Home » Modeling » Modeling (top-level project) » Sequence Diagram with Eclipse(Integration with Eclipse)
Sequence Diagram with Eclipse [message #518442] Thu, 04 March 2010 06:58 Go to next message
No real name is currently offline No real nameFriend
We have created a tool for Reverse Engineering any Java application, which creates dynamic UML Sequence Diagrams and Class Diagrams.
All you have to do is just run your application and sit back. Reverse Java runs in background tracing all the activities happening inside your application and creates UML diagram for you. You can get more details at
http://www.reversejava.com
I would like to enhance the capability of the tool by integrating it with Eclipse, where by users after viewing the Sequence diagram can also edit it.
Can some please recommend me any APIs which I can use for this?
Thanks and Regards,
Rajesh Jadhav.
Re: Sequence Diagram with Eclipse [message #518499 is a reply to message #518442] Thu, 04 March 2010 05:18 Go to previous messageGo to next message
--------------080208010406050804070106
Rajesh,
What APIs are you using now to build the sequence and class diagrams?
At Eclipse you'd be using the UML2
<http://www.eclipse.org/modeling/mdt/?project=uml2> project's APIs.
Aren't class diagrams more of a static thing you'd produce from
analyzing the Java source?
> details at
> also edit it.
> Thanks and Regards,
> Rajesh Jadhav.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Rajesh,<br>
<br>
At Eclipse you'd be using the <a
href="http://www.eclipse.org/modeling/mdt/?project=uml2">UML2</a>
project's APIs.  Aren't class diagrams more of a static thing you'd
produce from analyzing the Java source?  <br>
<br>
<br>
<a class="moz-txt-link-abbreviated" href="mailto:rsjadhav26@gmail.com">rsjadhav26@gmail.com</a> wrote:
<blockquote cite="mid:hmnlmo$85d$1@build.eclipse.org" type="cite">We
<br>
details at <br>
<a class="moz-txt-link-freetext" href="http://www.reversejava.com">http://www.reversejava.com</a>
<br>
<br>
<br>
also edit it.
<br>
<br>
<br>
<br>
Thanks and Regards,
<br>
Rajesh Jadhav.
<br>
<br>
</blockquote>
</body>
</html>
--------------080208010406050804070106--
Ed Merks
Re: Sequence Diagram with Eclipse [message #519539 is a reply to message #518499] Tue, 09 March 2010 09:32 Go to previous messageGo to next message
Thanks for your Reply.
Currently we are using Java 2D to draw class diagrams and sequence diagrams.
Thanks and Regards,
Rajesh
Re: Sequence Diagram with Eclipse [message #519560 is a reply to message #519539] Tue, 09 March 2010 10:27 Go to previous messageGo to next message
Vlad Varnica is currently offline Vlad VarnicaFriend
[Updated on: Wed, 10 March 2010 13:55]
Report message to a moderator
Re: Sequence Diagram with Eclipse [message #619485 is a reply to message #519539] Tue, 09 March 2010 10:27 Go to previous message
Hi Rajesh,
If you want to be natively integrated with Eclipse then you need to use GEF or GMF with EMF and UML2.
btw, if you are not using these plugins you can simply create your own view and put inside your diagrams.
I am convinced your tool have quality and changing architecture just to be native is a very very big investment for a small return on investment. Users needs graphical view connected or not with the code, so make it simple and user friendly.
Previous Topic:Sequence Diagram with Eclipse
Next Topic:[Graphiti Project] - Any news about??
Current Time: Mon Aug 08 20:34:26 GMT 2022
Powered by FUDForum. Page generated in 0.02052 seconds
