RAP is not working with Galileo 3.5 [message #526436] |
Sun, 11 April 2010 01:41 |
lottalava Messages: 12 Registered: October 2009 |
Hello folks, iǘe just installed Galileo 3.5 and Eclipse RAP runtime ( in a different directory ), my problem is, i cannot run a simple Hello World exemple from eclipse!'
This is what i got from console output:
osgi> !SESSION 2010-04-10 22:41:19.917 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_13
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -dev file:/home/edson/workspace/.metadata/.plugins/org.eclipse.pd e.core/Blah/dev.properties -os linux -ws gtk -arch x86 -console -consolelog
!ENTRY Blah 4 0 2010-04-10 22:41:23.333
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui; bundle-version="0.0.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolverError(AbstractBundle.java:1312)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolutionFailureException(AbstractBundle.java:1296)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:319)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:369)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1068)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:554)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:461)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:246)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:442)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:337)
!ENTRY org.eclipse.rap.demo 4 0 2010-04-10 22:41:23.371
!MESSAGE
!STACK 0
!ENTRY org.eclipse.rap.ui 4 0 2010-04-10 22:41:24.396
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui.workbench; bundle-version="[1.3.0,2.0.0)"
!ENTRY org.eclipse.rap.demo.databinding 4 0 2010-04-10 22:41:26.856
!MESSAGE
!STACK 0
!ENTRY org.eclipse.rap.ui.views 4 0 2010-04-10 22:41:26.874
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui; bundle-version="[1.2.0,4.0.0)"
!ENTRY org.eclipse.rap.ui.workbench 4 0 2010-04-10 22:41:27.021
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.help; bundle-version="[3.5.0,4.0.0)"
!ENTRY org.eclipse.osgi 4 0 2010-04-10 22:41:27.089
!MESSAGE Bundle initial@reference:file:../../home/edson/workspace/Blah/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2010-04-10 22:41:27.094
!MESSAGE Bundle initial@reference :file:../eclipse-RAP/plugins/org.eclipse.rap.ui.views_1.3.0. 20100316-1859.jar/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2010-04-10 22:41:27.096
!MESSAGE Bundle initial@reference :file:../eclipse-RAP/plugins/org.eclipse.rap.ui_1.3.0.201003 16-1859.jar/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2010-04-10 22:41:27.099
!MESSAGE Bundle initial@reference :file:../eclipse-RAP/plugins/org.eclipse.rap.demo_1.3.0.2010 0316-1859.jar/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2010-04-10 22:41:27.101
!MESSAGE Bundle initial@reference :file:../eclipse-RAP/plugins/org.eclipse.rap.demo.databindin g_1.3.0.20100316-1859.jar/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2010-04-10 22:41:27.103
!MESSAGE Bundle initial@reference :file:../eclipse-RAP/plugins/org.eclipse.rap.ui.workbench_1. 3.0.20100316-1859.jar/ was not resolved.
Re: RAP is not working with Galileo 3.5 [message #526449 is a reply to message #526436] |
Sun, 11 April 2010 08:30 |
Ivan Furnadjiev Messages: 2427 Registered: July 2009 Location: Sofia, Bulgaria |
did you set RAP as a target platform? Please post the result of osgi ss
command.
Best,
Ivan
> -consolelog
> !MESSAGE !STACK 0
> !MESSAGE !STACK 0
> !MESSAGE !STACK 0
> !MESSAGE !STACK 0
> !MESSAGE !STACK 0
> !MESSAGE !STACK 0
> !MESSAGE Bundle
> mailto:initial@reference:file:../../home/edson/workspace/Blah/ was not
> resolved.
> !MESSAGE Bundle mailto:initial@reference
Re: RAP is not working with Galileo 3.5 [message #526501 is a reply to message #526472] |
Sun, 11 April 2010 23:45 |
I made what you told me to do, here is what osgi wrote in console ( just to mention, i'm using RAP 1.3M6 ) :
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.6.0.v20100301
26 INSTALLED Blah_1.0.0.qualifier
33 ACTIVE org.eclipse.rap.ui.forms_1.3.0.20100316-1859
34 ACTIVE org.eclipse.core.databinding.observable_1.3.0.I20100310-1300
35 ACTIVE com.ibm.icu.base_4.2.1.v20100212
36 INSTALLED org.eclipse.rap.demo_1.3.0.20100316-1859
37 ACTIVE javax.servlet_2.5.0.v200910301333
38 ACTIVE org.eclipse.osgi.services_3.2.100.v20100108
39 ACTIVE org.eclipse.equinox.common_3.6.0.v20100222
40 ACTIVE org.eclipse.equinox.http.registry_1.1.0.v20100307
41 INSTALLED org.eclipse.rap.ui_1.3.0.20100316-1859
42 ACTIVE org.eclipse.core.expressions_3.4.200.v20100222
43 ACTIVE org.mortbay.jetty.server_6.1.15.v200905151201
44 ACTIVE org.eclipse.equinox.http.jetty_2.0.0.v20090520-1800
45 ACTIVE org.eclipse.rap.jface.databinding_1.3.0.20100316-1859
46 ACTIVE org.eclipse.core.commands_3.6.0.I20100122-0800
47 INSTALLED org.eclipse.rap.demo.databinding_1.3.0.20100316-1859
48 ACTIVE org.eclipse.equinox.preferences_3.3.0.v20100307
49 ACTIVE org.eclipse.core.jobs_3.5.0.v20100304
50 ACTIVE org.mortbay.jetty.util_6.1.15.v200905182336
51 ACTIVE org.eclipse.core.databinding.beans_1.2.100.I20100310-1300
52 INSTALLED org.eclipse.rap.ui.views_1.3.0.20100316-1859
53 RESOLVED org.eclipse.rap.rwt.q07_1.3.0.20100316-1859
Master=56
54 ACTIVE org.eclipse.equinox.registry_3.5.0.v20100301
55 ACTIVE org.eclipse.rap.jface_1.3.0.20100316-1859
56 ACTIVE org.eclipse.rap.rwt_1.3.0.20100316-1859
Fragments=53
57 ACTIVE org.eclipse.core.contenttype_3.4.100.v20100301
58 ACTIVE org.eclipse.equinox.http.servlet_1.1.0.v20100201
59 ACTIVE org.eclipse.core.runtime_3.6.0.v20091204
60 ACTIVE org.eclipse.core.databinding.property_1.3.0.I20100310-1300
61 INSTALLED org.eclipse.rap.ui.workbench_1.3.0.20100316-1859
62 ACTIVE org.eclipse.equinox.app_1.3.0.v20100304
63 ACTIVE org.eclipse.core.databinding_1.3.100.I20100310-1300
[Updated on: Sun, 11 April 2010 23:47] Report message to a moderator
Re: RAP is not working with Galileo 3.5 [message #526522 is a reply to message #526501] |
Mon, 12 April 2010 07:16 |
your org.eclipse.rap.ui bundle has not been started. Try a 'diag 41' or
start it manually 'start 41' to see what the problem is.
Ralf
lottalava wrote:
> I made what you told to do, here is what osgi wrote in console ( just to
> osgi> ss
> id State Bundle
> 34 ACTIVE
> Master=56
> Fragments=53
> 60 ACTIVE
FUDForum. Page generated in 0.02648 seconds
