Home » Eclipse Projects » Rich Client Platform (RCP) » Build ID in product splash screen
Build ID in product splash screen [message #522255] Sun, 21 March 2010 16:53 Go to next message
I can't believe I'm not able to locate this somewhere in the docs, but my splash screen is displaying a build ID in the default (i.e. SDK product build) location; except that it says "Unknown Build". I'm unfortunately still on manual IDE hosted build for my products so that isn't getting set anywhere AFAIK. Where can I set and/or disable this? It doesn't seem to be ..runtime.products.
thanks,
Miles
Re: Build ID in product splash screen [message #522256 is a reply to message #522255] Sun, 21 March 2010 17:10 Go to previous messageGo to next message
Never mind. I feel like an idiot, but I must have put it in myself at some point:
org.eclipse.ui.workbench/SHOW_BUILDID_ON_STARTUP=true
These are specified in IWorkbenchPreferenceConstants, but I'm not sure that's actually point out in the docs anywhere..
I think the other question still stands though -- where exactly is the workbench pulling this from? Is it configuration? In which case is there anyway to set this from a manual build w/o editing a config.ini?
cheers,
Miles
Miles Parker wrote on Sun, 21 March 2010 16:53
thanks,
Miles
Re: Build ID in product splash screen [message #524339 is a reply to message #522256] Wed, 31 March 2010 06:04 Go to previous message
As you mentioned, eclipse.buildId in the config.ini. But I believe you
can set it -Declipse.buildId on your command line to override it.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Command Binding Scheme
Next Topic:IMemento usage
Current Time: Thu Jul 17 21:46:55 EDT 2025
Powered by FUDForum. Page generated in 0.07127 seconds
