EGL execution error [message #528429] |
Tue, 20 April 2010 13:31 |
Originally posted by: c.k.holmes.lboro.ac.uk
I would like to investigate the use of EGL. I have created a minimal EGL
template:
<snip>
[% for (i in Sequence{1..5}) { %]
i is [%=i%]
</snip>
When I try to run this via Run Configurations I set:
Template:
Generate text to console
Models:
Point to both the model and metamodels (although for the sake of this
example neither are relevant)
Store on disposal is unchecked
Common:
save as local file
Running the template results in the following error:
<snip>
Could not process
'C:Blah\DocumentModels\DocumentGenerators\HTML\RenderDocumen t.egl'
at
org.eclipse.epsilon.egl.EglTemplateFactory.load(EglTemplateF actory.java:154)
at
org.eclipse.epsilon.egl.dt.launching.EglLaunchConfigurationD elegate.launch(EglLaunchConfigurationDelegate.java:63)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:853)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:703)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:866)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1069)
</snip>
What have I forgotten to set up?
Chris
Re: EGL execution error [message #528447 is a reply to message #528437] |
Tue, 20 April 2010 14:32 |
Hi Dimitris,
Thanks, it does :)
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> This is due to a regression in the interim version you're using.
> Updating to the latest stable version (0.8.9) should fix the problem.
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> EGL template:
>> <snip>
>> i is [%=i%]
>> </snip>
>> Template:
>> Models:
>> Common:
>> save as local file
>> <snip>
>> Could not process
>> at
>> at
>> at
>> at
>> at
>> at
>> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
>> </snip>
>> Regards
>> Chris
Re: EGL execution error [message #588407 is a reply to message #528437] |
Hi Dimitris,
Thanks, it does :)
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> EGL template:
>> <snip>
>> i is [%=i%]
>> </snip>
>> Template:
>> Models:
>> Common:
>> save as local file
>> <snip>
>> Could not process
>> at
>> at
>> at
>> at
>> at
>> at
>> </snip>
>> Regards
>> Chris
FUDForum. Page generated in 0.02564 seconds
