Home » Modeling » Epsilon » [eugenia] specifying compartments in an abstract class
[eugenia] specifying compartments in an abstract class [message #527244] Wed, 14 April 2010 11:02 Go to next message
hi all
in my current model i have an abstract class that defines some containment associations, and some classes that extend that abstract class.
i now defined that abstract class as a node and the associations as compartments.
while eugenia correctly creates nodes for all nonabstract subclasses, it does not create the compartments.
i tried some other solutions like explicitely defining all subclasses as nodes, but i could not get the compartments to work.
so before i go on with this, i wanted to ask if it is at all possible to create compartments for abstract classes (actually for their nonabstract subclasses) or not?
thanks in advance
marco
Re: [eugenia] specifying compartments in an abstr act class [message #527263 is a reply to message #527244] Wed, 14 April 2010 11:35 Go to previous messageGo to next message
Hi Marco,
This should work. Could you please provide a minimal metamodel in
emfatic that reproduces this?
Dimitris
<Marco.Kranz@fokus.fraunhofer.de> wrote:
> hi all
> class.
> compartments.
> thanks in advance
> marco
Re: [eugenia] specifying compartments in an abstr act class [message #527494 is a reply to message #527263] Thu, 15 April 2010 09:18 Go to previous messageGo to next message
hi dimitris
once again false alarm... Smile
i checked the model again and found that the associations are in fact no containments, so it couldn't work... Confused
is there a way of achieving the same effect for non containment associations?
cheers
marco
Re: [eugenia] specifying compartments in an abstr act class [message #527500 is a reply to message #527494] Thu, 15 April 2010 09:20 Go to previous messageGo to next message
Hi Marco,
That's a very good question indeed :) Could you possibly investigate
this using plain-vanilla GMF? If this is possible I'd be more than happy
to add support for this to Eugenia!
Dimitris
Marco.Kranz@fokus.fraunhofer.de wrote:
> hi dimitris
> once again false alarm... :)
> containments, so it couldn't work... :?
> associations?
> cheers
> marco
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: [eugenia] specifying compartments in an abstr act class [message #527512 is a reply to message #527500] Thu, 15 April 2010 09:51 Go to previous message
i have to find a way, at least something that looks/works similar.
i'll let you know in case i'm successful.
(it may take some time though since i've other things to do first).
Re: [eugenia] specifying compartments in an abstr act class [message #588325 is a reply to message #527263] Thu, 15 April 2010 09:18 Go to previous message
hi dimitris
i checked the model again and found that the associations are in fact no containments, so it couldn't work... :?
cheers
marco
Re: [eugenia] specifying compartments in an abstr act class [message #588333 is a reply to message #527494] Thu, 15 April 2010 09:20 Go to previous message
Hi Marco,
Dimitris
> hi dimitris
> associations?
> cheers
> marco
Re: [eugenia] specifying compartments in an abstr act class [message #588340 is a reply to message #527500] Thu, 15 April 2010 09:51 Go to previous message
Previous Topic:[eugenia] specifying compartments in an abstract class
Next Topic:adding markers to eugenia based editor after applying evl constraints to emfdiff model
Current Time: Sat Nov 08 14:03:39 EST 2025
Powered by FUDForum. Page generated in 0.06488 seconds
