Home » Archived » M2M (model-to-model transformation) » [ATL]Problem in run ATL standalone
Re: [ATL]Problem in run ATL standalone [message #52721 is a reply to message #52667] |
Tue, 17 July 2007 14:29 |
Originally posted by: erik_becker.gmx.de
Hi Stephen,
I'm not sure if your solution should work, but if you change it to
AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF)
it should work.
Greetings
Erik
sfyu schrieb:
> I'm using the latest code. I got it from CVS and exported them as plugins.
> In my standalone java programme, I wrote code like:
> import org.eclipse.m2m.atl.engine.AtlModelHandler;
> AtlModelHandler.getDefault("EMF");
> I always get following error message:
> Exception in thread "main" java.lang.RuntimeException:
> java.lang.NoClassDefFoundError
> at
> testEcore2Ecore.ModelTransform.getDefaultHandler(ModelTransf orm.java:133)
> at testEcore2Ecore.ModelTransform.main(ModelTransform.java:45)
> Caused by: java.lang.NoClassDefFoundError
> at
> org.eclipse.m2m.atl.engine.AtlEMFModelHandler.<init>(AtlEMFModelHandler.java:117)
> at
> org.eclipse.m2m.atl.engine.AtlModelHandler.getDefault(AtlMod elHandler.java:55)
> at
> testEcore2Ecore.ModelTransform.getDefaultHandler(ModelTransf orm.java:125)
> ... 1 more
> By debug the code I found:
> --->new AtlEMFModelHandler();
> --->if (Platform.isRunning()) {....}
> The method call: Platform.isRunning() cause the error.
> And I do not find this method call in ATL old version.
> So is it a bug?
> If yes, I'm going to fire a bug in bugzilla.
> Thanks
> Stephen Yu
Re: [ATL]Problem in run ATL standalone [message #52888 is a reply to message #52721] |
Wed, 18 July 2007 00:15 |
stephen Yu Messages: 35 Registered: July 2009 |
Member |
Hi Erik,
In AtlModelHandler.java, you will find following declaration:
public final static String AMH_EMF = "EMF";
So what's the difference between
"AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF)
" and "AtlModelHandler.getDefault("EMF")??
Just as I has pointed out, the problem is caused by
"Platform.isRunning()"method call.
This method should be called within eclipse run-time workbench, right?
In my code, I run ATL in standalone mode.
Is it a regression? because my code runs well with old version of ATL.
Stephen Yu
"Erik Becker" <erik_becker@gmx.de> wrote in message
news:f7ijoa$uuf$1@build.eclipse.org...
> Hi Stephen,
> it should work.
> Greetings
> Erik
>> plugins.
>> at
>> at
>> at
>> at
>> ... 1 more
>> So is it a bug?
>> Thanks
>> Stephen Yu
Re: [ATL]Problem in run ATL standalone [message #52910 is a reply to message #52888] |
Wed, 18 July 2007 05:53 |
Dennis Wagelaar Messages: 147 Registered: July 2009 |
Hi Stephen, Erik,
I've had this problem too, several times actually. It turns out Eclipse
classes are sometimes on the move from one jar to another ;-). The
Platform class at some point moved from the core runtime jar to an
equinox jar. Please check whether the jar files you've included in your
class path still include all classes that are needed. I use the
following Ant script to collect the jar dependencies:
http://ssel.vub.ac.be/viewcvs/viewcvs.py/UML1CaseStudies/uml 1cs-atlcommandline/lib/copydep.build.xml?rev=6870&view=m arkup
That said, I did change the AtlModelHandler code a while ago... Before,
AtlModelHandler just tried to access the Eclipse extension point
registry to find model handlers and gave up when an exception occurred.
This was changed to a check on Platform.isRunning(), since this is the
preferred method to find out whether you're running standalone or within
Eclipse. It does require the Platform class to be in your classpath,
where this previously wasn't necessary.
Dennis
sfyu schreef:
> Hi Erik,
> Thanks
> Stephen Yu
>> Hi Stephen,
>> it should work.
>> Greetings
>> Erik
>>> plugins.
>>> at
>>> at
>>> at
>>> at
>>> ... 1 more
>>> So is it a bug?
>>> Thanks
>>> Stephen Yu
Re: [ATL]Problem in run ATL standalone [message #53700 is a reply to message #52910] |
Fri, 20 July 2007 03:01 |
Member |
Hi Dennis,
Thanks a lot for your help.
It seams that your ant script still miss a jar which is required.
It is org.eclipse.core.jobs.[versionnumber].jar
Without it, I still get error message when running ATL standalone.
After adding all jars mentioned in you ant scripts and the missing jar, my
programme can run and I do get the correct result after transformation,
but I still get a strange error although it does not affect the result.
see,
java.lang.IllegalStateException: Workspace is closed.
at
org.eclipse.core.resources.ResourcesPlugin.getWorkspace(Reso urcesPlugin.java:320)
at
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.saveModel(AtlE MFModelHandler.java:99)
at
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.saveModel(AtlE MFModelHandler.java:65)
at testEcore2Ecore.ModelTransform.main(ModelTransform.java:106)
It's caused by "getDefaultHandler("EMF").saveModel(currentOutModel, os);"
in my code.
What does it mean? Does anybody have idea about it?
Stephen Yu
Dennis Wagelaar wrote:
> Hi Stephen, Erik,
> Regards,
> Dennis
> sfyu schreef:
>> Hi Erik,
>> Thanks
>> Stephen Yu
>>> Hi Stephen,
>>> it should work.
>>> Greetings
>>> Erik
>>>> plugins.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 1 more
>>>> So is it a bug?
>>>> Thanks
>>>> Stephen Yu
Current Time: Wed Apr 17 19:28:10 GMT 2024
Powered by FUDForum. Page generated in 0.03208 seconds
