Home » Modeling » OCL » Adding new operations to the String primitive datatype
Adding new operations to the String primitive datatype [message #53056] |
Fri, 21 March 2008 21:07 |
Hi OCL team!
I'm a new user of the QVTO component, and there's a question I have about
their OCL implementation, which I understand, is made by you guys.
I have a comma-separated string and I need to split it. From the spec, I
can see that the operations supported by the String datatype are size(),
concat(), substring(), toInteger() and toReal(), but there's no split()
operation. Is there a way to extend the plug-in to add new operations to
the String datatype? I'm truly illiterate on OCL so I'd be extremely
thankful if you could point me in the right direction. Thank you very much!
-Juan
Re: Adding new operations to the String primitive datatype [message #53163 is a reply to message #53056] |
Mon, 24 March 2008 15:38 |
Hi, Juan,
Yes, there is a way to do this.
Follow the example that adds a "regexMatch" operation to the String type in
the "Customizing the Environment" topic (under "Advanced Topics") in the
OCL SDK's developer guide in the on-line help. This illustrates how to
implement new operations in Java, for cases that would be too difficult or
impossible with OCL.
For operations that can be defined using OCL, the standard def: expression
syntax is supported.
HTH,
Christian
Juan Jose Cadavid G wrote:
> Hi OCL team!
> much!
> -Juan
Re: Adding new operations to the String primitive datatype [message #53214 is a reply to message #53163] |
Tue, 25 March 2008 12:15 |
Originally posted by: Alexander.Igdalov.borland.com
Hi Christian,
Although the what you mention works fine with OCL, currently QVTO which
internally uses the same approach must be extended in a different way.
See news://news.eclipse.org:119/fsap7g$r5a$1@build.eclipse.org
Alex.
Christian W. Damus wrote:
> Hi, Juan,
> HTH,
> Christian
>> Hi OCL team!
>> much!
>> -Juan
Re: Adding new operations to the String primitive datatype [message #53240 is a reply to message #53214] |
Tue, 25 March 2008 13:49 |
Thanks, Alex,
That's good to know. However, your link didn't work for my newsreader; it
gets a "430 No such article" error.
Can you provide a different way to link to this article?
Christian
Alexander Igdalov wrote:
> Hi Christian,
> Regards,
> Alex.
>> Hi, Juan,
>> in the "Customizing the Environment" topic (under "Advanced Topics") in
>> the
>> or impossible with OCL.
>> expression syntax is supported.
>> HTH,
>> Christian
>>> Hi OCL team!
>>> about their OCL implementation, which I understand, is made by you guys.
>>> much!
>>> -Juan
Re: Adding new operations to the String primitive datatype [message #53325 is a reply to message #53240] |
Wed, 26 March 2008 09:23 |
Hi Christian,
Sorry for the bad link. Try the HTTP version:
http://www.eclipse.org/newsportal/article.php?id=2390&gr oup=eclipse.modeling.m2m#2390
Alex.
> Thanks, Alex,
> Christian
>> Hi Christian,
>> Regards,
>> Alex.
>>> Hi, Juan,
>>> the
>>> HTH,
>>> Christian
>>>> Hi OCL team!
>>>> much!
>>>> -Juan
Current Time: Wed Apr 24 20:56:07 GMT 2024
Powered by FUDForum. Page generated in 0.03828 seconds
