Home » Modeling » Modeling (top-level project) » getResource issue
getResource issue [message #528481] |
Tue, 20 April 2010 16:43 |
Vaz Messages: 16 Registered: July 2009 |
Hello all,
I'm trying to load a xml into an EObject. I use the following code:
resourceSet.getLoadOptions().put(XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE); resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(Resource.Factory.Registry.DEFAULT_EXTENSION, new GenericXMLResourceFactoryImpl());
Resource resource = resourceSet.getResource(URI.createFileURI(xmlFile), true);
EObject documentRoot = (EObject)resource.getContents().get(0);
I get an exception on the last line.
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.IllegalValueException: Value '0' is not legal. (file:///C:/copy/wS/BS/data/example.ifcxml, 161, 46)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at bs.Loader.XsdTest.main(XsdTest.java:113)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value '0' is not legal. (file:///C:/copy/wS/BS/data/example.ifcxml, 161, 46)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2662)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2716)
at org.eclipse.emf.ecore.xmi.impl.SAXXMLHandler.handleObjectAttribs(SAXXMLHandler.java:83)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2192)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFeatureType(XMLHandler.java:2158)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHandler.java:2034)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1813)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1023)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:712)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
... 2 more
Caused by: java.lang.IllegalArgumentException: The value '0' is invalid.
at org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EFactoryImpl.java:439)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createFromString(XMLHelperImpl.java:1621)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1162)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2657)
... 27 more
Well, on the line 161 of the xml file i have the following: "<IfcLengthMeasure pos="0">0.</IfcLengthMeasure>".
In the context:
<IfcCartesianPoint id="i22">
<Coordinates ex:cType="list">
<IfcLengthMeasure pos="1">0.</IfcLengthMeasure>
<IfcLengthMeasure pos="2">0.</IfcLengthMeasure>
</Coordinates>
</IfcCartesianPoint>
The element in the xml schema is as follows:
<xs:element name="IfcLengthMeasure" nillable="true">
<xs:complexType>
<xs:simpleContent>
<xs:extension base="ifc:IfcLengthMeasure">
<xs:attributeGroup ref="ex:instanceAttributes">
</xs:attributeGroup>
</xs:extension>
</xs:simpleContent>
</xs:complexType>
</xs:element>
<xs:simpleType name="IfcLengthMeasure">
<xs:restriction base="xs:double">
</xs:restriction>
</xs:simpleType>
<xs:attributeGroup name="instanceAttributes">
<xs:attribute name="id" type="xs:ID" use="optional"/>
<xs:attribute name="path" type="xs:NMTOKENS" use="optional"/>
<xs:attribute name="pos" use="optional">
<xs:simpleType>
<xs:restriction>
<xs:simpleType>
<xs:list itemType="xs:integer"/>
</xs:simpleType>
<xs:minLength value="1"/>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
</xs:attributeGroup
I already validated the xml with SAX and here: http://tools.decisionsoft.com/schemaValidate/
None of them returned errors, so i'm excluding any xml issues.
Could it be a problem with the parser EMF uses? If i remove the "pos" attribute i don't get the exception, but then i lose important data
Does any of you have an idea or suggestion?
Thank you,
João Vaz
PS. I think i posted on the wrong section as i was planning to post in the EMF section
[Updated on: Tue, 20 April 2010 16:46] Report message to a moderator
Re: getResource issue [message #528492 is a reply to message #528481] |
Tue, 20 April 2010 17:30 |
Ed Merks Messages: 33113 Registered: July 2009 |
João,
Comments below.
Vaz wrote:
> Hello all,
> resourceSet.getLoadOptions().put(XMLResource.OPTION_EXTENDED _META_DATA,
> Boolean.TRUE);
> resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(Resource.Factory.Registry.DEFAULT_EXTENSION,
It already uses that option, so no point in doing the options thing
before it.
> Resource resource =
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
I don't know what models you have registered. Did you generate a model
for your schema? If so, try invoking Generate Test Code and using the
generated XyzExample.java in the *.tests project.
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2662)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XML Handler.java:2716)
> at
> org.eclipse.emf.ecore.xmi.impl.SAXXMLHandler.handleObjectAtt ribs(SAXXMLHandler.java:83)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:2192)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFe atureType(XMLHandler.java:2158)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:2034)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1813)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1023)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
> at
> org.apache.xerces.parsers.AbstractSAXParser.startElement(Unk nown Source)
> at
> org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unknown
> Source)
> at
> org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown
> Source)
> at
> org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
> Source)
> at
> org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unk nown Source)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
> ... 2 more
> invalid. at
> org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EFa ctoryImpl.java:439)
If your schema was actually being used, I'd expect this to end up using
an EDataType from XMLTypeFactoryImpl. Do you know which model's
EDataType is being used to process the literals here?
