"Install New Software...." fails when "osgi.configuration.area" is set in config [message #524302] |
Wed, 31 March 2010 13:25 |
Giuseppe Montalto Messages: 18 Registered: July 2009 |
Hi all!
I'm developing a fully branded product on top of Eclipse 3.5.1 and CDT, both adding some new plugins and modifying some of the existing ones.
the problem I am facing is quite weird:
when "osgi.configuration.area" is set in the config.ini file, if I run my product and try to install any third-party feature using the "Install New Software...." wizard, the installation pretends to be successful but the features I installed don't actually work.
everything works fine if I delete the above mentioned "osgi.configuration.area" key!
I've made several attempts, using different features from different update sites and the behavior is always the same.
a little more info can be found in this post:
http:// www.eclipse.org/forums/index.php?t=msg&&th=37595& ;goto=519158#msg_524295,
feel free to ask for further details.
Any hint on what to check?
thanks in advance.
Giuseppe.
FUDForum. Page generated in 0.03115 seconds
