Home » Modeling » GMF (Graphical Modeling Framework) » Diagram Partitioning
Diagram Partitioning [message #523477] Fri, 26 March 2010 11:12 Go to next message
i have problems with the feature "double-click to open a new Diagram Instance"
My model looks like this.
Document Root
-RootState
- -State
- - - Substate
- - - - Events
- - - - Actions
- - - - etc.
I created a GMF editor with RootState as root for the Canvas.
Substate is an affixed Child on State. If a double-click on Substate is received, a new Diagram Window should open with SubState as Root!
I tried this http://wiki.eclipse.org/Diagram_Partitioning example.
First i did everything as described in Usecase 1 "same type". When I double-clicked on a Substate, nothing happend.
Then I tried the Usecase 2 "different type" example.
I created a second GMFGraph, Tool, Map and GMFGen File for the Substate.
I created the source for my second editor and changed everything as explained in the example.
But still nothing happend.
I debugged the code and figured out that the
Diagram intializeNewDiagram()
function throws an exception because the value d on:
Diagram d = ViewService.createDiagram(getDiagramDomainElement(),getDiagramKind(), getPreferencesHint());
is null !
Has anyone an idea ?
Re: Diagram Partitioning [message #523541 is a reply to message #523477] Fri, 26 March 2010 14:11 Go to previous messageGo to next message
I solved the problem.
I have just used the Canvas from the main GMFGraph in the GMFMap instead of creating a new GMFGraph with a new Canvas!
Re: Diagram Partitioning [message #536079 is a reply to message #523541] Wed, 26 May 2010 17:45 Go to previous messageGo to next message
Hello, I have got the same problem, and I don't understand your solution. Can you describe it better, please?
Re: Diagram Partitioning [message #536160 is a reply to message #536079] Thu, 27 May 2010 05:41 Go to previous messageGo to next message
i try it.
The Main Element in your *.gmfgraph is a "Canvas" Element.
Now, when you create a NEW *.gmfmap you have to fill the Attribute "Diagram Canvas" in the Element "Canvas Mapping" with THIS "Canvas" Element .
The Palette can be a new one.
So, in my case, it works only if i use only ONE *.gmfgraph.
I hope this is understandable and helps you.
Re: Diagram Partitioning [message #536474 is a reply to message #536160] Fri, 28 May 2010 08:28 Go to previous message
Thx for help!
I did so, but my problem was an other.
In my model definition I did a generalization from my Node to my Diagram-Klass instead of a spezialisation.
Thx
Alexej
Previous Topic:Propsheet customization
Next Topic:Drop shadow border
Current Time: Fri Apr 25 03:05:50 EDT 2025
Powered by FUDForum. Page generated in 0.05929 seconds
