Home » Eclipse Projects » Eclipse Platform » Trying to execute the disabled command
Trying to execute the disabled command [message #524221] Wed, 31 March 2010 04:34 Go to next message
Hi All,
I am using keyboard shortcuts in my appliocation.
I am providing handlers for the paste action.
For some reason the paste does not work initially but after doing some other operations it works.
I enabled the tracing in the debug config and found the command is not enabled and hence the NotEnabledException.
I am creating the action in my code.
Then assigning the action handler to the action bar of the UI and then regirstering the action with the KeyBindingService.
I know KeyBindingService way is not the preffered way to go ahead.But that code i can not change much.
Below is the error i am getting in the console
COMMANDS >>> execute >>> not enabled: id=org.eclipse.ui.edit.paste; exception=org.eclipse.core.commands.NotEnabledException: Trying to execute the disabled command org.eclipse.ui.edit.paste
Any help would be hugely appreciated.
Thanks and Regards,
Saurav
[Updated on: Wed, 31 March 2010 04:35] by Moderator
Re: Trying to execute the disabled command [message #524335 is a reply to message #524221] Wed, 31 March 2010 10:42 Go to previous messageGo to next message
You're mixing actions and commands and a deprecated service ... all bets
are off.
Are you in a view? Then in your createPartControl(*) you can do
something like:
getViewSite().getActionBars().setGlobalActionHandler(ActionF actory.PASTE.getId(),
myPasteAction);
If you are dealing with actions, that's enough to provide your paste
action to the system. You don't have to deal with the IKeyBindingService.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Trying to execute the disabled command [message #524469 is a reply to message #524221] Thu, 01 April 2010 01:53 Go to previous message
Thanks Paul for the reply.
I could find out the solution to the problem.The problem was there in the logic of the enablement of my action.I corrected that one and it works now.
cheers,
Saurav
Previous Topic:How to extend eclipse code analysis strategy?
Next Topic:Cannot open input element
Current Time: Sat Apr 26 18:25:57 EDT 2025
Powered by FUDForum. Page generated in 0.03900 seconds
