Home » Archived » BIRT » PDF and barcode generation through iText(PDF, barcode, iText)
Re: PDF and barcode generation through iText [message #517985 is a reply to message #517780] |
Tue, 02 March 2010 16:25 |
Do the byte[] only come back as a pdf? Can it be retrieved as an image?
Jason
Ivan Hoe wrote:
> I'm new on the BIRT designing world.
> I'm using BIRT 2.5.1 and comes with iText 1.54 and I'd like to use iText
> barcode generation capabilities in my web app.
> I can obtain a PDF "subreport" or piece if you want to call it something
> but I'm unable to display it on my report design. It displays once
> deployed ""Current report item is not supported in this report format"...
> This is what I have in my servlet:
> SubReport folio = new SubReport();
> ByteArrayOutputStream baos = folio.getFolioBC("123456");
> byte[] bytes = baos.toByteArray();
> task.getAppContext().put("imageBarcode", bytes);
> That code gets a ByteArray that starts with %PDF... and so on, so I
> assume it is a whole PDF with the barcode I need.
> The SubReport class that outputs the ByteArrays is as follows:
> public ByteArrayOutputStream getFolioBC (String folio) throws
> IOException, DocumentException {
> ByteArrayOutputStream baos = new ByteArrayOutputStream();
> Document document = new Document();
> PdfWriter writer = PdfWriter.getInstance(document, baos);
> document.open();
> PdfContentByte cb = writer.getDirectContent();
> //Barcode 3 of 9 extended
> Barcode39 code39ext = new Barcode39();
> code39ext.setCode(folio);
> code39ext.setStartStopText(false);
> code39ext.setExtended(true);
> document.add(code39ext.createImageWithBarcode(cb, null, null));
> document.close();
> return baos;
> Can you suggest me a way in with I don't have to depend on barcode fonts?
> Hope to hear from you.
Re: PDF and barcode generation through iText [message #518015 is a reply to message #517994] |
Tue, 02 March 2010 18:10 |
Ivan,
We have a lot of developers on BIRT. I am just one of the team members.
Using iText you can combine the pdf generated from BIRT with the PDF you
generated. I will post the code at the end of this post. I would like
to play with the image a bit. If you could post your code that would be
great.
Jason
//This is just a sample. Do not start and stop the report engine more
//than once in your app as it is very expensive.
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import java.io.FileNotFoundException;
import java.io.FileOutputStream;
import java.io.ByteArrayOutputStream;
import java.io.IOException;
import java.io.OutputStream;
import com.lowagie.text.pdf.PdfReader;
import com.lowagie.text.pdf.PdfWriter;
import com.lowagie.text.pdf.PdfCopyFields;
import com.lowagie.text.Document;
import com.lowagie.text.Paragraph;
public class CombineReportsPDF {
public void concat(byte[] ba1, byte[] ba2, String outpath){
try{
document.open();
writer.addJavaScript("this.print(true);", true);
document.add(new Paragraph("This is Test silent print feature"));
document.close();
writer.close();
PdfReader js1 = new PdfReader(baos.toByteArray());
PdfReader rd1 = new PdfReader( ba1 );
PdfReader rd2 = new PdfReader( ba2 );
PdfCopyFields cpy = new PdfCopyFields( new FileOutputStream( outpath ));
cpy.addDocument(js1);
cpy.addDocument(rd1);
cpy.addDocument(rd2);
cpy.close();
}catch(Exception e){
e.printStackTrace();
public void runReport() throws EngineException
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
config.setBIRTHome(" C:\\birt\\birt-runtime-2_2_1\\birt-runtime-2_2_1\\ReportEngi ne ");
config.setLogConfig(null, Level.OFF);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
}catch( Exception ex){
ex.printStackTrace();
IReportRunnable design, design2 = null;
//Open the report design
design = engine.openReportDesign("Reports/TopNPercent.rptdesign");
design2 =
engine.openReportDesign("Reports/TopSellingProducts.rptdesign ");
//Create task to run and render the report,
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
task.setParameterValue("Top Percentage", (new Integer(3)));
task.setParameterValue("Top Count", (new Integer(5)));
task.validateParameters();
PDFRenderOption options = new PDFRenderOption();
ByteArrayOutputStream fso= new ByteArrayOutputStream();
byte[] rbytes = fso.toByteArray();
FileOutputStream fsof;
try {
fsof = new FileOutputStream("c:/test/mydata.txt");
fsof.write(rbytes);
fsof.close();
} catch (FileNotFoundException e) {
// TODO Auto-generated catch block
} catch (IOException e) {
ByteArrayOutputStream fso2= new ByteArrayOutputStream();
options.setOutputStream(fso);
options.setOutputFormat("pdf");
task.setRenderOption(options);
task.run();
task.close();
task = engine.createRunAndRenderTask(design2);
options.setOutputStream(fso2);
task.run();
task.close();
concat( fso.toByteArray(), fso2.toByteArray(),
"output/resample/Combined.pdf");
engine.destroy();
Platform.shutdown();
System.out.println("Finished");
* @param args
try
CombineReportsPDF ex = new CombineReportsPDF( );
ex.runReport();
catch ( Exception e )
Ivan Hoe wrote:
> Hey Jason, so you are the Man behind BIRT as I see. Thanks for your help
> but I tried with a com.lowagie.text.Image instead of a
> com.lowagie.text.pdf.PdfWriter to get an image raw but BIRT tells me it
> doesn't know the image format...
