Preferences->Label Decorations->Git won't "stick" [message #523035] |
Wed, 24 March 2010 20:08 |
buzzkill Messages: 10 Registered: March 2010 |
I can't get the label decorations to stick. I select the Preferences->Label Decorations->Git check box, but the setting won't apply and just reverts back to unchecked.
Everything is selected in Team->Git->Label Decorations.
The Import->Git->Git Repository worked fine, and all the files are imported correctly into the project..
Also, Team->Commit... is greyed out for all files, as well as Push. However, compare and history work fine... (if this is a separate problem, I will post separate topic).
I'm using Eclipse 3.5 with CDT and Egit 0.7.1 using ubuntu 8.0.4.
Any ideas or simple fixes?
buzz
[Updated on: Wed, 24 March 2010 20:16] Report message to a moderator
Re: Preferences->Label Decorations->Git won't "stick" [message #525540 is a reply to message #525439] |
Tue, 06 April 2010 19:53 |
> news:hodrgc$qeo$1@build.eclipse.org...
>> Hi,
>There is a known bug in case that there is a .git folder somewhere below a
>eclipse project (https://bugs.eclipse.org/bugs/show_bug.cgi?id=297163). Do
>you have that in your case?
I just checked, and I definitely have that case. In fact, I have three. Here's the directory structure (w company specifics x'd out):
projects/xxx/mx/.git
projects/xxx/dxxxxx/.git
projects/xxx/mxxxx/.git
projects/xxx/.project
Is this the same as the bug you mentioned?
>Do you have any entries in the error log?
Which/where error log?
>Stefan
Thank you for your help.
David
[Updated on: Tue, 06 April 2010 22:03] Report message to a moderator
FUDForum. Page generated in 0.03439 seconds
