Home » Archived » Buckminster » plugin jar dependencies
plugin jar dependencies [message #524378] Wed, 31 March 2010 17:37 Go to next message
Alex Kravets is currently offline Alex KravetsFriend
I have a plugin that depends on certain jars, in current build these jars are copied over from svn location. How can I copy these jars to my plugin during materialization?
thanks,
Alex
Re: plugin jar dependencies [message #524383 is a reply to message #524378] Wed, 31 March 2010 18:02 Go to previous messageGo to next message
Johannes Utzig is currently offline Johannes UtzigFriend
Alex schrieb:
> thanks,
> Alex
Hi Alex,
I have similar requirements for some of my plugins. What I am doing is this:
1. I create a cspex in the bundle
2. all extra jars are written in the cspex as additional dependencies
3. next I define a buckminster.prebind action (with an ant actor) that
takes these extra dependencies as prerequisites.
4. The ant actor simply copies a buckminster fileset (initialized from
the prerequisites property) to a certain location in the bundle. see
http://wiki.eclipse.org/Ant_actor_API_(Buckminster)
The name of the action buckminster.prebind has the effect that this
actor will be executed before the project is bound to the workspace
(i.e. during materialisation).
The nice thing about this approach is that your ant script does not need
to know which jars need to be copied because the files get 'injected'
into the ant script.
If you're interested I can post an example tomorrow.
Johannes
Re: plugin jar dependencies [message #524397 is a reply to message #524383] Wed, 31 March 2010 19:16 Go to previous messageGo to next message
Thanks Johannes,
Yes, if you could post an example that would be very helpful and appreciated.
Alex
Re: plugin jar dependencies [message #524488 is a reply to message #524397] Thu, 01 April 2010 02:24 Go to previous messageGo to next message
Hi Alex,
as promised, here the example.
This is how the cspex in my bundle looks like:
<cspecExtension
xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
xmlns="http://www.eclipse.org/buckminster/CSpec-1.0"
xmlns:cs="http://www.eclipse.org/buckminster/CSpec-1.0">
<dependencies>
<!-- here we declare some extra dependencies to jar files,
osgi.bundles, maven components, or whatever -->
<dependency name="org.eclipse.equinox.common"
componentType="osgi.bundle"/>
<dependency name="com.google.guice" componentType="osgi.bundle"/>
</dependencies>
<actions>
<!-- one public action with an ant actor to do the actual copying -->
<cs:public name="fetch.dependency.jars" actor="ant">
<cs:actorProperties>
<cs:property key="buildFile" value="build/copyJars.xml"/>
<cs:property key="targets" value="copy"/>
</cs:actorProperties>
<cs:prerequisites alias="copyJars.prerequisites">
<cs:attribute name="java.binaries" component="com.google.guice"/>
<cs:attribute name="bundle.jar"
component="org.eclipse.equinox.common"/>
</actions>
<groups>
<!-- the prebind group will be executed during materialization -->
<cs:private name="buckminster.prebind" >
<cs:attribute name="fetch.dependency.jars"
alias="action.requirements"/>
</cs:private>
</groups>
</cspecExtension>
And finally the ant script:
<project name="Blubb" basedir=".." default="copy">
<target name="copy">
<buckminster.copy todir="lib">
<!-- fs:copyJars.prerequisites contains all the stuff declared in
the cspex -->
<buckminster.filesetgroup value="${fs:copyJars.prerequisites}" >
</buckminster.filesetgroup>
</buckminster.copy>
</target>
</project>
Hope that helps.
Johannes
Re: plugin jar dependencies [message #524665 is a reply to message #524488] Thu, 01 April 2010 18:14 Go to previous messageGo to next message
Thank you very much Johannes, I'll try this!
Re: plugin jar dependencies [message #524793 is a reply to message #524378] Fri, 02 April 2010 14:31 Go to previous messageGo to next message
Hi Johannes,
I have couple of questions about the snippet.