> Since I already have a piece of a pdf with the barcode (as fas as I
> know) is there a way to insert it with some sort of obscure api method?
> If you have any other approach I can use, that would be great.
> Thanks man.
Re: PDF and barcode generation through iText [message #518381 is a reply to message #518015] |
Wed, 03 March 2010 22:54 |
Ivan Hoe Messages: 12 Registered: March 2010 |
Junior Member |
Hey Jason. Still playing with your code.
This is my original code:
The Servlet WebReport.java
import java.io.PrintWriter;
import java.util.logging.Logger;
import javax.servlet.ServletConfig;
import javax.servlet.ServletContext;
import javax.servlet.ServletException;
import javax.servlet.http.HttpServlet;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
public class WebReport extends HttpServlet {
private static final long serialVersionUID = 1L;
private IReportEngine birtReportEngine = null;
protected static Logger logger = Logger.getLogger( "org.eclipse.birt" );
public WebReport() {
super();
public void init(ServletConfig sc) throws ServletException {
BirtEngine.initBirtConfig();
this.birtReportEngine = BirtEngine.getBirtEngine(sc.getServletContext());
public void destroy() {
super.destroy();
BirtEngine.destroyBirtEngine();
public void doGet(HttpServletRequest req, HttpServletResponse resp) throws ServletException, IOException {
resp.setContentType("text/html");
String reportName = req.getParameter("ReportName");
ServletContext sc = req.getSession().getServletContext();
this.birtReportEngine = BirtEngine.getBirtEngine(sc);
IReportRunnable design;
try {
design = birtReportEngine.openReportDesign( sc.getResource("/Reports/"+reportName+".rptdesign").toString().substring(6) );
IRunAndRenderTask task = birtReportEngine.createRunAndRenderTask( design );
task.getAppContext().put("BIRT_VIEWER_HTTPSERVLET_REQUEST", req);
// For barcode insertion
options.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_PDF);
resp.setHeader( "Content-Disposition", "inline; filename=\""+reportName+".pdf\"" );
options.setOutputStream(resp.getOutputStream());
options.setSupportedImageFormats("JPG;BMP");
task.run();
task.close();
} catch (Exception e) {
throw new ServletException( e );
public void doPost(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
response.setContentType("text/html");
PrintWriter out = response.getWriter();
out.println("<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01 Transitional//EN\">");
out.println("<HTML>");
out.println(" <HEAD><TITLE>A Servlet</TITLE></HEAD>");
out.println(" <BODY>");
out.println(" Post Not Supported");
out.println(" </BODY>");
out.println("</HTML>");
out.flush();
out.close();
This one is the Engine class BirtEngine.java
import java.io.InputStream;
import java.util.Properties;
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.core.framework.IPlatformContext;
import org.eclipse.birt.core.framework.PlatformServletContext;
import org.eclipse.birt.report.engine.api.EngineConstants;
public class BirtEngine {
private static IReportEngine birtEngine = null;
private static Properties configProps = new Properties();
private final static String configFile = "BirtConfig.properties";
public static synchronized void initBirtConfig() {
loadEngineProps();
@SuppressWarnings("unchecked")
public static synchronized IReportEngine getBirtEngine(ServletContext sc) {
if (birtEngine == null) {
EngineConfig config = new EngineConfig();
if( configProps != null){
String logLevel = configProps.getProperty("logLevel");
Level level = Level.OFF;
