Re: Egit and gitosis [message #520951 is a reply to message #520943] |
Mon, 15 March 2010 22:00 |
tomw Messages: 6 Registered: March 2010 |
Exactly the same issue here. That's the point. It seems that the keys are either not properly recognized or the settings in the push dialog do not really fit.
For gitosis push I would expect something like
git push git@myhost.com:myrepo
but I can't get to this format
update: of course, it needs to spell git(at)myhost.. but suprisingly the editor makes a dot from the @
[Updated on: Tue, 16 March 2010 09:29] Report message to a moderator
Re: Egit and gitosis [message #523425 is a reply to message #522555] |
Fri, 26 March 2010 12:48 |
sure, the native git environment works perfectly well with gitosis, so the setup is ok. The only point is that I can't push from Egit. Perhaps you can share what you have changed to make it work.
concerning the passphrase: the passphrase is only needed if you setup a passphrase during key generation.
[Updated on: Fri, 26 March 2010 12:50] Report message to a moderator
Re: Egit and gitosis [message #523520 is a reply to message #523425] |
Fri, 26 March 2010 16:50 |
Ivan V Messages: 22 Registered: March 2010 |
You wrote in an earlier message that you had the same issue as I. The cause may be the same or it may be different. In my case I did not change anything, except enter a non-obvious pass-phrase that was accepted. In fact the git user name is misleading.
The pass-phrase I entered was not the the empty password associated with the git user, but the pass-phrase associated with the private key for logging into my server user account (!) which does NOT have the username 'git', but something else. Why EGit would require that pass-phrase, I don't know. Since EGit does not ask me for the pass-phrase again until Eclipse is restarted it is stored somewhere. Hopefully it's in memory only, but I haven't seen any documentation regarding this.
As native git doesn't require this pass-phrase I'm wondering why EGit does.
[update:] It could be that I'm confused. I'm using the same public key for interacting with gitosis and for my user account on the same server. Mac OS X stores my pass-phrase in the Keychain and that could be the reason it's not requested when pushing with native git. However, I still would like to know how EGit stores the pass-phrase during the lifetime of the Eclipse session. Hope this may be of any help to others.
[Updated on: Tue, 30 March 2010 11:32] Report message to a moderator
FUDForum. Page generated in 0.03081 seconds
