Re: Downloading/installing buckminster through the director: Unpack facility not configured [message #521360 is a reply to message #521349] |
Wed, 17 March 2010 12:01 |
Seems you have the same problem as Eike did yesterday. Check if you have this line in the director task:
<jvmarg value=" -Dorg.eclipse.update.jarprocessor.pack200=${org.eclipse.upda te.jarprocessor.pack200} " />
If you do, the problem is probably that the property is not set. You can either remove this line and make sure you use a
JVM that isn't buggy with respect to pack200 (i.e. do not use the Hudson default 1.6, nor the 1.6 M4), or you can make
sure that the property is correctly propagated in your Hudson config. I.e., add:
org.eclipse.update.jarprocessor.pack200=/shared/common/ibm-j ava2-ppc-50/jre/bin
to the Ant -> Advanced properties.
HTH,
- thomas
On 03/17/2010 12:12 PM, Martin Taal wrote:
> I am using buckminster for the eclipse.org hudson build. When updating
> to the latest buckminster build and trying to download it I get this
> exception. I think it is a director/p2 issue but maybe someone here has
> encountered the same issue and solved it.
> See here for the complete log:
> https://build.eclipse.org/hudson/job/emft-texo-nightly/72/co nsole
> Is this a buckminster thing? Or maybe a director issue?
> [echo] Configuring headless buckminster with needed features
> [java] Installing org.eclipse.buckminster.cmdline.product 1.2.0.r11290.
> [java] Installing
> org.eclipse.buckminster.core.headless.feature.feature.group 1.3.0.r11313.
> [java] Installing
> org.eclipse.buckminster.pde.headless.feature.feature.group 1.2.0.r11295.
> [java] Installing
> org.eclipse.buckminster.cvs.headless.feature.feature.group 1.1.0.r11210.
> [java] Installing
> org.eclipse.buckminster.emma.headless.feature.feature.group 0.9.0.r11256.
> [java] An error occurred while collecting items to be installed
> [java] session context was:(profile=Buckminster,
> phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Collect,
> operand=, action=).
> [java] Result of processing steps.
> [java] Unpack facility not configured
> [java] OK
> [java] OK
> [java] OK
> [java] OK
> [java] OK
> [java] OK
> [java] OK
> [java] OK
Re: Downloading/installing buckminster through the director: Unpack facility not configured [message #521369 is a reply to message #521360] |
Wed, 17 March 2010 12:59 |
Thanks Thomas, that worked!
gr. Martin
> <jvmarg
> either remove this line and make sure you use a JVM that isn't buggy
> 1.6 M4), or you can make sure that the property is correctly propagated
> HTH,
> - thomas
>> Hi,
>> [java] Installing
>> [java] Installing
>> [java] Installing
>> [java] Installing
>> operand=, action=).
>> [java] OK
>> [java] OK
>> [java] OK
>> [java] OK
>> [java] OK
>> [java] OK
>> [java] OK
>> [java] OK
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.02874 seconds
