Re: Eclipse is always locked [High CPU & RAM usage] [message #521975 is a reply to message #520680] |
Fri, 19 March 2010 09:26  |
Il 14/03/2010 10.02, Talha Kabakus ha scritto:
> -XX:MaxPermSize=128m
First of all, remove this line, as you already have the following:
--launcher.XXMaxPermSize
256m
> My laptop has 3 GB RAM, and AMD Turion 64 x2 2.00 GHz CPU. The only
> plugin that I installed is Hibernate.. I'm a web developer, so I use
> Tomcat while developing.. That's all what I used Eclipse till now..
> Thanx again..
I don't know if there's an Eclipse plugin for Hibernate, however if you
say you're using Tomcat I think you're also using Webtools. Which
Eclipse version did you download and install?
Secondly, which JRE are you using to run Eclipse?
What are you doing when Eclipse starts to freeze? Building the
workspace? Something else?
Is your project big or small?
Is Eclipse reading from the hard disk while you see it freezing?
Once frozen, does Eclipse awake after a while or does it crash?
Is there any "OutOfMemoryException" error in you
<workspace>/.metadata/.log file?
If so, what is the full error message of that OutOfMemoryException?
Mauro.
FUDForum. Page generated in 0.04011 seconds
