Home » Modeling » UML2 » Extending the Standard profile
Re: Extending the Standard profile [message #518309 is a reply to message #518111] |
Wed, 03 March 2010 12:52 |
Erhard Weinell Messages: 39 Registered: January 2010 Location: Kassel, Germany |
Member |
Am 03.03.2010 07:15, schrieb Steven Stallion:
> One area where I am a bit confused, is if I create a Stereotype in the
> profile and an extension to one of the custom metaclasses, I am unable
> to apply the Stereotype to a Class once the profile is defined and then
> applied to a Class diagram.
I do not quite get your scenario. So first you provide your own
metamodel - understood. Now you want to define a profile for these
metaclasses? Wouldn't it be a lot easier to define this metamodel
according to your needs from the beginning?
In general, do you not use the UML2 metamodel at all, or is there
another reason why you cannot simply stick to profiles?
> Is it possible to define an inheritance hierarchy between metaclasses
> (i.e. custom metaclass A inherits from uml::Class)?
Not in a profile. Stereotypes are the way to go here.
You can of course define your own metamodel library and reference UML
metaclasses therein - but in contrast to profiles, tool-support will be
quite close to non-existent when it comes to instantiate this metamodel.
UML tools are just not meant to be used completely without UML :)
> That said, I may be headed down the wrong path - what I truly need is a
> way to apply a metamodel construct to a Stereotype which extends
> uml::Class - if there is another way to do this, any pointers would be
> helpful!
What do you mean by "apply a metamodel construct"? Examples?
Erhard
Re: Extending the Standard profile [message #518472 is a reply to message #518352] |
Thu, 04 March 2010 04:00 |
Member |
Am 03.03.2010 21:58, schrieb Steven Stallion:
> I'm implementing an OMG specification in process. The spec calls for a
> metamodel and a profile. Unfortunately the spec is a little scant on
> details, particularly with how the metamodel is "glued" to the profile
> so I'm left to my own devices at the moment.
Phew, honestly I'd rather advice to leave the implementation work to the
spec authors, as they probably know best :) Or they change their spec if
it turns out not to fit into the UML world properly.
> Right. In this case, I have a Stereotype which extends the uml::Class
> metaclass. In the documentation it states that a secondary "metaclass
> construct" should be applied to the Stereotype. I'm taking this to mean
> that the Stereo type should extend the secondary metaclass which in turn
> extends the uml::Class metaclass.
Doubtful, and very informal - I wonder why they did not put up a profile
diagram instead. I don't think there are good reasons why one would
first extend UML::Class by means of generalization and then again extend
it by a stereotype. There's nothing you couldn't put into the stereotype
directly that you can model in the new metaclass.
What I can imagine is that the stereotype is supposed to have a
composite association to another metaclass (which in turn does not need
to extend anything) - it's the only way I'm aware of to model value
tuples as a stereotype attribute. But that's just guessing.
> See above; this is the exact wording in the specification (which is not
> public yet) - the term confused me a bit, I was hoping someone could
> shed some light on it.
In the UML spec, 'apply' only shows up in the context of profiles. A
profile is not a model (formally) - thats where they lost me.
Erhard Weinell
Re: Extending the Standard profile [message #518918 is a reply to message #518764] |
Fri, 05 March 2010 12:49 |
Member |
Am 04.03.2010 23:49, schrieb Steven Stallion:
> This sounds interesting, and may very well have been the intent of the
> authors - could you describe this in a little more detail? It sounds
> like you are saying that I can have a Stereotype extend uml::Class, and
> then define a composite association between the Stereotype and the
> Metaclass?
This metaclass, or any other one - the target metaclass so to say gets a
new "purpose". E.g., Property does not only represent class attributes,
but also association roles. Class is not only used to represent "usual"
classes, but also for template instantiation. Likewise, you can use
metaclasses for your own purpose in a stereotype. Plus, you can add your
own (meta-)classes to the profile.
