Home » Archived » B3 » newversion of b3 book uploaded
newversion of b3 book uploaded [message #520814] Mon, 15 March 2010 13:31 Go to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
a new version (0.3) of the draft b3 book have been uploaded.
The following issues have been fixed:
- select-switch in repository configuration documented
- reported typos fixed
- general eclipse technology part moved to appendix
- b3expression & build part renamed "b3 reference"
This was just uploaded to eclipse, so expect some lag until it is
available on all mirrors.
- henrik
Re: newversion of b3 book uploaded [message #527251 is a reply to message #520814] Wed, 14 April 2010 15:02 Go to previous messageGo to next message
Werner Keil is currently offline Werner KeilFriend
Where is the URL for this book?
Unfortunately (for them ;-) the colleagues I mentioned at EclipseCon have
abandoned P2 mainly because it was too complex for them to understand and
little documented in some areas you must admit.
I currently won't need it (I use Eclipse based IDEs like STS but more on the
server side) but I'll share it with 2 of my friends who also attended
EclipseCon.
Werner
Re: newversion of b3 book uploaded [message #527341 is a reply to message #527251] Wed, 14 April 2010 20:52 Go to previous messageGo to next message
The latest version is always found at the link:
http://www.eclipse.org/downloads/download.php?file=/tools/bu ckminster/doc/BuckyBook.pdf
Currently revision 0.7.
- henrik
> have abandoned P2 mainly because it was too complex for them to
> understand and little documented in some areas you must admit.
> the server side) but I'll share it with 2 of my friends who also
> attended EclipseCon.
> Werner
Re: newversion of b3 book uploaded [message #527342 is a reply to message #527341] Wed, 14 April 2010 20:55 Go to previous message
Hm,
that was not the answer to your question :)
I was responding to a question about the bookminster book at the same
time, and pasted the wrong URL.
Everything about b3 is reachable from
http://www.eclipse.org/modeling/emft/b3
The b3 book is found at:
http://www.eclipse.org/downloads/download.php?file=/modeling /emft/b3/documentation/B3Book2.pdf
- henrik
> Regards
> - henrik
>> Thanks,
>> Werner
Re: newversion of b3 book uploaded [message #603717 is a reply to message #520814] Wed, 14 April 2010 15:02 Go to previous message
EclipseCon.
Werner
Re: newversion of b3 book uploaded [message #603724 is a reply to message #527251] Wed, 14 April 2010 20:52 Go to previous message
- henrik
> Werner
Re: newversion of b3 book uploaded [message #603725 is a reply to message #527341] Wed, 14 April 2010 20:55 Go to previous message
Hm,
- henrik
> Regards
> - henrik
>> Thanks,
>> Werner
Previous Topic:Using p2 model to generate a p2 site
Next Topic:Ideas from Grails dependency resolution
Current Time: Sun Jan 17 10:59:59 GMT 2021
Powered by FUDForum. Page generated in 0.02563 seconds