<dependency name="org.eclipse.equinox.common" componentType="osgi.bundle"/>
<cs:attribute name="bundle.jar" component="org.eclipse.equinox.common"/>
Does this mean that org.eclipse.equinox.common has some dependencies, and later on they are listed in prerequisites element?
From the ant script that is being called by fetch.dependency.jars, I don't see where it is specified where these jars are being copied from?
Lastly, if I am not mistaken the fetching will happen during the build when all appropriate actions are called. What if I want the fetching happen when materialization happens in IDE into my workspace?
thanks,
Alex
Re: plugin jar dependencies [message #524798 is a reply to message #524793] Fri, 02 April 2010 14:56 Go to previous messageGo to next message
Hi Alex,
please see comments inline.
Alex schrieb:
> Hi Johannes,
No, it was just an example of an extra dependency of your bundle. You
can replace org.eclipse.equinox.common with foo.jar if you want.
That's the good part: The ant script doesn't need to know. Everything
you stated as prerequisite of the 'fetch.dependency.jars action (or
however you would like to call it) will be copied by that script.
In the example I declared a public action fetch.dependency.jars and
defined a group buckminster.prebind that contains the action.
buckminster.prebind will be automatically executed when the
materialization occurs, so this is exactly the behaviour you describe.
You resolve your query/mspec, and before buckminster binds your material
to the workspace it will execute the fetch.dependency.jars action and
copy the jars you stated as prerequistes to a folder inside the bundle
(lib in the given example)
Johannes
Re: plugin jar dependencies [message #524801 is a reply to message #524798] Fri, 02 April 2010 15:14 Go to previous messageGo to next message
Thanks Johannes,
More questions...
Sorry for my lack of understanding this. But where will it copy jars from? In my case the jars that are dependencies are located in a svn folder, so I need to tell script to get jars from there, no? Or, does RMAP needs to be the source of location of these jars?
thanks,
Alex
[Updated on: Fri, 02 April 2010 15:20]
Report message to a moderator
Re: plugin jar dependencies [message #524817 is a reply to message #524801] Fri, 02 April 2010 17:33 Go to previous messageGo to next message
You need to make sure that they are reachable through your resource map,
that way Buckminster will fetch them like any other component during the
resolution.
Re: plugin jar dependencies [message #524819 is a reply to message #524817] Fri, 02 April 2010 17:53 Go to previous messageGo to next message
Aha, that's what I though. Thank you!
Re: plugin jar dependencies [message #525046 is a reply to message #524819] Mon, 05 April 2010 14:50 Go to previous messageGo to next message
Hi Johannes,
I am still struggling to make this work. During materialization phase all my bundles make it into workspace but then I get this error:
ERROR [0001] : CSpec com.iwaysoftware.eclipse.common:osgi.bundle$0.1.0.qualifier has no action, group, or local artifact named iwaf.jar
TAG-ID 0001 = Query for com.iwaysoftware.integration.tools.site:eclipse.feature
Here are my files:
thanks,
Alex
Re: plugin jar dependencies [message #525059 is a reply to message #525046] Mon, 05 April 2010 11:18 Go to previous messageGo to next message
Hi Alex,
you state in your cspex that your action depends on the
action/group/artifact iwaf.jar of the component
com.iwaysoftware.eclipse.common. Does com.iwaysoftware.eclipse.common
declare an action, artifact or group of that name and if so, is it public?
Do you have a cspex for com.iwaysoftware.eclipse.common? If so, how does
it look like?
If not, then you have only the standard attributes available that have
been discovered by buckminster. For OSGi Bundles these are things like
bundle.jar, java.binaries and so on.
Do I get it right that com.iwaysoftware.eclipse.common contains a jar
called 'iwaf.jar' that you want access to? If that's correct, than you
need to create a cspex for com.iwaysoftware.eclipse.common and declare
it as a public artifact.