I tried to illustrate this in a small example:
http://weinell.de/bin/profile-sh1.png
Erhard Weinell
Re: Extending the Standard profile [message #519041 is a reply to message #519040] |
Fri, 05 March 2010 20:04 |
Hi, Steven,
Yes, a Stereotype can simply define associations to to existing
metaclasses of the metamodel (in your case, UML) that it references.
These can be composite (the stereotype instance contains a UML sub-tree)
or not.
A Profile can also define Classes. These behave, effectively, like
metaclasses. You can use them to define structure in a Stereotype that
can't be expressed using metaclasses from the referenced metamodel.
However, you have to be sure that you define at least one composition
association to own any given class, because otherwise they won't persist
nicely. Instances of profile classes can be owned by stereotypes or
other profile classes.
I don't think that a profile class is permitted to specialize a
metaclass from the referenced metamodel, but I could be wrong about
that. I can certainly imagine that it would introduce tricky problems
of element substitutability ...
HTH,
Christian
On 05/03/10 02:47 PM, Steven Stallion wrote:
> Thanks All.
> I think I'm beginning to understand a little better the relationship
> between the profile and the metamodel. That said, I think there is
> something fundamental I must be missing here.
> Let me try and rephrase my question in a different way...
> Essentially I need to be able to define an additional set of tagged
> values for a given Stereotype. The specification dictates this comes in
> the form of a Class defined in a UML metamodel.
> The profile is all that really matters here, however the metamodel is
> quite complex, so it would not be an easy effort to collapse all of
> these attributes and define them directly in the profile. In addition
> there are a number of inherited constraints which I would prefer not to
> redefine for every Stereotype.
> Ed, the image you posted earlier looks fairly close to what I want,
> however I'm not quite sure how to translate that into the EMF editor for
> the profile. Is there any chance you could elaborate on this a little
> more? Is this simply a composite association to a Metaclass or a
> packaged Class within the metamodel?
> I apologize in advance - I've been a long-time user of UML, however this
> is my first exposure to the MOF and DSL modeling.
> Regards,
> Steve
Re: Extending the Standard profile [message #519053 is a reply to message #519041] |
Fri, 05 March 2010 22:18 |
Steven Stallion Messages: 21 Registered: March 2010 |
Thanks Christian.
Based on your feedback, I've tried updating my profile, however I'm still not seeing the results I want.
Lets say I have Metaclass A which contains two properties, "two", and "three". In my profile I have a single Stereotype B, with a property of "one". What I would like to see is all three tagged values be available, that is "one", "two", and "three" (this is the behavior the specification mandates).
If I create a composite association between A and B, in the graphical editor, I am not able to see any tagged values related to A once the profile is defined, and applied to a class diagram.
Ideas?
Steve
Re: Extending the Standard profile [message #519058 is a reply to message #519053] |
Fri, 05 March 2010 22:35 |
Hi, Steve,
Is your stereotype B a metaclass extension of A? A's properties are not
tagged values; they are metamodel attributes.
For the UML profile, all three of these values are accessible, but they
are owned by different objects. Given
<<b>> a : A
(an "A" with the "B" stereotype applied) you are dealing with two
different objects: a, which has the "two" and "three" properties, and
b, which as the "one" property. The metaclass extension is an
association relationship between b and a. So, from b you can get a's
A::two and A::three by navigating over b's B::base_A property (one end
of the extension association). In OCL, you would actually do this as:
b.base_A.two
for example. To go the other way, in OCL (because OCL is able to
navigate the directed association in reverse)
a.extension_B.one
The mapping of the UML profile to a metamodel (or, probably more
naturally, the metamodel from which the profile was mapped) can combine
the concepts of B and A by simply defining a generalization relationship
from B to A:
B ---|> A
In this case, you can have an element
b : B
that define all three properties (two inherited), so that in OCL you can do
b.one
b.two
A profile will never be able to modify the metaclasses that it
references, so there will always need to be some mapping from property
access in the "metamodel view" of your spec to the "profile view."
Remembering that the semantics of metaclass extension (by stereotypes)
is really just the same as association should help to keep these
mappings straight.
(Forgive the introduction of OCL into the conversation. I just find it
convenient for concrete illustration.)