if ("SEVERE".equalsIgnoreCase(logLevel)) {
level = Level.SEVERE;
} else if ("WARNING".equalsIgnoreCase(logLevel)) {
level = Level.WARNING;
} else if ("INFO".equalsIgnoreCase(logLevel)) {
level = Level.INFO;
} else if ("CONFIG".equalsIgnoreCase(logLevel)) {
level = Level.CONFIG;
} else if ("FINE".equalsIgnoreCase(logLevel)) {
level = Level.FINE;
} else if ("FINER".equalsIgnoreCase(logLevel)) {
level = Level.FINER;
} else if ("FINEST".equalsIgnoreCase(logLevel)) {
level = Level.FINEST;
} else if ("OFF".equalsIgnoreCase(logLevel)) {
level = Level.OFF;
config.setLogConfig(configProps.getProperty("logDirectory"), level);
config.setEngineHome("");
config.getAppContext().put(EngineConstants.APPCONTEXT_CLASSLOADER_KEY, BirtEngine.class.getClassLoader());
IPlatformContext context = new PlatformServletContext( sc );
config.setPlatformContext( context );
try {
} catch ( BirtException e ) {
e.printStackTrace( );
IReportEngineFactory factory = (IReportEngineFactory) Platform.createFactoryObject( IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
birtEngine = factory.createReportEngine( config );
return birtEngine;
public static synchronized void destroyBirtEngine() {
return;
birtEngine.destroy();
birtEngine = null;
public Object clone() throws CloneNotSupportedException {
throw new CloneNotSupportedException();
private static void loadEngineProps() {
try {
ClassLoader cl = Thread.currentThread().getContextClassLoader();
InputStream in = null;
in = cl.getResourceAsStream(configFile);
configProps.load(in);
in.close();
And finally the class that constructs the barcode SubReport.java
package org.data.report.pdf;
import com.lowagie.text.DocumentException;
import com.lowagie.text.pdf.Barcode39;
import com.lowagie.text.pdf.PdfContentByte;
public class SubReport {
public SubReport() {
public ByteArrayOutputStream getFolioBC (String folio) throws IOException, DocumentException {
document.open();
document.close();
return baos;
I'm tweaking it to adapt your example code to test it.
I'll tell you my results.
Re: PDF and barcode generation through iText [message #518411 is a reply to message #518015] |
Thu, 04 March 2010 01:51 |
Junior Member |
Hi Jason,
I tweaked a bit your code to produce the results I wanted... Sort of.
This class:
import com.lowagie.text.pdf.PdfStamper;
public class InsertPDF {
public void insert(byte[] ba1, byte[] ba2, String outpath) {
try {
PdfReader reader = new PdfReader(ba1);
PdfReader reader2 = new PdfReader(ba2);
PdfStamper stamp = new PdfStamper(reader2, new FileOutputStream(outpath));
PdfContentByte under = stamp.getOverContent(1);
under.addTemplate(stamp.getImportedPage(reader, 1), 420, -30);
stamp.close();
} catch (DocumentException e) {
public void runReport() throws EngineException {
IReportEngine engine = null;
try{
config.setBIRTHome("C:\\birt-runtime-2_5_2\\ReportEngine");
//IReportRunnable design, design2 = null;
IReportRunnable design2 = null;
design2 = engine.openReportDesign("Reports/TopSellingProducts.rptdesign");
IRunAndRenderTask task = null;
ByteArrayOutputStream fso = null;
try {
fso = getFolioBC("1234567890");
ByteArrayOutputStream fso2 = new ByteArrayOutputStream();
task.run();
task.close();
insert( fso.toByteArray(), fso2.toByteArray(), "c:/temp/Watermarked.pdf");
engine.destroy();
document.open();
document.close();
return baos;
* @param args
try {
InsertPDF ex = new InsertPDF( );
ex.runReport();
catch ( Exception e ) {
But since I need many different report designs, the barcode section varies its position...
