Home » Eclipse Projects » Eclipse 4 » e4 1.0M4: example psf still points to R0_9 and photo sample not compiling
e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #520308] Thu, 11 March 2010 21:26 Go to next message
Bernhard Merkle is currently offline Bernhard MerkleFriend
Member
I installed e4 1.0M4 and generate the example project via menu.
however the psf still points to the 0.9 Release. is this intended ?
I think it should be tag 1_0M4, right ?
also please note that the photoapplication does not compile (at least
using 1.0M4 with the R0_9 version of the photo sample.
thanks,
Berni.
<psf version="2.0">
<provider id="org.eclipse.team.cvs.core.cvsnature">
<project
reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/eclipse,e4/org.eclipse .e4.ui/examples/org.eclipse.e4.demo.contacts,org.eclipse.e4. demo.contacts,R0_9 "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/eclipse,e4/org.eclipse .e4.ui/examples/org.eclipse.e4.demo.e4photo,org.eclipse.e4.d emo.e4photo,R0_9 "/>
</provider>
</psf>
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #520347 is a reply to message #520308] Thu, 11 March 2010 23:14 Go to previous messageGo to next message
Lars Vogel is currently offline Lars VogelFriend
what does not compile in photo?
Cheers, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
On 11.03.2010 13:26, Bernhard Merkle wrote:
> thanks,
> Berni.
> <psf version="2.0">
> <project
> <project
> </provider>
> </psf>
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #520375 is a reply to message #520347] Fri, 12 March 2010 07:21 Go to previous messageGo to next message
Member
Lars Vogel wrote on Thu, 11 March 2010 18:14
ExifTable.java
import org.eclipse.e4.core.services.events.IEventBroker;
@Inject
private IEventBroker eventBroker;
type seems to be moved or removed...
kind regards,
Berni.
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #520556 is a reply to message #520308] Fri, 12 March 2010 19:19 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
Did you get the e4 1.0M4 SDK zip or did you install it on top of
something existing?
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #520558 is a reply to message #520556] Fri, 12 March 2010 19:27 Go to previous messageGo to next message
Member
>> Hi,
> something existing?
i get the e4 1.0M4 SDK from the website, clean fresh install.
new workspace etc. so should be easy to reproduce.
Berni.
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #520589 is a reply to message #520558] Fri, 12 March 2010 23:21 Go to previous message
Member
okay, please ignore this post. my 1.0M4 installation was somehow
corrupted. after reinstall everything worked fine....
Berni.
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #569927 is a reply to message #520308] Fri, 12 March 2010 04:03 Go to previous message
Cheers, Lars
> thanks,
> Berni.
> <psf version="2.0">
> <project
> <project
> </provider>
> </psf>
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #570012 is a reply to message #569927] Fri, 12 March 2010 07:21 Go to previous message
Member
ExifTable.java
@Inject
kind regards,
Berni.
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #570237 is a reply to message #520308] Fri, 12 March 2010 19:19 Go to previous message
something existing?
PW
Paul Webster
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #570273 is a reply to message #520556] Fri, 12 March 2010 19:27 Go to previous message
Member
>> Hi,
> something existing?
Berni.
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #570393 is a reply to message #520558] Fri, 12 March 2010 23:21 Go to previous message
Member
Berni.
Previous Topic:XWT. How to set absolute (null) layout?
Next Topic:XWT and Form Layout - Problems ?
Current Time: Wed Feb 26 10:45:56 GMT 2020
Powered by FUDForum. Page generated in 0.10781 seconds
