Home » Language IDEs » Java Development Tools (JDT) » Warning about fix for bug 59891: [formatter] improve lines wrapping in nested method calls
Warning about fix for bug 59891: [formatter] improve lines wrapping in nested method calls [message #528533] Tue, 20 April 2010 16:03 Go to next message
--------------010004090206090409030509
If you're using the JDT/Core formatter, then this message may have some
interest for you otherwise, please, just ignore it.
We're targeting to fix bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=59891
for 3.6M7, work is in progress and we have real interesting results in this area.
Here are some samples, based on the existing bugs and complementary tests,
which show the expected improvement:
(See attached file: examples.txt)
Note that the final fix should be released by the end of the week. Beyond
that the formatter behavior will change for method calls and that will
surely imply some updates in the formatted code, typically if the formatter
is automatically activated while saving a Java file...
Let us know asap if this forthcoming changes might cause troubles.
TIA
Cordialement/Regards,
Fr
Re: Warning about fix for bug 59891: [formatter] improve lines wrapping in nested method calls [message #528571 is a reply to message #528533] Wed, 21 April 2010 02:31 Go to previous message
"Frederic Fusier" <frederic_fusier@fr.ibm.com> wrote in message
news:hql19o$2n7$2@build.eclipse.org...
> for 3.6M7
It's nice to see these very old bugs finally getting some attention!
Thanks, Frederic.
Previous Topic:ATG DYNAMO 7.2
Next Topic:smart searching in code
Current Time: Fri Apr 18 13:24:56 EDT 2025
Powered by FUDForum. Page generated in 0.02967 seconds
