Re: Jar making problem [message #520156 is a reply to message #520092] |
Thu, 11 March 2010 11:38 |
The error you're getting means that the class file is out of sync with the project inside Eclipse. That can happen if you compiled it outside the IDE or erased it manually.
Have you tried to refresh the project handigeklasses?
You can do that selecting the project and pressing F5 or right-click the project and then "Refresh".
Try cleaning the project too, that normally sync the class files inside the project with the latest updates you have done in your java files.
You can clean a project going to the menu Project > Clean...
From there you can clean (rebuild) all projects in your workspace or only some of them by selecting "Clean projects selected below" and selecting the desired projects.
FUDForum. Page generated in 0.02921 seconds
