Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT.PASSWORD default echo char
SWT.PASSWORD default echo char [message #525917] Thu, 08 April 2010 09:38 Go to next message
Luca Ferrari is currently offline Luca FerrariFriend
I'm using a text field for password prompt, and the field has the SWT.PASSWORD style. Since I'd like to provide the user with a "show password" checkbox I need the echo char used in the SWT.PASSWORD field to set/unset it as echo char. On my platform (Linux KDE) the echo char is a big black circle, not the usual '*'. So after I've done a
passwordText.setEchoChar('\0');
I'd like to re-set it again with such default big black circle. Is there a way to set such default password echo char?
Re: SWT.PASSWORD default echo char [message #525983 is a reply to message #525917] Thu, 08 April 2010 13:17 Go to previous messageGo to next message
Dmitry K is currently offline Dmitry KFriend
Have you looked at the setEchoChar source?
Under win it starts with smth like:
public void setEchoChar (char echo) {
	checkWidget ();
	if ((style & SWT.MULTI) != 0) return;
	if (echo != 0) {
		if ((echo = (char) Display.wcsToMbcs (echo, getCodePage ())) == 0) echo = '*';
Maybe, under KDE char for this circle can be found in the same location?
Re: SWT.PASSWORD default echo char [message #525986 is a reply to message #525917] Thu, 08 April 2010 13:13 Go to previous messageGo to next message
Praveen  is currently offline Praveen Friend
Member
Use this code - it will reset to (default) dark circle :)
char ch = 0x25cf;
text.setEchoChar(ch);
I hope it works on all platforms.
Re: SWT.PASSWORD default echo char [message #525994 is a reply to message #525986] Thu, 08 April 2010 13:47 Go to previous message
using such character works for me.
Previous Topic:CTabFolderRenderer can't be usefully subclassed
Next Topic:SWT Browser Widget, no mouse events while loading
Current Time: Sun Jan 19 11:01:51 GMT 2025
Powered by FUDForum. Page generated in 0.07665 seconds
