Home » Modeling » Amalgam » Unable to install DSL Toolkit
Re: Unable to install DSL Toolkit [message #525188 is a reply to message #525187] |
Wed, 01 July 2009 20:58 |
Richard Gronback Messages: 605 Registered: July 2009 |
If you're following the book, you should use the Ganymede edition:
http://download.eclipse.org/modeling/amalgam/dsltk/downloads /drops/I20081128
-0606/index.php
Unfortunately, there is no 64 bit version for Linux. I have built one for
M8 based on Galileo, but it's not promoted yet.
Best,
Rich
On 7/1/09 4:54 PM, in article
dd872609a93892e1ab06a84c944419bc$1@www.eclipse.org, "Flavelle Ballem"
<fballem@ballemco.com> wrote:
> I am running Galileo and trying to follow some examples in the book,
> "eclipse Modeling Project: A Domain-Specific Language (DSL) Toolkit".
> As part of that, I'm trying to install the DSL Toolkit from the Amalgam
> project, but I get the following error:
> Cannot complete the install because one or more required items could not
> be found.
> Software being installed: DSL Toolkit 1.0.0.v200905210858
> (org.eclipse.amalgam.dsltk.product 1.0.0.v200905210858)
> Missing requirement for filter
> (&(osgi.os=linux)(osgi.ws=gtk)(osgi.arch=x86_64)): Eclipse RCP
> 3.5.0.v20090506-9SA-FwxFtqHA7O_ZPyAv-cGC (org.eclipse.rcp.feature.group
> 3.5.0.v20090506-9SA-FwxFtqHA7O_ZPyAv-cGC) requires
> 'org.eclipse.swt.gtk.linux.x86_64 [3.5.0.v3548c]' but it could not be found
> Cannot satisfy dependency:
> From: DSL Toolkit 1.0.0.v200905210858
> To: org.eclipse.platform.feature.group
> [3.5.0.v20090513-9fEdG1HFtGcZlCVLSVqmsTcdv4RgTlPeD]
> From: Eclipse Platform
> (org.eclipse.platform.feature.group
> 3.5.0.v20090513-9fEdG1HFtGcZlCVLSVqmsTcdv4RgTlPeD)
> To: org.eclipse.rcp.feature.group
> [3.5.0.v20090506-9SA-FwxFtqHA7O_ZPyAv-cGC]
> Please be aware that I am running on ubuntu 9.04 AMD64 and have eclipse
> for Linux 64-bit installed. I'm also a newbie to eclipse, so if that's
> part of the problem, then some detail on how to correct the problem would
> be much appreciated.
> Many thanks, both for the solution, and your patience!
Rich
Re: Unable to install DSL Toolkit [message #525191 is a reply to message #525189] |
Thu, 02 July 2009 10:39 |
M8 = Milestone 8
You can try the linux x86_64 download of the Modeling package from EPP:
http://www.eclipse.org/epp/download.php It contains most of what's in the
Amalgam DSL Toolkit, less some UI elements.
There are some differences in the Galileo version of the modeling
components, as compared to the Ganymede version the book is based on.
Mostly, things should work, but the solutions are not yet updated. The main
thing to do is replace references to the "legacy" Xpand model-to-text engine
with the new one in GMF that uses OCL and QVTO.
Best,
Rich
On 7/1/09 7:25 PM, in article
c52a18f8944b602a7a8b198ffbd46ea4$1@www.eclipse.org, "Flavelle Ballem"
>> -0606/index.php
>> Best,
>> Rich
> Rich:
> I'm sorry, I am new to eclipse. Could you please tell me what M8 is? Is
> there anyway that I could get a preview of the new code - happy to be the
> tester. I have found advantages to staying with the 64-bit environment for
> my applications, and I gather that 32-bit and 64-bit plugins don't mix
> well.
> Many thanks,
> Flavelle
Rich
Re: Unable to install DSL Toolkit [message #577362 is a reply to message #525187] |
-0606/index.php
Best,
Rich
> be found.
Rich
Re: Unable to install DSL Toolkit [message #577418 is a reply to message #525189] |
M8 = Milestone 8
Best,
Rich
>> -0606/index.php
>> Best,
>> Rich
> Rich:
> well.
> Many thanks,
> Flavelle
Rich
Current Time: Tue Apr 23 12:06:08 GMT 2024
Powered by FUDForum. Page generated in 0.03993 seconds
