Home » Eclipse Projects » SWTBot » Give an argument to the swtbot test on run
Give an argument to the swtbot test on run [message #519902] Wed, 10 March 2010 13:21 Go to next message
Urtzi Odriozola is currently offline Urtzi OdriozolaFriend
Hi!
I've made a generic testcase using SWTBot for then, to be able to change some parameters in the test.
So, I wanna give an argument to my swtbot java class when this one is executed. This parameter will change the behaviour of the test so, it's there any possibilities to do that?
I mean, how can I give a variable to my test class, so, I will able to change my test?
Thank you!!
Re: Give an argument to the swtbot test on run [message #519917 is a reply to message #519902] Wed, 10 March 2010 09:14 Go to previous messageGo to next message
Pascal G is currently offline Pascal GFriend
Urtzi Odriozola wrote:
> Hi!
> change my test?
> Thank you!!
You could probably use system properties when launching your test. When
launching, add this parameter: -Dname.of.property=value ; then, inside
your test case, use this: System.getProperty("name.of.property").
This'll return the value you passed as a string. It's also a good idea
to provide a default value, using the 2 args method instead:
System.getProperty("name.of.property", "defaultValue").
Hope this helps
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: Give an argument to the swtbot test on run [message #519939 is a reply to message #519902] Wed, 10 March 2010 14:51 Go to previous messageGo to next message
Wooowww!!
That's a quick and great answer!! That works perfectly to me!!
Thank you very much!!!
Re: Give an argument to the swtbot test on run [message #519978 is a reply to message #519902] Wed, 10 March 2010 16:55 Go to previous messageGo to next message
Ketan Padegaonkar is currently offline Ketan PadegaonkarFriend
Something like this:
http://kentbeck.github.com/junit/javadoc/latest/org/junit/ru nners/Parameterized.html
-- Ketan
On 3/10/10 5:21 AM, Urtzi Odriozola wrote:
> Hi!
> change my test?
> Thank you!!
Re: Give an argument to the swtbot test on run [message #520014 is a reply to message #519978] Wed, 10 March 2010 18:47 Go to previous message
Didn't know that this existed! Seems quite handy! It also look more
appropriated then my solution.
*Nu Echo Inc.*
Previous Topic:JUnit as dependency for SWTBot features?
Next Topic:Ant not getting environment on MacOSX when running within Eclipse
Current Time: Sat Mar 25 12:23:29 GMT 2023
Powered by FUDForum. Page generated in 0.02010 seconds