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createFromStrin g(XMLHelperImpl.java:1621)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHel perImpl.java:1162)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2657)
> ... 27 more
> In the context:
> </Coordinates>
> <xs:complexType>
> <xs:simpleContent>
> </xs:extension>
> </xs:simpleContent>
> </xs:complexType>
> </xs:element>
> </xs:restriction>
> </xs:simpleType>
> <xs:simpleType>
> <xs:restriction>
> <xs:simpleType>
> </xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:attribute>
> </xs:attributeGroup
No, some issue with the data type being used not allowing the value "0"
but I can't imagine why. "xsd:integer" obviously allows that and a list
of those should allow it too.
> lose important data :blush: Does any of you have an idea or suggestion?
> Thank you,
> João Vaz
Ed Merks
Re: getResource issue [message #528697 is a reply to message #528559] |
Wed, 21 April 2010 13:41 |
Vaz,
Comments below.
Vaz wrote:
> Ed,
> Thanks for the quick reply.
> Quote:
>> model for your schema?
> Quote:
>> using an EDataType from XMLTypeFactoryImpl. Do you know which
>> model's EDataType is being used to process the literals here?
> I wanted to load a xsd into an ePackage and then register it in the
> factory. The code I'm currently using to accomplish that is the
> following:
> XSDEcoreBuilder xsdEcoreBuilder = new XSDEcoreBuilder();
> ResourceSet resourceSet = new ResourceSetImpl();
> Collection eCorePackages =
> xsdEcoreBuilder.generate(URI.createFileURI(xsdFile));
Time to start exploiting Java 5.0...
> int n =0;
> Resource resource;
> for (Iterator iter = eCorePackages.iterator();
> iter.hasNext();) {
> n++;
> EPackage element = (EPackage) iter.next();
> resourceSet.getPackageRegistry().put(element.getNsURI(), element);
> // Register XML Factory implementation to handle
> .ecore files
> .put("ecore", new XMLResourceFactoryImpl());
Normally EcoreResourceFactoryImpl is used for Ecore resources.
> // Create empty resource with the given URI
> Resource resource2 = resourceSet.createResource(URI
> .createURI("./" + element.getName() + + n +
> ".ecore"));
> // Add bookStoreEPackage to contents list of the resource
> resource2.getContents().add(element);
If there is more than one Ecore model, it's important to put all of them
in resources before saving any of them so that they reference each other
correctly via their physical location.
> try {
> // Save the resource
> resource2.save(null);
> } catch (IOException e) {
> e.printStackTrace();
> The whole idea (if it's relevant) is to create an app which parses a
> xsd and xml, and loads them into the EMF world so that they can be
> "ATL-transformed".
Just from the snips you've shown, it's not apparent to me yet what data
type is being used to process the "0" value.
> Thank you,
> João Vaz
Ed Merks
Re: getResource issue [message #528992 is a reply to message #528481] |
Thu, 22 April 2010 14:46 |
Hi Ed,
Quote: | Just from the snips you've shown, it's not apparent to me yet what data
My xml schema imports another schema. So in fact I have to load both into separate models, resulting in two separate *.ecore files. Although here, I didn't understand your suggestion, when you say Quote: |
| you mean that I must put both EcorePackages in the same ResourceSet? If so, i think I'm already doing that.
