Home » Archived » Buckminster » Update Authorized CI problem
Update Authorized CI problem [message #521398] Wed, 17 March 2010 13:49 Go to next message
Alexis  is currently offline Alexis Friend
ENTRY com.ibm.ism.dw.models.cispace.diagram 4 0 2010-03-17 08:39:19.859
!MESSAGE Error building context menu
!STACK 0
at com.ibm.ism.dw.models.cispace.diagram.part.DiagramEditorCont extMenuProvider.buildContextMenu(DiagramEditorContextMenuPro vider.java:69)
at org.eclipse.gef.ContextMenuProvider.menuAboutToShow(ContextM enuProvider.java:60)
at org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuMan ager.java:335)
at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuM anager.java:463)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.ja va:459)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager .java:485)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:235)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.jav a:4111)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3815 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:337)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1576)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:1937)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4528 )
at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:250)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:3849)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3416)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Re: Update Authorized CI problem [message #521408 is a reply to message #521398] Wed, 17 March 2010 14:13 Go to previous message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Alexis,
What is the relationship between this stacktrace and Buckminster?
- thomas
> !STACK 0
> ager.java:335)
> anager.java:463)
> ner.java:235)
> (Realm.java:288)
> bench.java:488)
> tarter.java:386)
> tarter.java:179)
Re: Update Authorized CI problem [message #521410 is a reply to message #521398] Wed, 17 March 2010 14:13 Go to previous message
Alexis,
Is there a question related to Buckminster?
> !STACK 0
> vider.java:69)
> ager.java:335)
> anager.java:463)
> va:459)
> .java:485)
> ner.java:235)
> a:4111)
> ava:1576)
> :3416)
> a:2382)
> (Realm.java:288)
> bench.java:488)
> ava:149)
> tarter.java:386)
> tarter.java:179)
Ed Merks
Previous Topic:Downloading/installing buckminster through the director: Unpack facility not configured
Next Topic:solving java.lang.OutOfMemoryError: "Java heap space"
Current Time: Wed Sep 22 12:54:44 GMT 2021
Powered by FUDForum. Page generated in 0.01704 seconds
