Home » Language IDEs » PHP Development Tools (PDT) » Building php projects...
Building php projects... [message #522251] Sun, 21 March 2010 19:12 Go to next message
Tony  is currently offline Tony Friend
Hiya guys
When i start up eclipse (3.32 with pdt 1.03) i get in the bottom bar "building php projects"...for about 45 minutes before it finally begins to build the workspace. This happens every time i start eclipse. I am working on a small-medium site, which references the zend framework. Is this build feature needed, or can it be turned off - if so, what will i lose out on?
Or is there any way to find out what's choking the builder for so long?
[Updated on: Sun, 21 March 2010 19:13]
Report message to a moderator
Re: Building php projects... [message #522618 is a reply to message #522251] Tue, 23 March 2010 11:38 Go to previous messageGo to next message
Doesn't this happen to anyone else?
Re: Building php projects... [message #522620 is a reply to message #522251] Tue, 23 March 2010 11:42 Go to previous messageGo to next message
sNop is currently offline sNopFriend
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enig533ECAE73E61EE171EB557ED
Content-Type: text/plain; charset=UTF-8
Content-Transfer-Encoding: quoted-printable
Dne 21. 3. 2010 20:12, Tony napsal(a):
> Hiya guys
>=20
> "building php projects"...for about 45 minutes before it finally begins=
> to build the workspace. I am working on a small-medium site, which
> Or is there any way to find out what's choking the builder for so long?=
why didn't you upgrade to the latest stable build which is e.g. on the ze=
nd site ?
http://www.eclipse.org/pdt/downloads/
http://www.zend.com/en/community/pdt
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.12 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAkuoqRwACgkQkCAxuhXMpxW0lACffShGFQMiZWDXGM+SRTYf 8vfc
iG4An0OKgome+o77wbB9/yGyW2pppZxh
=QtZC
-----END PGP SIGNATURE-----
--------------enig533ECAE73E61EE171EB557ED--
Re: Building php projects... [message #528659 is a reply to message #522618] Wed, 21 April 2010 11:23 Go to previous messageGo to next message
hello
we had similar problem, it was caused by slower samba resources and versioning
control. Some options were checked like "refresh before build" etc. Eclipse was
refreshing all files, asking for each file etc. There was huge amount of packets
over network, small but about 1000/second. Samba with such usage is very slow.
We solved out problem by:
+ turning on some memory cache options (for svn)
+ tweaking samba (new version, some options)
+ disabling some svn updates
Moving resources from samba to local disk cured problem completely.
BTW: if you are still using such old Eclipse You should upgrade.
d.
Re: Building php projects... [message #529187 is a reply to message #528659] Fri, 23 April 2010 10:55 Go to previous message
Thanks for the replies. The last time i used the latest vesion (2.1 if i recall correctly) the autocomplete was horrific so i've stayed on 1.03 ever since.
Interesting about version control - i have tortoiseSVN installed (developing on a windows box) so that may have something to do with it.
Previous Topic:SWT Browser Control is not available
Next Topic:Auto Update SVN Projects?
Current Time: Sat Feb 08 07:53:50 GMT 2025
Powered by FUDForum. Page generated in 0.03800 seconds