Thus, the relevant lines to solve the error from both generated Ecore models are:
The IfcCartesianPoint:
<eClassifiers xsi:type="ecore:EClass" name="IfcCartesianPoint" eSuperTypes="./org.tech.iai.ifc.xml.ifc._2x3.final2.ecore#//IfcPoint">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="IfcCartesianPoint"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="coordinates" lowerBound="1"
eType="ecore:EClass ./org.tech.iai.ifc.xml.ifc._2x3.final2.ecore#//CoordinatesType1"
containment="true" resolveProxies="false">
<details key="kind" value="element"/>
<details key="name" value="Coordinates"/>
<details key="namespace" value="##targetNamespace"/>
</eAnnotations>
</eStructuralFeatures>
</eClassifiers>
which has an eStructuralFeature "Coordinates" of the type CoordinatesType1:
<eClassifiers xsi:type="ecore:EClass" name="CoordinatesType1">
<details key="name" value="Coordinates_._1_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="ifcLengthMeasure" lowerBound="1"
upperBound="3" eType="ecore:EClass ./org.tech.iai.ifc.xml.ifc._2x3.final2.ecore#//IfcLengthMeasureType"
<details key="name" value="IfcLengthMeasure"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="arraySize" eType="ecore:EDataType ./org.iso.standard._10303.part._28.version._2.xmlschema.common2.ecore#//ArraySizeType">
<details key="kind" value="attribute"/>
<details key="name" value="arraySize"/>
<details key="namespace" value="urn:iso.org:standard:10303:part(28):version(2):xmlschema:common"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="cType" eType="ecore:EDataType ./org.iso.standard._10303.part._28.version._2.xmlschema.common2.ecore#//CTypeType"
defaultValueLiteral="list" unsettable="true">
<details key="name" value="cType"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="itemType" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//QName"
defaultValueLiteral="ifc:IfcLengthMeasure" unsettable="true">
<details key="name" value="itemType"/>
</eAnnotations>
</eClassifiers>
Here starts the problem (i think...), because the CoordinatesType1 has an eStructuralFeatures named ifcLengthMeasure which references the type IfcLengthMeasureType :
<eClassifiers xsi:type="ecore:EClass" name="IfcLengthMeasureType">
<details key="name" value="IfcLengthMeasure_._type"/>
<details key="kind" value="simple"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value" eType="ecore:EDataType ./org.tech.iai.ifc.xml.ifc._2x3.final2.ecore#//IfcLengthMeasure"
unsettable="true">
<details key="name" value=":0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="id" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//ID"
iD="true">
<details key="name" value="id"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="path" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//NMTOKENS">
<details key="name" value="path"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="pos" eType="ecore:EDataType ./org.iso.standard._10303.part._28.version._2.xmlschema.common2.ecore#//PosType">
<details key="name" value="pos"/>
</eAnnotations>
</eClassifiers>
The error parsing the xml data is very specific and points out to the Attribute "pos" of the Eclass above, and it doesn't matter what value I insert. That Attribute is of the type "PosType" and is declared in the other Ecore file as follows:
<eClassifiers xsi:type="ecore:EDataType" name="PosType" instanceClassName="java.util.List">
<details key="name" value="pos_._type"/>
<details key="minLength" value="1"/>
</eAnnotations>
</eClassifiers>
And finally, the xml I'm trying to load (which is created automatically with a specific sofware):
</Coordinates>
Do you think there's a problem with the generated models? Or maybe even with the way they reference each other?
I know the post got a bit confusing (and huge), sorry for that, but it gets really difficult to explain the problem.
Thanks once more,
João Vaz
Re: getResource issue [message #529291 is a reply to message #528992] |
Fri, 23 April 2010 17:12 |
Vaz,
Comments below.
Vaz wrote:
> Hi Ed,
> Quote:
>> data type is being used to process the "0" value.
>> them in resources before saving any of them so that they reference
>> each other correctly via their physical location.
The models will reference each other via the URI of the resource that
contains them, so it's import to establish those names first. Perhaps
you're lucky that the order in which you process happens to set the URI
of the referenced model before a reference to it from the second model
is saved.
> models are:
> eSuperTypes="./org.tech.iai.ifc.xml.ifc._2x3.final2.ecore#//IfcPoint ">
> <eAnnotations
> </eAnnotations>
> lowerBound="1"
> eType="ecore:EClass
> ./org.tech.iai.ifc.xml.ifc._2x3.final2.ecore#//CoordinatesTy pe1 "
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> CoordinatesType1:
> <eAnnotations
> </eAnnotations>
> ./org.tech.iai.ifc.xml.ifc._2x3.final2.ecore#//IfcLengthMeas ureType "
> <eAnnotations
> </eAnnotations>
> ./org.iso.standard._10303.part._28.version._2.xmlschema.comm on2.ecore#//ArraySizeType ">
> <eAnnotations
> value=" urn:iso.org:standard:10303:part(28):version(2):xmlschema:com mon "/>
> </eAnnotations>
> ./org.iso.standard._10303.part._28.version._2.xmlschema.comm on2.ecore#//CTypeType "
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> ./org.tech.iai.ifc.xml.ifc._2x3.final2.ecore#//IfcLengthMeas ure "
> unsettable="true">
> <eAnnotations
> </eAnnotations>
> iD="true">
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> ./org.iso.standard._10303.part._28.version._2.xmlschema.comm on2.ecore#//PosType ">
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
I don't seen an annotation for key="baseType" nor any EDataType that
specifies the itemType.
> </eAnnotations>
> </eClassifiers>
If you provide a complete schema I can see if it's producing the right
Ecore model from it but what you show looks incomplete.