Johannes
Re: plugin jar dependencies [message #525112 is a reply to message #525059] Mon, 05 April 2010 18:49 Go to previous messageGo to next message
Thanks Johannes,
I created buckminster.cspex in common plugin that looks like this:
<cspecExtension
xmlns="http://www.eclipse.org/buckminster/CSpec-1.0">
<artifacts>
<public name="iwaf.jar"/>
</artifacts>
</cspecExtension>
During materialization I see in console fetch.dependecy.jars being executed, however nothing is being copied to the common bundle, what happens was that common bundle was copied to my materialization bundle - so I did something really wrong here.
I am declaring cspex in common bundle that lists all artifacts that this bundle expects, in cspex of my materialization bundle in action fetch.dependecies.jars I list attributes to copyJars.prerequsites (http://pastebin.com/BJcuV01A). Will these attributes become exactly what's in common's cspex? Or did I miss something?
Appreciate your help,
Alex
[Updated on: Mon, 05 April 2010 18:53]
Re: plugin jar dependencies [message #525250 is a reply to message #525112] Mon, 05 April 2010 20:16 Go to previous messageGo to next message
Johannes,
I am trying different things here what I noticed, during materialization I see this in console:
Actions to perform (in order)
com.iwaysoftware.eclipse.common:osgi.bundle$0.1.0.qualifier# manifest
com.iwaysoftware.logging:osgi.bundle$0.1.0.qualifier#eclipse .build
com.iwaysoftware.eclipse.common:osgi.bundle$0.1.0.qualifier# eclipse.build
com.iwaysoftware.eclipse.common:osgi.bundle$0.1.0.qualifier# create.eclipse-common.jar
com.iwaysoftware.eclipse.common:osgi.bundle$0.1.0.qualifier# bundle.jar
com.iwaysoftware.integration.tools.site:eclipse.feature$1.0. 0.qualifier#fetch.dependency.jars
I would think that fetch.dependency.jars would be one of the first things to be done, no?
thanks,
Alex
Re: plugin jar dependencies [message #525255 is a reply to message #525112] Mon, 05 April 2010 16:42 Go to previous messageGo to next message
Hi Alex,
Looks like your iwaf.jar Artifact has just a name, no associated path.
Johannes
Re: plugin jar dependencies [message #525257 is a reply to message #525255] Mon, 05 April 2010 20:54 Go to previous messageGo to next message
Thanks Johannes,
What should the path represent though? Can you give an example perhaps of what it should look like?
In the book it seems that paths are optional that's why I thought they are not needed here.
Alex
[Updated on: Mon, 05 April 2010 20:55]
Re: plugin jar dependencies [message #525265 is a reply to message #525257] Mon, 05 April 2010 22:07 Go to previous messageGo to next message
Hi Johannes,
Thanks for your help, everything works!
thanks,
Alex
Re: plugin jar dependencies [message #540376 is a reply to message #525265] Tue, 15 June 2010 21:29 Go to previous messageGo to next message
I was preoccupied with other projects and now came back to buckminster build. What I thought was working does not, so I have some more questions about dependencies.
When I materialize my cquery the jars are being materialized into workspace and obviously this is wrong, I expect buckminster.prebind to execute but it does not. My questions are:
1.Does the common plugin, to which jars to be copied need its own cquery and rmap, or this only needed by my feature plugin that checks out common plugin?
2. I created a cspex for the common plugin http://pastebin.com/X5LyeHnF, but is it really needed because MANIFEST.MF for the plugin contains this information Bundle-ClassPath directive and it seems generated CSpec already has this information?
3.Is buckminster.prebind part of the common plugin and executed before this bundle is materialized or should it be part of the feature plugin and is called before common is made into workspace?
thanks for your help,
Alex
Re: plugin jar dependencies [message #540420 is a reply to message #540376] Wed, 16 June 2010 06:21 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
On 06/15/2010 11:29 PM, Alex wrote:
> Hello,
> common plugin?
