Home » Modeling » Amalgam » DSL Toolkit Build Problems
DSL Toolkit Build Problems [message #525212] Wed, 16 September 2009 11:29 Go to next message
Rod Hughes is currently offline Rod HughesFriend
I am working throug the eclipse Modeling Project book and have installed
the galileo DSL Toolkit (1.0.0M8)for 32-bit windows along with Java 6,
update 16.
Building the project results in 203 build errors and 29 warnings. The
majority of these errros are in 5 Xpand files in the dnc project. There
are also some problems in mindmap2xhtml.qvto.
Should the 1.0.0M8 DSL Toolkit build cleanly?
If so, any suggestions you may have to correct these issues are
appreciated.
Re: DSL Toolkit Build Problems [message #525215 is a reply to message #525212] Thu, 17 September 2009 16:29 Go to previous messageGo to next message
Rod,
It's probably better to ask on the mailing list of the project from
which that source code comes.
> installed the galileo DSL Toolkit (1.0.0M8)for 32-bit windows along
> with Java 6, update 16.
> There are also some problems in mindmap2xhtml.qvto.
> appreciated.
Ed Merks
Re: DSL Toolkit Build Problems [message #525223 is a reply to message #525212] Wed, 21 October 2009 10:53 Go to previous message
Richard Gronback is currently offline Richard GronbackFriend
If you're using the book examples, you'll need to use the corresponding
version of the DSL Toolkit. There were changes to QVTO since then that
require some changes to the transformation definition.
Best,
Rich
Re: DSL Toolkit Build Problems [message #584028 is a reply to message #525212] Thu, 17 September 2009 16:29 Go to previous message
Rod,
> appreciated.
Ed Merks
Re: DSL Toolkit Build Problems [message #587183 is a reply to message #525212] Wed, 21 October 2009 10:53 Go to previous message
Best,
Rich
Previous Topic:examples of the book?
Next Topic:Amalgam update site for Galileo?
Current Time: Tue Apr 16 17:54:08 GMT 2024
Powered by FUDForum. Page generated in 0.18115 seconds