> </Coordinates>
> Thanks once more,
> João Vaz
Ed Merks
Re: getResource issue [message #529882 is a reply to message #529652] |
Tue, 27 April 2010 14:44 |
Ed,
Currently I'm working with two versions.
- Eclipse 3.6.0 + Emf 2.6.0
- Eclipse 3.5.0 + Emf 2.5.0
I get same error with both of them.
Quote: | > Shouldn't the "PosType" have a reference to the "PosTypeBase"? I know
> the "PosTypeBase" represents a restriction in xml.
Well, yes, that was the point of my earlier notes.
Is that a bug or a feature?
Ed Merks wrote on Mon, 26 April 2010 11:59 | Vaz,
Comments below.
Vaz wrote:
> Ed,
> Just spent a few more minutes analyzing deeply the generated ecores
> and after reading the "XML schema to Ecore Mapping pdf" some questions
> arise:
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eClassifiers xsi:type="ecore:EDataType" name="PosTypeBase"
> <eAnnotations
> <details key="name" value="pos_._type_._base"/>
> <details key="itemType"
> value="http://www.eclipse.org/emf/2003/XMLType#integer"/>
> </eAnnotations>
> </eClassifiers>
> The problem lies in here somewhere, since if i add an "id" or a "path"
> in xml data, which are the other eStructuralFeatures in the class
> "IfcLengthMeasureType", the problem doesn't
Version version of EMF are you using? Perhaps this is a bug that's been
fixed in the latest...
> show up.
> Thanks again for your time.
> João Vaz
João Vaz
Re: getResource issue [message #529910 is a reply to message #529882] |
Tue, 27 April 2010 16:14 |
Vaz,
The problem is that I can't reproduce your problem. You've not modified
the schemas I used directly from the web in any way? Unless I can
reproduce it, I can't do anything about it, so if you want to be look at
this further, you'll need to send me a completely self contained test
case (e.g., exported projects I can import into my workspace) and which
I can execute to see this problem.
Vaz wrote:
> Ed,
> Currently I'm working with two versions. - Eclipse 3.6.0 + Emf 2.6.0
> Quote:
>> know > the "PosTypeBase" represents a restriction in xml.
>> Vaz,
>> Comments below.
>> Vaz wrote:
>> > Ed,
>> questions > arise:
>> > <eClassifiers xsi:type="ecore:EDataType" name="PosType" >
>> > <eAnnotations >
>> > </eAnnotations>
>> > </eClassifiers>
>> > <eClassifiers xsi:type="ecore:EDataType" name="PosTypeBase" >
>> > <eAnnotations >
>> > <details key="itemType" >
>> > </eAnnotations>
>> > </eClassifiers>
>> "path" > in xml data, which are the other eStructuralFeatures in the
>> class > "IfcLengthMeasureType", the problem doesn't
>> been fixed in the latest...
>> > show up.
>> > João Vaz
> Thanks
> João Vaz
Ed Merks
Re: getResource issue [message #619538 is a reply to message #619502] |
Vaz,
Comments below.
Vaz wrote:
> Ed,
> Quote:
> Quote:
> following:
> int n =0;
> Resource resource;
> iter.hasNext();) {
> n++;
> .ecore files
> ".ecore"));
> try {
> "ATL-transformed".
> Thank you,
> João Vaz
Ed Merks
Re: getResource issue [message #619555 is a reply to message #529643] |
Mon, 26 April 2010 15:59 |
Vaz,
Comments below.
Vaz wrote:
> Ed,
> arise:
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> show up.
> João Vaz
Ed Merks
Re: getResource issue [message #619556 is a reply to message #529652] |
Ed,
> Vaz,
> Comments below.
> Vaz wrote:
> > Ed,
> > arise:
> > <eAnnotations
> > </eAnnotations>
> > </eClassifiers>
> > <eAnnotations
> > </eAnnotations>
> > </eClassifiers>
> > show up.
> > João Vaz
João Vaz
Re: getResource issue [message #619557 is a reply to message #529882] |
Vaz,
Vaz wrote:
> Ed,
> Quote:
>> Vaz,
>> Comments below.
>> Vaz wrote:
>> > Ed,
>> questions > arise:
>> > <eAnnotations >
>> > </eAnnotations>
>> > </eClassifiers>
>> > <eAnnotations >
>> > </eAnnotations>
>> > </eClassifiers>
>> > show up.
>> > João Vaz
> Thanks
> João Vaz
Ed Merks
Current Time: Thu Mar 28 11:31:09 GMT 2024
Powered by FUDForum. Page generated in 0.07875 seconds
