Home » Archived » IAM (Eclipse Integration for Apache Maven) » Package WAR gives NullPointer Exception
Package WAR gives NullPointer Exception [message #518699] Thu, 04 March 2010 19:11 Go to next message
Tom Talbott is currently offline Tom TalbottFriend
I am trying to use the WAR Overlay functionality in the latest IAM. If Packaging is set to 'war' in the pom.xml file, I get the following exception:
eclipse.buildId=M20090917-0800
java.version=1.5.0_22
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product -keyring /Users/tomtalbott/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86 -product org.eclipse.epp.package.jee.product -keyring /Users/tomtalbott/.eclipse_keyring -showlocation
Error
Thu Mar 04 10:50:13 PST 2010
Unexpected error on project P/sersol-cas: java.lang.NullPointerException
at org.codehaus.plexus.util.xml.Xpp3Dom.<init>(Xpp3Dom.java:73)
at org.apache.maven.lifecycle.LifecycleUtils.mergeBindings(Life cycleUtils.java:304)
at org.apache.maven.lifecycle.plan.BuildPlan.<init>(BuildPlan.java:47)
at org.apache.maven.lifecycle.plan.DefaultBuildPlanner.construc tBuildPlan_aroundBody0(DefaultBuildPlanner.java:103)
at org.apache.maven.lifecycle.plan.DefaultBuildPlanner.construc tBuildPlan(DefaultBuildPlanner.java:1)
at org.eclipse.iam.core.embedder.internal.EclipseMavenBuildPlan ner.constructBuildPlan(EclipseMavenBuildPlanner.java:43)
at org.apache.maven.embedder.MavenEmbedder.getBuildPlan(MavenEm bedder.java:571)
at org.apache.maven.embedder.MavenEmbedder.getBuildPlan(MavenEm bedder.java:537)
at org.eclipse.iam.core.embedder.internal.EclipseMaven.getGoals ForPhase(EclipseMaven.java:937)
at org.eclipse.iam.core.embedder.internal.EclipseMavenRequest.g etExecutionMojos(EclipseMavenRequest.java:436)
at org.eclipse.iam.core.embedder.internal.EclipseMavenRequest.r un(EclipseMavenRequest.java:106)
at org.eclipse.iam.core.embedder.internal.EclipseMaven.executeG oals(EclipseMaven.java:175)
at org.eclipse.iam.core.embedder.internal.EclipseMaven.executeG oals(EclipseMaven.java:160)
at org.eclipse.iam.wtp.core.internal.war.WarBuilderDelegate.run WarExploded(WarBuilderDelegate.java:378)
at org.eclipse.iam.wtp.core.internal.war.WarBuilderDelegate.pro cessOverlayWar(WarBuilderDelegate.java:220)
at org.eclipse.iam.wtp.core.internal.war.MavenWarClasspathListe ner.addOverlayWarFolders(MavenWarClasspathListener.java:123)
at org.eclipse.iam.wtp.core.internal.war.MavenWarClasspathListe ner.resolved(MavenWarClasspathListener.java:57)
at org.eclipse.iam.jdt.core.classpath.container.MavenClasspathC ontainer.resolveArtifacts(MavenClasspathContainer.java:272)
at org.eclipse.iam.jdt.core.classpath.container.MavenClasspathC ontainer.refreshClasspath(MavenClasspathContainer.java:141)
at org.eclipse.iam.jdt.core.classpath.container.MavenClasspathC ontainer.newClasspath(MavenClasspathContainer.java:181)
at org.eclipse.iam.jdt.core.classpath.container.UpdateClasspath Job.runInWorkspace(UpdateClasspathJob.java:80)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
The pom.xml is as follows:
<project xmlns="http://maven.apache.org/POM/4.0.0"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.sersol</groupId>
<artifactId>sersol-cas</artifactId>
<packaging>war</packaging>
<version>0.0.1-SNAPSHOT</version>
<build>
<plugins>
<plugin>
<artifactId>maven-war-plugin</artifactId>
<configuration>
<warName>sersol-cas</warName>
<packagingExcludes>**/*.ORIG</packagingExcludes>
</configuration>
</plugin>
<plugin>
<artifactId>maven-compiler-plugin</artifactId>
<configuration>
<source>1.5</source>
<target>1.5</target>
</configuration>
<executions>
<execution>
<goals>
<goal>compile</goal>
</goals>
</execution>
</executions>
</plugin>
</plugins>
</build>
<dependencies>
<dependency>
<groupId>org.jasig.cas</groupId>
<artifactId>cas-server-webapp</artifactId>
<version>${cas.version}</version>
<type>war</type>
<scope>runtime</scope>
</dependency>
<dependency>
<artifactId>cas-server-core</artifactId>
</dependency>
<dependency>
<groupId>edu.ucmerced.cas</groupId>
<artifactId>cas-server-support-shib</artifactId>
<version>3.3.5a</version>
</dependency>
</dependencies>
<properties>
<cas.version>3.3.5</cas.version>
</properties>
<repositories>
<repository>
<id>ja-sig</id>
<url>http://developer.ja-sig.org/maven2/</url>
</repository>
</repositories>
</project>
Any ideas?