No.
The dependencies expressed in the bundle manifest does not need to be listed. Buckminster will handle them automatically.
The cspec extension does not contain a prebind declaration so I'm a bit confused here. What is it that you expect to get
executed?
Please note that you will not need to do anything at all in order to get a normal OSGi setup to build where all
dependencies are expressed as bundle requirements in the manifests. All of that should work out of the box. The prebind
action is normally used when you need to copy non-OSGi jars into a bundle to form a nested jar. Turning all jars into
bundles is the preferred approach.
HTH,
- thomas
Re: plugin jar dependencies [message #540573 is a reply to message #540420] Wed, 16 June 2010 14:39 Go to previous messageGo to next message
Thanks Thomas,
This is what I am trying to accomplish. I have a common plugin that is used by other plugins for common functionality, this plugin has some jars that it exports packages from for use by other plugins. In the current build I just copy these jars from svn to the plugin so I was looking for a way to do this in buckminster.
From what Johannes helped me with I was trying to accomplish this but I don't think I understand the whole process correctly.
The prebind action is normally used when you need to copy non-OSGi jars into a bundle to form a nested jar.
My jars are exactly that - non-OSGi jars such as axis.jar, commons-logging-1.1.1.jar, etc. So then prebind is what I need in my case? But if
Then where and how is it used? I thought that using prebind action will be executed before bundles make it into workspace, but since this is an action it is not called during 'Resolve and Materialize' step which I thought was when jars would be copied into the common plugin.
Turning all jars into bundles is the preferred approach.
Do you mean each jar should be a separate bundle?
May be I did explain my requirements correctly the first time, so perhaps you can suggest a solution for this?
thanks,
Alex
[Updated on: Wed, 16 June 2010 14:58]
Re: plugin jar dependencies [message #540596 is a reply to message #540573] Wed, 16 June 2010 15:40 Go to previous messageGo to next message
Hi Alex
> case? But if
> Quote:
I think you misunderstand. A CSPEX CAN contain an action/group called
buckminster.prebind and this action will be executed before the bundle
is bound to the workspace. Your CSPEX (http://pastebin.com/X5LyeHnF)
however, does NOT contain such action/group and hence, NO action is
executed before the bundle is bound to the workspace. So far all you do
is state some extra dependencies, but what's missing is the declariation
of a prebind action that will actually do something (like copy those
dependencies into your bundle).
Specificily what's missing in your CSPEX is the rest of the example I
posted earlier:
<actions>
copying -->
<!--insert all the extra jars you need here -->
<cs:attribute name="java.binaries" component="com.google.collect"/>
</actions>
<groups>
</cs:private>
</groups>
And the matching ant script:
<project name="BuckminstersLittleHelperAntScript" basedir=".."
default="copy">
declared in the cspex -->
</buckminster.copy>
</target>
</project>
> Quote:
Yes, that is usually the prefered approach in an OSGi environment. All
jars are OSGi bundles. There's also some repositories available that
offer OSGiified versions of many common java libs. Eclipse Orbit is one
of them:
http://download.eclipse.org/tools/orbit/downloads/drops/R201 00519200754/
Springsource offers another:
http://www.springsource.com/repository/app/
However, if for whatever reason you do not want to or cannot turn your
jars into OSGi bundles, then I'd suggest you go with the prebind action
as seen above.
Johannes
Re: plugin jar dependencies [message #540597 is a reply to message #540573] Wed, 16 June 2010 15:42 Go to previous messageGo to next message
On 06/16/2010 04:39 PM, Alex wrote:
> Quote:
When Buckminster is materializing (i.e. copying things to your local harddrive) and before the material is bound to the
workspace as a project (hence the name prebind).
Buckminster checks if the component has an action named prebind. If it has, it is executed.
