RAP to JavaScript [message #529175 is a reply to message #528924] Fri, 23 April 2010 09:17 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf SternbergFriend
Hi Maziar,
you can use a PhaseListener to handle your custom requests on the
server. Some examples for the use of PhaseListeners can be found in the
RAP FAQ [1]. If this all becomes too messy, you could also consider
writing a custom widget. See the custom widget tutorial in the RAP
developer guide in your IDE or online [2].
Hope this helps,
Ralf
[1] http://wiki.eclipse.org/RAP/FAQ
[2]
http://help.eclipse.org/galileo/topic/org.eclipse.rap.help/h elp/html/advanced/custom-widget.html
> HI,
> thx
> Maziar
Re: Communication from RAP to JavaScript [message #529511 is a reply to message #528991] Mon, 26 April 2010 08:52 Go to previous messageGo to next message
Erdal Karaca is currently offline Erdal KaracaFriend
If you would use an embedded Browser widget, you could point it to your custom HTML page by setting its url. Then, providing a browser function, you could use it to show that dialog and process its return value in your JS code:
--- js ---
<script .../>
<script .../>
<script>
  // execute Java by calling the browser function
  var returnValue = openComplexDialog();
  // process return value obtained by Java code
  alert(returnValue);
</script>
--- java ...
Browser b = ...
new MyBrowserFunction(b, "openComplexDialog")
class MyBrowserFunction:
Object function(Object[] args) {
  ComplexDialog d = new ComplexDialog(...);
  // calculate return value...
  return returnValue;
Re: Communication from RAP to JavaScript [message #529553 is a reply to message #528924] Mon, 26 April 2010 11:04 Go to previous message
thank you Ralf and thank you Erdal for your tips. It´s work fine.
Thanks a lot Smile
Previous Topic:[Text widget][Context menu]
Next Topic:Not all requests from the client are send to the server through req.addParameter(...)?
Current Time: Fri Jun 02 08:54:02 GMT 2023
Powered by FUDForum. Page generated in 0.02248 seconds
