H2 enablement [message #526056] |
Thu, 08 April 2010 15:17 |
Romain Bioteau Messages: 65 Registered: August 2009 Location: Grenoble |
Member |
I've integrated DTP in a RCP and we need to add some connectivity to
other product than those present in enablement project.
For example, I need to provide an enablement for H2 database. I have
followed this tutorial :
http://fitzdtp.blogspot.com/2008/08/dtp-sqlite-support-conti nued-on-to.html
However, I think i've missed the xmi generation (just left the template
value) as I don't know the specification for H2. The result is that I
succeed to connect the db but i've only access to the INFORMATION_SCHEMA
tables. I didn't succeed to see public table.
Thanks for your help.
Romain
R&D Engineer at BonitaSoft
Re: H2 enablement [message #597428 is a reply to message #526300] |
Fri, 09 April 2010 15:00 |
Member |
Hi Fitz,
I did try to do but something but i'm stuck with the same problem that
is : I don't know what is the specificity of H2 (the tutorial is
speaking about sqlite). Is H2 the same of Sqlite for catalog loaders ?
(no schema ?)
I will try to stick to the tutorial to see if it works like SQLite.
Thanks for the help
Romain
Le 09/04/2010 16:36, Brian Fitzpatrick a écrit :
> Hi Romain!
> Did you implement the catalog loaders that article discusses? That's
> where the SQL results coming back from the database are converted to the
> EMF model that gets rendered in the tree.
> --Fitz
> Romain Bioteau wrote:
>> Hi,
>> template value) as I don't know the specification for H2. The result
>> is that I succeed to connect the db but i've only access to the
>> INFORMATION_SCHEMA tables. I didn't succeed to see public table.
>> Romain
FUDForum. Page generated in 0.03581 seconds
