Shift-tab does not work in compare [message #517861] |
Tue, 02 March 2010 11:26 |
David Balažic Messages: 130 Registered: July 2009 |
If I show the history of a file (.classpath or some java source file) and then right click a revision and select "Compare with Previous State", then in the compare editor, shift-tab does not work:
when the compare appears, the cursor is in the left pane. If I press TAB, the cursor goes to right pane. If I press TAB again, the focus goes to the toolbar.
Then If I press SHIFT-TAB, the cursor goes back to the right pane, but pressing SHIFT-TAB again makes no action. I should return to the left pane, I expect.
So: TAB in compare works, SHIFT-TAB does not work (not in either pane).
-- Configuration Details --
Product: Eclipse 1.2.2.20100122-1337 (org.eclipse.epp.package.jee.product)
Installed Features:
org.eclipse.platform 3.5.2.R35x_v20100210-0800-9hEiFzmFst-TiEn9hNYgDWg1XN8ulH_JvC NGB
Subversive SVN Connectors 2.2.1.I20091215-1700 org.polarion.eclipse.team.svn.connector.feature.group
Subversive SVN Team Provider (Incubation) 0.7.8.I20100222-1600 org.eclipse.team.svn.feature.group
SVNKit 1.3.2 Implementation (Optional) 2.2.1.I20091215-1700 org.polarion.eclipse.team.svn.connector.svnkit16.feature.gro up
Re: Shift-tab does not work in compare [message #518474 is a reply to message #517861] |
Thu, 04 March 2010 09:05 |
Igor Burilo Messages: 435 Registered: July 2009 |
Hello David,
In order to show Compare editor, we use Compare framework. I checked and got
the same behaviour as you described. Please, target this question to Eclipse
compare framework.
> toolbar.
> pane, I expect.
> Installed Features:
FUDForum. Page generated in 0.03738 seconds