HTH,
Christian
On 05/03/10 05:18 PM, Steven Stallion wrote:
> Thanks Christian.
> Ideas?
> Steve
Re: Extending the Standard profile [message #519059 is a reply to message #519058] |
Fri, 05 March 2010 23:13 |
Christian,
To be honest, I don't know. The specification seems to be written such that the profile is derived from the metamodel. A is a metaclass, however there does not seem to be a formal association between it and B.
As an example, A is defined as a Class within the Metamodel which may contain any number of associations, generalizations, etc (none of which link back to the UML metamodel).
The profile defines a Stereotype B which extends uml::Class, however there is a table which defines A as B's "metamodel construct".
I think this is where I am getting confused. What is the relationship between a metamodel and a profile? This particular specification has quite a bit defined in the metamodel, and very little in the profile; what purpose could this serve?
TA,
Steve
Re: Extending the Standard profile [message #519113 is a reply to message #519059] |
Sat, 06 March 2010 12:12 |
Member |
Hi Steven,
sounds like the 'Tuple' class in the example I posted above - It is defined
in the given profile without extending any metaclass. As Steven pointed out,
such classes shoud be containment-referenced from some stereotype for
technical purposes. Besides that, the may comprise arbitrary attributes and
associations to other classes. Imported metaclasses cannot be modified,
hence associations towards UML metaclasses may only be navigable in this
direction.
I don't think this term is 'officially defined' - so my best guess is indeed
that B has some composition to A.
It is quite natural if large fragments of the DSL do not map to any UML
construct - so why extend any UML metaclass?
Erhard Weinell
Re: Extending the Standard profile [message #519118 is a reply to message #519058] |
Sat, 06 March 2010 17:52 |
Member |
Hello Christian,
> from B to A:
> B ---|> A
Tools like M2T Xpand treat stereotypes quite this way - metaclasses are
'assignable from' stereotypes (meaning we can typecast from A to B, given
that we have an instance object b). Plus, you can access attributes in a
uniformal way, as you outlined below:
> b.one
> b.two
Surely the 'formal' approach using base_ associations can avoid possible
name clashes, but it makes such OCL documents a nightmare to read.
> mappings straight.
In my opinion, thinking of stereotypes as subclasses of extended metaclasses
is a lot closer to the intended meaning of such constructs - albeit not on
a(OMG-compliant) technical level. Why else would I write a marker <<Entity>>
to a class if not to express that this element IS not a regular class, but
an entity (whatever this means in my context).
Erhard Weinell
Re: Extending the Standard profile [message #628298 is a reply to message #518352] |
Thu, 04 March 2010 08:45 |
Member |
Erhard Weinell
Re: Extending the Standard profile [message #628302 is a reply to message #628301] |
Member |
> Metaclass?
Erhard Weinell
Re: Extending the Standard profile [message #628305 is a reply to message #519040] |
Hi, Steven,
or not.
HTH,
Christian
> Thanks All.
> Regards,
> Steve
Re: Extending the Standard profile [message #628306 is a reply to message #519041] |
Thanks Christian.
Ideas?
Steve
Re: Extending the Standard profile [message #628307 is a reply to message #628306] |
Hi, Steve,
<<b>> a : A
b.base_A.two
a.extension_B.one
from B to A:
B ---|> A
b : B
b.one
b.two
mappings straight.
HTH,
Christian
> Thanks Christian.
> Ideas?
> Steve
Re: Extending the Standard profile [message #628308 is a reply to message #519058] |
Christian,
TA,
Steve
Re: Extending the Standard profile [message #628309 is a reply to message #628308] |
Sat, 06 March 2010 16:59 |
Member |
Hi Steven,
direction.
Erhard Weinell
Re: Extending the Standard profile [message #628310 is a reply to message #519058] |
Member |
Hello Christian,
> from B to A:
> B ---|> A
> b.one
> b.two
> mappings straight.
Erhard Weinell
Current Time: Thu Apr 25 05:14:44 GMT 2024
Powered by FUDForum. Page generated in 0.05569 seconds
