Home » Language IDEs » Java Development Tools (JDT) » decoding generics in signature(help needed)
decoding generics in signature [message #526033] Thu, 08 April 2010 10:52 Go to next message
Hi all
I am trying to get the fully qualified name of generic types, for instance
"QArrayList<QObservator;>;" should be read as "java.util.ArrayList<fr.emn.example.Observator>"
There are several methods about that in Signature of core JDT but
it seems rather complex to use.
What help me could be an example or better a program doing this!
best regards
Re: decoding generics in signature [message #526095 is a reply to message #526033] Thu, 08 April 2010 12:42 Go to previous messageGo to next message
You cannot do that using the java model.
The java model doesn't contain resolved signatures. If you describe what you are trying to do, I might be able to tell you how to do it.
Olivier
Re: decoding generics in signature [message #526237 is a reply to message #526095] Fri, 09 April 2010 06:23 Go to previous messageGo to next message
Hi Olivier
I want to analyse Java source code and to extract type information,
for signature, fields, array, generics and so on.
I was presuming that JDT could help me here, and in fact I known to extract
some information.
But I have problems with the various encoding, resolved types, etc.
If there is a better and simpler way to do that of course I am interested.
regards
Re: decoding generics in signature [message #529858 is a reply to message #526033] Tue, 27 April 2010 09:40 Go to previous messageGo to next message
see also snippet of ScoutSignature (Eclipse Scout Project)
http://www.eclipse.org/forums/index.php?t=msg&th=167027& amp;start=0&
Cheers
Andreas
Re: decoding generics in signature [message #530530 is a reply to message #526237] Thu, 29 April 2010 19:54 Go to previous message
You can use the DOM/AST API with bindings if you care about resolved information.
Olivier
Previous Topic:how to view project cycles?
Next Topic:Produce ant build.xml or maven pom.xml automatically in Eclipse
Current Time: Fri Apr 18 10:35:36 EDT 2025
Powered by FUDForum. Page generated in 0.04009 seconds
