Home » Eclipse Projects » Remote Application Platform (RAP) » Could someone check the RAP example, I guess there might be an error(When close PopupMenu, SWT.Disposed Exception is thrown.)
Re: Could someone check the RAP example, I guess there might be an error [message #520417 is a reply to message #520137] |
Fri, 12 March 2010 05:26 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Wayne,
without testing your scenario, you mention MenuPopup class, but I can't
find such a class in RAP from CVS HEAD. What RAP version are you using?
Best,
Ivan
On 03/11/2010 11:47 AM, wayne wrote:
> This would happen in two Scenarios:
> The example used is the first one on website:
> http://www.eclipse.org/rap/demos.php
> 1. Add an Editor to the example -> Add a New MenuItem to show the
> Editor -> Run Example -> Execute the MenuItem; Exception is thrown. I
> find the error is thrown in the method close() in MenuPopup.java. So I
> do "//close()", then run again. Works!
> 2. Add an Editor to the modified code as mentioned above, let the
> execution of the MenuItem to open a wizard, using wizard to open the
> Editor. Can't solve. I guess it might happen in som place where wizard
> is closing. But I can't change the code.
Re: Could someone check the RAP example, I guess there might be an error [message #520426 is a reply to message #520417] |
Fri, 12 March 2010 05:50 |
Holger Staudacher Messages: 166 Registered: July 2009 |
hi Wayne, hi Ivan,
the class MenuPopup was a design related one. We used this class to
provide a styled menu. Since we can style menus with rounded corners
and gradients this class was not longer needed. So, I removed the class
right after RAP 1.3 M5 and replaced the menu behaviour with the one
from the workbench.
@Wayne: your error should be goen with M6 or the latest version from HEAD.
Hope this helps.
Regards Holger
On 2010-03-12 11:13:37 +0100, Ivan Furnadjiev <ivan@eclipsesource.com> said:
> Hi Wayne,
> Best,
> Ivan
http://eclipsesource.com
http://twitter.com/eclipsesource
Current Time: Thu Apr 25 04:43:18 GMT 2024
Powered by FUDForum. Page generated in 0.02557 seconds
