Home » Modeling » EMF » [CDO] Model Corruption ClassCastException Server Side
[CDO] Model Corruption ClassCastException Server Side [message #526106] Thu, 08 April 2010 17:18 Go to next message
Gaetan is currently offline GaetanFriend
(my current platform is Ganymede / CDO 2.0 (the latest version from the 2.0 maintenance branch) )
I have a model, and I commit it on CDO server, I can use this model in the current instance of my CDO server but when I restart the server and load my model,
I have this Exception :
org.eclipse.net4j.signal.RemoteException: java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EGenericTypeImpl cannot be cast to org.eclipse.emf.ecore.EModelElement
	at org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteException(RequestWithConfirmation.java:128)
	at org.eclipse.net4j.signal.SignalProtocol.handleRemoteException(SignalProtocol.java:495)
	at org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:53)
	at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:55)
	at org.eclipse.net4j.signal.Signal.doInput(Signal.java:311)
	at org.eclipse.net4j.signal.Indication.execute(Indication.java:49)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:238)
	at org.eclipse.net4j.signal.Signal.run(Signal.java:146)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EGenericTypeImpl cannot be cast to org.eclipse.emf.ecore.EModelElement
	at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.getMetaInstance(MetaDataManager.java:91)
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.ObjectTypeCache.getObjectType(ObjectTypeCache.java:99)
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.readObjectType(AbstractHorizontalMappingStrategy.java:66)
	at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readObjectType(DBStoreAccessor.java:136)
	at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.getObjectType(DBStoreAccessor.java:144)
	at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readRevision(DBStoreAccessor.java:168)
	at org.eclipse.emf.cdo.internal.server.Repository.loadRevisions(Repository.java:297)
	at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.loadRevisions(CDORevisionManagerImpl.java:350)
	at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevisions(CDORevisionManagerImpl.java:253)
	at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevision(CDORevisionManagerImpl.java:235)
	at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevision(CDORevisionManagerImpl.java:1)
	at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.execute(RevisionInfo.java:128)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.LoadRevisionsIndication.responding(LoadRevisionsIndication.java:169)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndication.responding(CDOServerIndication.java:119)
	at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:96)
	at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:281)
	at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOReadIndication.execute(CDOReadIndication.java:36)
	... 5 more
I have set a breakpoint in MetaDataManager :
 public EModelElement getMetaInstance(long id)
	    CDOIDMeta cdoid = CDOIDUtil.createMeta(id);
	    InternalEObject metaInstance = getPackageRegistry().getMetaInstanceMapper().lookupMetaInstance(cdoid);
	    return (EModelElement)metaInstance;
The value of metaInstance is org.eclipse.emf.ecore.impl.EGenericTypeImpl@1c03a0 (expression: XX)
I don't understand because I have not used a GenericType.
Gaëtan.
[Updated on: Fri, 09 April 2010 07:26]
Report message to a moderator
Re: [CDO] Model Corruption ClassCastException Server Side [message #526580 is a reply to message #526106] Mon, 12 April 2010 10:51 Go to previous messageGo to next message
My problem disapeared when I reinstalled my server plugins. My CDO plugins set was apparently unstable.
So I cannot reproduce this problem in my cdo server anymore.
Gaetan.
Re: [CDO] Model Corruption ClassCastException Server Side [message #526604 is a reply to message #526580] Mon, 12 April 2010 11:53 Go to previous message
Eike Stepper is currently offline Eike StepperFriend
Hi Gaetan,
I was waiting for Stefan to comment on a potential DBStore issue. Good
that it works now for you ;-)
Cheers
/Eike
Am 12.04.2010 12:51, schrieb Gaetan:
> Gaetan.
Previous Topic:[CDO databinding]
Next Topic:[EMF Databinding] Sorting on databound TableViewer columns
Current Time: Tue Apr 16 08:05:44 GMT 2024
Powered by FUDForum. Page generated in 0.17354 seconds
