Home » Eclipse Projects » Remote Application Platform (RAP) » Is there a tool or plugin for RAP to trace memory use(Too many UI Elements result in too much memory use.)
Is there a tool or plugin for RAP to trace memory use [message #527664] Fri, 16 April 2010 02:49 Go to next message
wayne  is currently offline wayne Friend
Hi Guys,
I am working on a project with many UI elements. When I run the program, memory usage is pretty high. I want to know if there is a tool or plugin for tracing JAVA memory usage in RAP env?
Re: Is there a tool or plugin for RAP to trace memory use [message #527684 is a reply to message #527664] Fri, 16 April 2010 06:44 Go to previous messageGo to next message
Benjamin Wolff is currently offline Benjamin WolffFriend
the Memory Analyzer (MAT) is the tool to go for: http://www.eclipse.org/mat/
I think there've been a tutorial how to use it with RAP. But i could not find
it. The tutorial on the projekt homepage should be sufficient.
Pretty cool tool, i already used it for my projects.
Greetings,
-ben
Am 16.04.2010 04:49, schrieb wayne:
> Hi Guys,
Re: Is there a tool or plugin for RAP to trace memory use [message #527975 is a reply to message #527664] Sat, 17 April 2010 17:42 Go to previous message
Originally posted by: karsten_voigt.gmx.de
just to mention another one :-) I use the visualvm direct from java
(https://visualvm.dev.java.net/). Within that tool you can download some
more plugins that will make life much easier...
wayne schrieb:
> Hi Guys,
Previous Topic:Periodic activity for duration of session?
Next Topic:transparency ExpandedComposite, Composite
Current Time: Wed Jan 19 08:52:01 GMT 2022
Powered by FUDForum. Page generated in 0.02374 seconds
