Home » Language IDEs » PHP Development Tools (PDT) » PDT in Java Eclipse
PDT in Java Eclipse [message #519703] Tue, 09 March 2010 12:30 Go to next message
I've already installed Eclipse for Java development.
Now, I want to install PDT. Can I do this without installing a new Eclipse, as plugin?
I searched the web for half an hour but, however, all tipps I found didn't work, the plugin-installation failed!
Thanks in advance!!!!
Max K.
EDIT:
I've solved my first problem: I tried to install the PDT using the plugin installer.
But the installer reported a problem ("dependency conflict")and it wasn't able to install the plugin.
Does anyone know why this conflict occures?
[Updated on: Tue, 09 March 2010 13:29] by Moderator
Re: PDT in Java Eclipse [message #519783 is a reply to message #519703] Tue, 09 March 2010 14:12 Go to previous messageGo to next message
mail@maximilian-kellner.de wrote:
> Eclipse, as plugin?
A nicely detailed writeup can be found at
http://wiki.eclipse.org/PDT/Installation
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: PDT in Java Eclipse [message #519948 is a reply to message #519783] Wed, 10 March 2010 10:27 Go to previous messageGo to next message
thank you, but I've already found this source.
Now, my problem is that when I try to install the plugin there is a dependency conflict and I don't know how to solve it!
Max K.
Re: PDT in Java Eclipse [message #520318 is a reply to message #519948] Thu, 11 March 2010 17:00 Go to previous message
There is a list of build dependencies with links on this page:
http://www.eclipse.org/pdt/downloads/
Perhaps you could match up the error message with the proper build.
HTH
-Rob B.
Previous Topic: How to perform syntax coloring for my own language
Next Topic:runtime error with PDT and ZendDebugger
Current Time: Fri Jun 20 19:35:02 EDT 2025
Powered by FUDForum. Page generated in 0.26339 seconds
