Home » Eclipse Projects » Eclipse 4 » XWT: Preview & Run-time views are different
XWT: Preview & Run-time views are different [message #523100] Thu, 25 March 2010 05:25 Go to next message
can kayacan is currently offline can kayacanFriend
I have simple UI element, which has two button and a text widgets. The XWT designer and the Preview shows the button and text size as I expected. But the run-time widget sizes are not shown as I defined. The default widget size is being shown instead.
Anyone has any idea, what is the correct way to define the widget width and height?
Demo.xwt
<Composite xmlns="http://www.eclipse.org/xwt/presentation"
xmlns:x="http://www.eclipse.org/xwt" xmlns:c="clr-namespace:demo.xwt"
xmlns:j="clr-namespace:java.lang" x:Class="demo.xwt.Demo">
<Composite.layout>
<GridLayout numColumns="1" />
</Composite.layout>
<Text x:style="SWT.NONE" weight="400" height="150" />
<Button x:style="SWT.PUSH" x:Name="NotifyButton1" text="Notify" width="200" Height="50" />
<Button x:style="SWT.PUSH" x:Name="NotifyButton2" text="Notify" width="200" Height="50" />
</Composite>
Demo.java
public class Demo extends Composite {
public Demo(Composite parent, int style) {
super(parent, style);
Simple main method:
URL content = Demo.class.getResource("Demo.xwt");
try {
XWT.open(content);
} catch (Exception e) {
e.printStackTrace();
[Updated on: Thu, 25 March 2010 05:28]
Report message to a moderator
Re: XWT: Preview & Run-time views are different [message #523158 is a reply to message #523100] Thu, 25 March 2010 11:56 Go to previous messageGo to next message
Konstantin Scheglov is currently offline Konstantin ScheglovFriend
You should use GridData for GridLayout instead of specifying size directly.
In general Layout manages location and size, so your width/height are overridden.
You want something like this
<Composite xmlns="http://www.eclipse.org/xwt/presentation" xmlns:x="http://www.eclipse.org/xwt">
	<Composite.layout>
		<GridLayout numColumns="1"/>
	</Composite.layout>
	<Text x:Style="BORDER">
		<Text.layoutData>
			<GridData grabExcessHorizontalSpace="true" horizontalAlignment="FILL" heightHint="150"/>
		</Text.layoutData>
	</Text>
	<Button x:Name="NotifyButton1" text="Notify">
		<Button.layoutData>
			<GridData widthHint="200" heightHint="50"/>
		</Button.layoutData>
	</Button>
	<Button x:Name="NotifyButton2" text="Notify">
		<Button.layoutData>
			<GridData heightHint="50" widthHint="200"/>
	</Button>
</Composite>
http://dl.dropbox.com/u/76691/Eclipse/images/Screenshot%20-%2025.03.2010%20%2C%2014_53_21.png
Konstantin Scheglov,
Google, Inc.
Re: XWT: Preview & Run-time views are different [message #523301 is a reply to message #523158] Thu, 25 March 2010 20:21 Go to previous messageGo to next message
Thank you so much again, Konstantin. This was very helpful.
Re: Preview & Run-time views are different [message #525879 is a reply to message #523100] Thu, 08 April 2010 07:16 Go to previous messageGo to next message
Yves YANG is currently offline Yves YANGFriend
How do you set the width and height, via XWT Visual Designer? If so, it
could be a bug of the tool and please report a bug.
Yves
"can kayacan" <kayacanc@hotmail.com> wrote in message
news:hoes53$hh2$1@build.eclipse.org...
> designer and the Preview shows the button and text size (width and
> height) as I expected. But the run-time widget sizes are not shown as I
> defined. The default widget size is being shown.
> and height?
> Demo.xwt
> <Composite.layout>
> <GridLayout numColumns="2" />
> </Composite.layout>
> </Composite>
> Demo.java
> Simple main method: public static void main(String[] args) {
> try {
> XWT.open(content);
Re: Preview & Run-time views are different [message #526125 is a reply to message #525879] Thu, 08 April 2010 19:09 Go to previous messageGo to next message
Hi Yang,
I did not use Visual Designer, intellisense shows the "width" and "height".
I checked the designer, the width and height is available under Size & Location tab.
Normally, SWT button has setSize method which takes width and height as parameters. If these are what the intellisense shows?
Should I still report?
Re: Preview & Run-time views are different [message #573550 is a reply to message #525879] Thu, 08 April 2010 19:09 Go to previous message
Hi Yang,
Previous Topic:XWT: Preview & Run-time views are different
Next Topic:open Application.e4xmi and the window keeps flashing
Current Time: Tue Apr 16 04:28:28 GMT 2024
Powered by FUDForum. Page generated in 0.19225 seconds