Here's a sample from our demo application:
http://dev.eclipse.org/svnroot/tools/org.eclipse.buckminster /trunk/org.eclipse.buckminster/demo/org.demo.xml.provider/bu ckminster.cspex
> Quote:
Yes. And many of the jars that you want are already published in OSGi form by the Eclipse Orbit project. Have a look at:
You can point the Orbit p2 repository directly using a Buckminster p2 reader type. The URL to use for that is:
http://download.eclipse.org/tools/orbit/downloads/drops/R201 00519200754/repository
HTH,
- thomas
Re: plugin jar dependencies [message #540608 is a reply to message #540596] Wed, 16 June 2010 16:49 Go to previous messageGo to next message
Thanks Thomas, Johannes,
Ok, this is clear now. However, there is still something I don't understand. If my common plugin contains CSPEX with prebind action, where do I specify how to get these jars from svn? If I add a provider that points to location of the jars then during materialization these jars are being materialized into workspace which throws errors.
thanks,
Alex
Re: plugin jar dependencies [message #540616 is a reply to message #540597] Wed, 16 June 2010 17:38 Go to previous messageGo to next message
Sorry, meant to reply here
Ok, this is clear now. However, there is still something I don't understand. If my common plugin contains CSPEX with prebind action, where do I specify how to get these jars from svn? If I add a provider that points to location of the jars then during materialization these jars are being materialized into workspace which throws errors that jar is a file and not a directory.
If I take approach that you suggested of bundling up jar in the plugin, I get these errors during materialization:
mail.jar:jar: Using resolver Local resolver
iwaeutil.jar:jar: Using resolver Local resolver
axis2-kernel-1.4.jar:jar: Trying provider svn({0}/dependencies/trunk/{1})
iwconfigsm.jar:jar: Using resolver Local resolver
iwresource.jar:jar: Using resolver Local resolver
Errors and Warnings
E [0000] : No suitable provider for component geronimo-stax-api_1.0_spec-1.0.1.jar:jar was found in resourceMap file:/home/akravets2/dev/workspaces/pluto.build/com.iwaysoftware.integration.tools.site/site.svn.rmap
E   [0000] : No suitable provider for component geronimo-stax-api_1.0_spec-1.0.1.jar:jar was found in searchPath resources
E     [0000] : Rejecting provider svn({0}/dependencies/trunk/{1}): Components of type jar are not supported
E     [0000] : Rejecting provider svn({0}/iIT/trunk/features/{1}): Components of type jar are not supported
E     [0000] : Rejecting provider svn({0}/iIT/trunk/plugins/{1}): Components of type jar are not supported
E     [0000] : Rejecting provider svn({0}/Explorer/trunk/plugins/{1}): Components of type jar are not supported
commons-codec-1.3.jar:jar: Trying provider svn({0}/dependencies/trunk/{1})
j2ee.jar:jar: Using search path resources
axis2-kernel-1.4.jar:jar: Rejecting provider svn({0}/dependencies/trunk/{1}): Components of type jar are not supported
axis2-kernel-1.4.jar:jar: Trying provider svn({0}/iIT/trunk/features/{1})
Does line "mail.jar:jar: Using resolver Local resolver" mean that jar was located correctly?
thanks,
Alex
[Updated on: Wed, 16 June 2010 19:03]
Re: plugin jar dependencies [message #540647 is a reply to message #540616] Wed, 16 June 2010 20:08 Go to previous message
Hi Alex,
The cspex contains an additional dependency to the jar. During import, the resolver will make an attempt to resolve this
dependency which means that it will consult your rmap in order to find it. Your rmap must contain a provider that is
capable of finding and materializing the jar. I.e. this component is treated just like any other component would.
- thomas
> thanks,
> Alex
Previous Topic:How to do a platform agnostic build
Next Topic:How to use buckminster.lastTimestamp?
Current Time: Sat Sep 25 04:03:12 GMT 2021
Powered by FUDForum. Page generated in 0.03248 seconds
