Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Eclipse Form Section nesting problem(How do I nest a Form Section within a Section?)
Eclipse Form Section nesting problem [message #524656] Thu, 01 April 2010 17:07 Go to next message
Andrew Hubbs is currently offline Andrew HubbsFriend
I am trying to build a form view into an EMF model editor.
My form shows up but I cannot get a Section within a Section to show up. Is this possible/how should I be doing it?
Here is a chunk of my code where I create the Sections:
//Parameters Section
		parameterSection = toolkit.createSection(form.getBody(),
				Section.DESCRIPTION | Section.TITLE_BAR | Section.TWISTIE | Section.EXPANDED);
		clData = new ColumnLayoutData();
		parameterSection.setLayoutData(clData);
		parameterSection.addExpansionListener(new ExpansionAdapter()
				public void expansionStateChanged(ExpansionEvent e){
					form.reflow(true);
		parameterSection.setText("Parameters");
		parameterSection.setDescription("Edit the function's parameters in this section");
		parameterSecClient = toolkit.createComposite(parameterSection);
		parameterSecClient.setLayoutData(new GridData());
		standardParametersSection = toolkit.createSection(parameterSecClient, Section.TITLE_BAR | Section.EXPANDED);
		standardParametersSection.setText("Standard Parameters");
		standardParametersSection.setLayoutData(clData);
		standardParametersSection.addExpansionListener(new ExpansionAdapter()
					form.reflow(true);
		sParamTable = toolkit.createTable(standardParametersSection, SWT.SINGLE);
		sParamTable.setHeaderVisible(true);
		sParamTable.setData(FormToolkit.KEY_DRAW_BORDER, FormToolkit.TEXT_BORDER);
		String tableLabels[] = {"Name", "Value"};
		TableColumn sParamColumns[] = new TableColumn[tableLabels.length];
		for(int i=0; i<tableLabels.length; i++){
			sParamColumns[i] = new TableColumn(sParamTable, SWT.NULL);
			sParamColumns[i].setText(tableLabels[i]);
			sParamColumns[i].pack();
			sParamColumns[i].setWidth(100);
		sParamTable.setLayoutData(new GridData());
		Composite sParamButtonComp = toolkit.createComposite(standardParametersSection);
		sParamButtonComp.setLayout(new GridLayout(2, false));
		Button sParamButtons[] = new Button[2];
		sParamButtons[0] = toolkit.createButton(sParamButtonComp, "Add Parameter", SWT.PUSH | SWT.CENTER);
		sParamButtons[0].addSelectionListener(new SelectionAdapter() {
			public void widgetSelected(SelectionEvent e) {
				System.out.println("Add");
		sParamButtons[1] = toolkit.createButton(sParamButtonComp, "Delete Parameter", SWT.PUSH | SWT.CENTER);
		sParamButtons[1].addSelectionListener(new SelectionAdapter() {
				System.out.println("Delete");
		sParamButtonComp.update();
		calculatedParametersSection = toolkit.createSection(parameterSecClient, Section.TITLE_BAR | Section.EXPANDED);
		calculatedParametersSection.setText("Calculated Parameters");
		calculatedParametersSection.setLayoutData(clData);
		calculatedParametersSection.addExpansionListener(new ExpansionAdapter()
				form.reflow(true);
			//create table
		sParamTable = toolkit.createTable(calculatedParametersSection, SWT.SINGLE);
			//create columns
		TableColumn cParamColumns[] = new TableColumn[tableLabels.length];
			cParamColumns[i] = new TableColumn(sParamTable, SWT.NULL);
			cParamColumns[i].setText(tableLabels[i]);
			cParamColumns[i].pack();
			cParamColumns[i].setWidth(100);
		parameterSection.setClient(parameterSecClient);
What I have tried to do is this: Create a section, Place a composite within that section that then has two sections next to each other that each have a table and some buttons within them.
Thanks for any suggestions about why I am only getting one empty Section to show up.
Re: Eclipse Form Section nesting problem [message #525432 is a reply to message #524656] Tue, 06 April 2010 14:45 Go to previous messageGo to next message
Grant Gayed is currently offline Grant GayedFriend
You should ask this on the eclipse.platform.ua newsgroup since this is where
the Forms classes come from.
Grant
<andrew.hubbs@siemens.com> wrote in message
news:hp2jtc$4cf$1@build.eclipse.org...
Section.EXPANDED);
> form.reflow(true);
section");
> form.reflow(true);
> form.reflow(true);
> //create table
SWT.SINGLE);
> //create columns
to show up.
Re: Eclipse Form Section nesting problem [message #527301 is a reply to message #525432] Wed, 14 April 2010 17:53 Go to previous message
Thank you for directing me to the correct location.
For those interested this problem was a result of not setting the Layout correctly for several of my composites.
Andrew
Andrew Hubbs
Previous Topic:Embedded Mozilla, Cookies
Next Topic:StyledText in SWT Table
Current Time: Thu Oct 01 14:02:36 GMT 2020
Powered by FUDForum. Page generated in 0.02331 seconds