-Tom
Re: Package WAR gives NullPointer Exception [message #518718 is a reply to message #518699] Thu, 04 March 2010 19:45 Go to previous messageGo to next message
Followup: I've gone to a clean JEE Eclipse install with IAM and subversive. I still get nullpointers with the above pom.xml, but the stack trace is different:
eclipse.buildId=unknown
Error
Thu Mar 04 11:41:22 PST 2010
An internal error occurred during: "Updating classpath container: sersol-cas".
at org.eclipse.wst.common.componentcore.internal.resources.Virt ualResource.removeLink(VirtualResource.java:300)
at org.eclipse.iam.wtp.core.internal.war.MavenWarClasspathListe ner.addOverlayWarFolders(MavenWarClasspathListener.java:89)
Re: Package WAR gives NullPointer Exception [message #518798 is a reply to message #518718] Thu, 04 March 2010 23:18 Go to previous messageGo to next message
Carlos Sanchez is currently offline Carlos SanchezFriend
try deleting the
..project
..classpath
..settings
and reimporting the project again from Import -> Maven 2 project
> Error
> sersol-cas".
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: Package WAR gives NullPointer Exception [message #519431 is a reply to message #518798] Mon, 08 March 2010 19:08 Go to previous messageGo to next message
Thanks for the reply Carlos,
I tried your suggestion on my "clean" copy of Eclipse and now I'm getting the same errors as my first message:
Error
Mon Mar 08 10:54:57 PST 2010
at org.eclipse.iam.wtp.core.internal.war.WarBuilderDelegate.onF ullBuild(WarBuilderDelegate.java:87)
at org.eclipse.iam.builder.internal.builder.MavenIncrementalBui lder.doFullBuild(MavenIncrementalBuilder.java:213)
at org.eclipse.iam.builder.internal.builder.MavenIncrementalBui lder.build(MavenIncrementalBuilder.java:119)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:627)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:170)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:309)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:341)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:140)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:238)
I deleted the project from eclipse, removed the dot files an ".settings" and imported the project back into eclipse.
Would really love to get this working. We are trying to work with a 3rd party WAR (CAS) that uses WAR Overlay as a way to customize the framework.
-Tom
Re: Package WAR gives NullPointer Exception [message #520967 is a reply to message #519431] Tue, 16 March 2010 00:48 Go to previous messageGo to next message
Hoping someone can try to repro this problem. Would love to switch to IAM.
-Tom
Continued NullPointer Exceptions trying to use IAM [message #521485 is a reply to message #518699] Wed, 17 March 2010 18:14 Go to previous messageGo to next message
I've tried to pursue this further, by starting with a standard Maven webapp generated from maven-archetype-webapp. If I start adding just about anything to the pom, I can start getting nullpointers of the form:
Sometimes it goes away for a bit if I turn off Maven Dependency Management and back on again. But, that doesn't always work.
Below is a reference to another project that had this exception:
http://issues.ops4j.org/browse/PAXCONSTRUCT-77
All of this is on a clean updated Eclipse 3.5.2 with only IAM & Subversive as added plugins. Running on updated Mac OS X 10.5.8.
I need to come up with a solution for my team soon. At this point, I will probably not be looking into IAM any further unless someone gets back soon. I will be evaluating Netbeans next since it supposedly has good Maven integration.
Re: Package WAR gives NullPointer Exception [message #572575 is a reply to message #518699] Thu, 04 March 2010 19:45 Go to previous messageGo to next message
Error
Re: Package WAR gives NullPointer Exception [message #572624 is a reply to message #518718] Fri, 05 March 2010 04:08 Go to previous messageGo to next message
try deleting the
..project
..classpath
..settings
> Error
> sersol-cas".
Re: Package WAR gives NullPointer Exception [message #572681 is a reply to message #572624] Mon, 08 March 2010 19:08 Go to previous messageGo to next message
Error
-Tom
Re: Package WAR gives NullPointer Exception [message #572729 is a reply to message #519431] Tue, 16 March 2010 00:48 Go to previous messageGo to next message
-Tom
Continued NullPointer Exceptions trying to use IAM [message #572746 is a reply to message #518699] Wed, 17 March 2010 18:14 Go to previous message
Previous Topic:Disable Dependecy Path Update
Next Topic:Dependency on test classes in another project
Current Time: Sat Nov 28 17:38:01 GMT 2020
Powered by FUDForum. Page generated in 0.06403 seconds
