Home » Modeling » Epsilon » Possible bug in ETL/Emfatic?
Possible bug in ETL/Emfatic? [message #524031] |
Tue, 30 March 2010 12:12 |
Originally posted by: c.k.holmes.lboro.ac.uk
This may not be a bug at all and, rather, a lack of understanding on my
part; however ...
If we have a directory structure of the following form:
MyProject
Parent (directory)
parent.ecore
parent.emf
Child (directory)
child.ecore
child.emf
Each Emfatic file defines a namespace commensurate with its location in
the directory hierarchy:
parent
parent.child
And each defines its own package and imports the namespace directly
above it:
parent (doesn't import anything)
child (imports parent)
If package Parent defines a class Thing and package Child extends this
class as (say) AnotherThing then I can run a transformation
(MyTransformation) using Ant to provide a reference to package Child and
access the types Thing and AnotherThing via (e.g.)
Target!Thing
and
Target!AnotherThing
However, if package Child is empty or does not extend any of the classes
provided in package Parent, say Child now introduces the class Strange,
then using the same approach as above I find that:
Target!Strange is resolved correctly, but
Target!Thing can no longer be found.
Is this behaviour to be expected?
Chris
Re: Possible bug in ETL/Emfatic? [message #524034 is a reply to message #524031] |
Tue, 30 March 2010 12:21 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Chris,
This is the expected behaviour. The Emfatic "import" statement is just a
convenience mechanism so that you don't have to refer to external
EClasses using fully-qualified names (i.e. including namespace URI). If
you don't use (reference, extend) any EClasses from the imported
(parent) metamodel, then when you do the Emfatic->Ecore transformation
on the child metamodel, the "import" is not mapped to anything.
A solution for this would be to allow Epsilon to load a model using a
number of (instead of just one) unrelated metamodel URIs. This is
something we've been pondering as a feature for some time now but didn't
have a case study for. As a workaround you can use a third metamodel
which imports and somehow references classes from both the parent and
the child metamodels (even in abstract non-instantiable classes) and use
this to load your models.
Dimitris
Chris Holmes wrote:
> part; however ...
> MyProject
> Parent (directory)
> parent.ecore
> parent.emf
> Child (directory)
> child.ecore
> child.emf
> parent
> parent.child
> above it:
> Target!Thing
> and
> Target!AnotherThing
> Regards
> Chris
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Possible bug in ETL/Emfatic? [message #524043 is a reply to message #524034] |
Tue, 30 March 2010 08:06 |
Hi Dimitris,
OK, thanks for clarifying for me.
It occurred to me that I could have made Child a child package of Parent
such that Child should be able to the Parent's parts (I could do this
with XMF), however I don't know the syntax for either Emfatic or eCore
(I spent a while searching the web, but didn't find anything useful). Do
you know if this is possible, and, if so, could you provide an example
of the syntax?
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> my part; however ...
>> MyProject
>> Parent (directory)
>> parent.ecore
>> parent.emf
>> Child (directory)
>> child.ecore
>> child.emf
>> in the directory hierarchy:
>> parent
>> parent.child
>> above it:
>> and access the types Thing and AnotherThing via (e.g.)
>> Target!Thing
>> and
>> Target!AnotherThing
>> classes provided in package Parent, say Child now introduces the class
>> Strange, then using the same approach as above I find that:
>> Regards
>> Chris
Re: Possible bug in ETL/Emfatic? [message #524044 is a reply to message #524043] |
Hi Chris,
Section 1.2 of http://www.eclipse.org/gmt/epsilon/doc/articles/emfatic/
provides examples for defining sub-packages in Emfatic. (this is a
relatively new article so Google may not have picked it up yet)
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> of the syntax?
> Best Wishes
> Chris
>> Hi Chris,
>> a convenience mechanism so that you don't have to refer to external
>> If you don't use (reference, extend) any EClasses from the imported
>> didn't have a case study for. As a workaround you can use a third
>> metamodel which imports and somehow references classes from both the
>> parent and the child metamodels (even in abstract non-instantiable
>> classes) and use this to load your models.
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi,
>>> MyProject
>>> Parent (directory)
>>> parent.ecore
>>> parent.emf
>>> Child (directory)
>>> child.ecore
>>> child.emf
>>> parent
>>> parent.child
>>> above it:
>>> this class as (say) AnotherThing then I can run a transformation
>>> Target!Thing
>>> and
>>> Target!AnotherThing
>>> class Strange, then using the same approach as above I find that:
>>> Regards
>>> Chris
Re: Possible bug in ETL/Emfatic? [message #588006 is a reply to message #524031] |
Hi Chris,
Dimitris
Chris Holmes wrote:
> part; however ...
> MyProject
> Parent (directory)
> parent.ecore
> parent.emf
> Child (directory)
> child.ecore
> child.emf
> parent
> parent.child
> above it:
> Target!Thing
> and
> Target!AnotherThing
> Regards
> Chris
Re: Possible bug in ETL/Emfatic? [message #588018 is a reply to message #524034] |
Tue, 30 March 2010 12:45 |
Hi Dimitris,
of the syntax?
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> MyProject
>> Parent (directory)
>> parent.ecore
>> parent.emf
>> Child (directory)
>> child.ecore
>> child.emf
>> parent
>> parent.child
>> above it:
>> Target!Thing
>> and
>> Target!AnotherThing
>> Regards
>> Chris
Re: Possible bug in ETL/Emfatic? [message #588024 is a reply to message #588018] |
Tue, 30 March 2010 12:59 |
Hi Chris,
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> of the syntax?
> Best Wishes
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi,
>>> MyProject
>>> Parent (directory)
>>> parent.ecore
>>> parent.emf
>>> Child (directory)
>>> child.ecore
>>> child.emf
>>> parent
>>> parent.child
>>> above it:
>>> Target!Thing
>>> and
>>> Target!AnotherThing
>>> Regards
>>> Chris
Current Time: Sat Apr 20 15:06:41 GMT 2024
Powered by FUDForum. Page generated in 0.03326 seconds
