Home » Archived » BIRT » Java and beforeOpen: stop birt execution
Re: Java and beforeOpen: stop birt execution [message #517995 is a reply to message #517958] |
Tue, 02 March 2010 12:08 |
Nicola,
Another approach would be to do this in the beforeFactory and just drop
the report items. Then you could display a message to the user with a
BIRT label report item.
Jason
nicola wrote:
> how can I stop birt from continuing its execution in a beforeOpen method?
> What command should be called (if any)?
> @Override
> public void beforeOpen(IDataSourceInstance dataSource, IReportContext
> reportContext) throws ScriptException {
> if (hasPermission(reportContext)) {
> // show report
> super.beforeOpen(dataSource, reportContext);
> } else {
> // Stop BIRT from continuing
> thank you
> Nicola
Re: Java and beforeOpen: stop birt execution [message #518014 is a reply to message #518000] |
Tue, 02 March 2010 18:04 |
Nicola,
In script it would be something like:
reportContext.getDesignHandle().findElement("mytable").drop();
Just name the table "mytable" in its general properties. You could then
add a label that says "You do not have permission to view this report".
and drop it if they do have permission.
Jason
nicola wrote:
> thank you for the reply.
> Is there an example of code?
> Regards,
> Nicola
> Jason Weathersby ha scritto:
>> Nicola,
>> Jason
>> nicola wrote:
>>> Hi,
>>> @Override
>>> // show report
>>> } else {
>>> thank you
>>> Nicola
Re: Java and beforeOpen: stop birt execution [message #531518 is a reply to message #518014] |
Wed, 05 May 2010 10:02 |
Nicola Messages: 184 Registered: July 2009 |
is there a way to drop the source before doing any query?
I have my datasource defined in a library.
I named it and try the code you suggested, but with no results.
Am I wrong or there's a problem with dropping a datasource defined in a
library?
Thank you,
Nicola
> Nicola,
> Jason
> nicola wrote:
>> Hi,
>> Regards,
>> Nicola
>>> Nicola,
>>> Jason
>>> nicola wrote:
>>>> Hi,
>>>> method?
>>>> @Override
>>>> // show report
>>>> } else {
>>>> thank you
>>>> Nicola
Re: Java and beforeOpen: stop birt execution [message #531691 is a reply to message #531518] |
Wed, 05 May 2010 19:07 |
I assume you named it in the library. If your script is in the report
it does not have access to the name. So do something like:
//Get the first datasource and drop it
reportContext.getDesignHandle().getDataSources().get(0).drop ();
Jason
On 5/5/2010 6:02 AM, nicola wrote:
> library?
> Thank you,
> Nicola
>> Nicola,
>> Jason
>> nicola wrote:
>>> Hi,
>>> Regards,
>>> Nicola
>>>> Nicola,
>>>> Jason
>>>> nicola wrote:
>>>>> Hi,
>>>>> method?
>>>>> @Override
>>>>> // show report
>>>>> } else {
>>>>> thank you
>>>>> Nicola
Re: Java and beforeOpen: stop birt execution [message #538265 is a reply to message #531691] |
Mon, 07 June 2010 07:20 |
Hi Jason,
this solution does not work.
Nothing happens and the report is shown.
Nicola
> Jason
>> Hi,
>> library?
>> Thank you,
>> Nicola
>>> Nicola,
>>> report".
>>> Jason
>>> nicola wrote:
>>>> Hi,
>>>> Regards,
>>>> Nicola
>>>>> Nicola,
>>>>> drop
>>>>> Jason
>>>>> nicola wrote:
>>>>>> Hi,
>>>>>> method?
>>>>>> @Override
>>>>>> // show report
>>>>>> } else {
>>>>>> thank you
>>>>>> Nicola
Re: Java and beforeOpen: stop birt execution [message #538399 is a reply to message #538265] |
Mon, 07 June 2010 14:47 |
You may need to change the index number (ie get(0) to get(1)) depending
on what datasource it is. You also may need to drop the dataset.
Jason
On 6/7/2010 3:20 AM, nicola wrote:
> Hi Jason,
> Regards,
> Nicola
>> Jason
>>> Hi,
>>> library?
>>> Thank you,
>>> Nicola
>>>> Nicola,
>>>> report".
>>>> Jason
>>>> nicola wrote:
>>>>> Hi,
>>>>> Regards,
>>>>> Nicola
>>>>>> Nicola,
>>>>>> drop
>>>>>> Jason
>>>>>> nicola wrote:
>>>>>>> Hi,
>>>>>>> method?
>>>>>>> @Override
>>>>>>> // show report
>>>>>>> } else {
>>>>>>> thank you
>>>>>>> Nicola
Re: Java and beforeOpen: stop birt execution [message #696559 is a reply to message #538399] |
Thu, 14 July 2011 09:49 |
arlene86 Messages: 6 Registered: July 2011 |
Hi...
I need some help here...
i put below codes to my beforeFactory event :
if (params["name"].value == null) {
javax.swing.JOptionPane.showMessageDialog(null,"ALERT", "ALERT",
javax.swing.JOptionPane.ERROR_MESSAGE);
The message appear when i put null for my parameter input. But, i want report stop from continue running after i click "OK" button on my message dialog.Can anyone help me...
thanks,
Arlene
[Updated on: Thu, 14 July 2011 09:52] Report message to a moderator
Current Time: Sat Apr 20 03:38:02 GMT 2024
Powered by FUDForum. Page generated in 0.03819 seconds
