Home » Modeling » Amalgam » Xpand file error?
Xpand file error? [message #525159] |
Thu, 04 June 2009 22:51 |
Bill Hinge Messages: 156 Registered: July 2009 |
I'm using Amalgam at the moment.
I've created a DSL project, generated model and diagram code etc.
I've also used the GMF-XPand wizard to create an xpand file in templates
If I use ctrl-space I can correctly see a list of selectable dsl's for
me to import. If I pick them I get something like <<IMPORT contract>>,
<<IMPORT uml>> etc which is what I expect. (I also have Xpand Nature
turned on by the way.) The "URI" import doesn't seem to be supported
here.
I can then build up my template as expected by using ctrl-space etc.
But when I save I get a red error flag against each import statement
despite them appearing to be working. In my dependencies I have the
following
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.emf.ecore;visibility:=reexport,
org.eclipse.emf.ecore.xmi;visibility:=reexport,
org.eclipse.uml2.uml;visibility:=reexport,
org.eclipse.xpand;bundle-version="0.7.0",
org.eclipse.xtend;bundle-version="0.7.0",
org.eclipse.xtend.typesystem.emf;bundle-version="0.7.0",
org.eclipse.emf.mwe.core;bundle-version="0.7.0"
Bundle-ActivationPolicy: lazy
Any ideas please? is this a symptom of some other error?
(DSL toolkit Build id: 20081128-0606)
Also the workflow wizard just seems to create an empty text file
with no context editing support, is this really all I should get?
regards
Steve
Re: Xpand file error? [message #525160 is a reply to message #525159] |
Fri, 05 June 2009 00:27 |
Richard Gronback Messages: 605 Registered: July 2009 |
I'm afraid the errors are "normal" for this build, using the original Xpand
(which doesn't support URI-based imports, btw). The GMF-based Xpand has
much improved the situation in the current release train.
The workflow file wizard provides no default content. As both the newer
GMF-based Xpand and QVT both support Ant invocation, there is little need
for these files when using the current release train.
Sorry for the bad news.
Best,
Rich
On 6/4/09 6:51 PM, in article h09j5b$vgt$1@build.eclipse.org, "Bill Hinge"
<steve.orobec@btopenworld.com> wrote:
> Hi
> here.
> following
> regards
> Steve
Rich
Re: Xpand file error? [message #525161 is a reply to message #525160] |
Fri, 05 June 2009 09:28 |
Rich
Not a problem, just glad to know I'm not doing anything wrong.
I'm flitting between Amalgam and Galileo to see which gives me the most
useful features, hence I'm not tied to a specific release but I like
the lightweight simplicity of Amalgam.
So I guess I should use a newer release
steve
> Best,
> Rich
>> Hi
>> here.
>> following
>> regards
>> Steve
Re: Xpand file error? [message #525162 is a reply to message #525160] |
Fri, 05 June 2009 10:55 |
Hi Rich
Just tried 1.0M7
I noticed when I imported my projects from 20081128-0606 that the
chevrons had changed to ' and a weird degree character (I'm on OS X).
This is the same if I open the file in textedit, but I can cut and paste
chevrons OK from the older dsltk.
The URL works but the older format doesn't. Also the xpand nature is no
longer there, I downloaded the examples from the welcome screen for good
measure. On both my templates and the examples, ctrl-space doesn't seem
to work. Am I missing something?
If I wish to use xpand code generation (for demo purposes - just looking
for something basic an easy at the moment that I can run from a plugin
or rcp) - what would you recommend as a build/plugin set?
regards
Steve
> Best,
> Rich
>> Hi
>> here.
>> following
>> regards
>> Steve
Re: Xpand file error? [message #525163 is a reply to message #525162] |
Fri, 05 June 2009 11:04 |
Posting here, in addition to direct email:
Try changing the encoding on the files to ISO-8859-1.
Also, you¹ll need to make sure the new builder is used. You should add this
in your .project file (remove any other xpand builder):
<buildCommand>
<name>org.eclipse.gmf.xpand.xpandBuilder</name>
<arguments>
</arguments>
</buildCommand>
Finally, the newer Xpand uses an .xpand-root file in the project directory
to point at template locations. It¹s a simple file that should only contain
a single entry for most projects, e.g. templates¹ (if there is a directory
named templates¹ in your project where you keep your xpt files).
HTH,
Rich
On 6/5/09 6:55 AM, in article 4A28F9B5.1070207@btopenworld.com, "Bill Hinge"
> Hi Rich
> Just tried 1.0M7
> regards
> Steve
>> Best,
>> Rich
>>> Hi
>>> here.
>>> following
>>> regards
>>> Steve
Rich
Re: Xpand file error? [message #525164 is a reply to message #525162] |
Fri, 05 June 2009 11:08 |
Just found the answer to one issue ;-)
I had put org.eclipse.gmf.xpand into my dependencies already.
I typed xpand into Help to see what it said, help pointed to new xpand
wizard so I ran it to create a new template and it seemed to kick start
the context help!
regards
Steve
Bill Hinge wrote:
> Hi Rich
> Just tried 1.0M7
> regards
> Steve
>> Xpand
>> Best,
>> Rich
>> Hinge"
>>> Hi
>>> here.
>>> following
>>> regards
>>> Steve
Re: Xpand file error? [message #525165 is a reply to message #525163] |
Fri, 05 June 2009 11:16 |
Another thing to point out is that the newer Xpand uses OCL/QVTO as the
expression/query language. So, you will need to correct errors you may now
see in your templates where the legacy expression language and Xtend
language was used.
- Rich
On 6/5/09 7:04 AM, in article C64E740B.22368%richard.gronback@borland.com,
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
> HTH,
> Rich
>> Hi Rich
>> Just tried 1.0M7
>> regards
>> Steve
>>> Best,
>>> Rich
>>>> Hi
>>>> here.
>>>> following
>>>> regards
>>>> Steve
Rich
Re: Xpand file error? [message #574429 is a reply to message #525159] |
Best,
Rich
> Hi
> here.
> following
> regards
> Steve
Rich
Re: Xpand file error? [message #574450 is a reply to message #525160] |
Rich
steve
> Best,
> Rich
>> Hi
>> here.
>> following
>> regards
>> Steve
Re: Xpand file error? [message #574476 is a reply to message #525160] |
Hi Rich
Just tried 1.0M7
regards
Steve
> Best,
> Rich
>> Hi
>> here.
>> following
>> regards
>> Steve
Re: Xpand file error? [message #574507 is a reply to message #525162] |
<buildCommand>
<arguments>
</arguments>
</buildCommand>
HTH,
Rich
> Hi Rich
> Just tried 1.0M7
> regards
> Steve
>> Best,
>> Rich
>>> Hi
>>> here.
>>> following
>>> regards
>>> Steve
Rich
Re: Xpand file error? [message #574529 is a reply to message #525162] |
the context help!
regards
Steve
Bill Hinge wrote:
> Hi Rich
> Just tried 1.0M7
> regards
> Steve
>> Xpand
>> Best,
>> Rich
>> Hinge"
>>> Hi
>>> here.
>>> following
>>> regards
>>> Steve
Re: Xpand file error? [message #574548 is a reply to message #525163] |
language was used.
- Rich
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
> HTH,
> Rich
>> Hi Rich
>> Just tried 1.0M7
>> regards
>> Steve
>>> Best,
>>> Rich
>>>> Hi
>>>> here.
>>>> following
>>>> regards
>>>> Steve
Rich
Current Time: Thu Apr 25 13:00:41 GMT 2024
Powered by FUDForum. Page generated in 0.04331 seconds