Isn't there a way to place it in a container inside the report.rptdesign file like a dynamic image (my first approach)?
Thanks for your support man.
Ivan
Re: PDF and barcode generation through iText [message #518637 is a reply to message #518397] |
Thu, 04 March 2010 11:50 |
Ivan,
If you can get the image bytes you could use something similar to the
following image oncreate script:
importPackage(Packages.java.io);
importPackage(Packages.java.lang);
var file = new File("c:/temp/test.png");
var ist = new FileInputStream(file);
var lengthi = file.length();
bytesa = new ByteArrayOutputStream( lengthi);
var c;
while((c=ist.read()) != -1){
bytesa.write(c);
ist.close();
this.data = bytesa.toByteArray();
Jason
Ivan Hoe wrote:
> Jason,
> Your example is great and I can definitely make use of it but the thing
> is that the part where the magic happends:
> cpy.close();
> What it does is append the documents to create a PDF. The thing is that
> I need to have a barcode on every page of the report.
> The approach I had was to insert a dynamic image to my report.rptdesign
> where I intended to create the barcode using the iText that BIRT already
> includes. While your approach might enlight me in this quest (That is
> excellent to output a dozen reports in a single file 8) ) The fact to
> include a barcode in a report is still missing.
> I know tons of developers here will thank you and like it if we can
> solve this issue.
Re: PDF and barcode generation through iText [message #519487 is a reply to message #518637] |
Tue, 09 March 2010 00:57 |
Junior Member |
Jason,
Sorry for this late reply.
I found a library to create Barcodes (BarCode4J) that return them as Images (and ByteArrays for the purpose here). I want to take your approach but I don't know how to get the ByteArrayOutputStream from the image I'm trying to create and put it instead of your File.
In this code of yours:
var c;
bytesa.write(c);
ist.close();
I want to replace the line:
With the ByteArraysOutputStream I already get from the Servlet while constructing the image with the barcode...
This is how I construct the image:
1. In the Report Servlet:
ByteArrayOutputStream baos = folio.getFolioImage("123456");
2. The image creation:
public ByteArrayOutputStream getFolioImage (String folio) throws IOException, DocumentException {
ByteArrayOutputStream baos = null;
try {
//Create the barcode bean
Code39Bean bean = new Code39Bean();
final int dpi = 150;
//Configure the barcode generator
bean.setModuleWidth(UnitConv.in2mm(1.0f / dpi)); //makes the narrow bar
//width exactly one pixel
bean.setWideFactor(3);
bean.doQuietZone(false);
//Open output file
try {
//Set up the canvas provider for monochrome JPEG output
BitmapCanvasProvider canvas = new BitmapCanvasProvider(
baos, "image/jpeg", dpi, BufferedImage.TYPE_BYTE_BINARY, false, 0);
//Generate the barcode
bean.generateBarcode(canvas, folio);
//Signal end of generation
canvas.finish();
} finally {
baos.close();
return baos;
I use a Dynamic Image as the container of these bytes as follows:
# Define "Dynamic Image" as Type
# In the DataBinding Dialog click the "Add..." Button
# Define "folio" as "Column Binding Name"
# Define "String" as "Data Type"
# Use the expression "reportContext.getAppContext().get("imageBarcode");"
# Check the checkbox in front of the "folio" entry in dialog
I'm getting a "The resource of this report item is not reachable." message instead of the actual barcode. I configure the output image to be a "image/jpeg" as you can see on my code.
Any suggestion?
Ivan
[Updated on: Tue, 09 March 2010 00:58] Report message to a moderator
Re: PDF and barcode generation through iText [message #519495 is a reply to message #517780] |
Tue, 09 March 2010 02:37 |
Junior Member |
Also, I obtain the same bytes bit by bit using the following code using iText to convert to image the resulting barcode:
Image image = code39ext.createAwtImage(Color.black, Color.white);
BufferedImage bffImg = new BufferedImage(image.getWidth(null),image.getHeight(null),
BufferedImage.TYPE_3BYTE_BGR);
Graphics offg = bffImg.createGraphics();
offg.drawImage(image, 0, 0, null);
ImageIO.write(bffImg, "jpeg", baos);
return baos;
So I guess there's no need to use external jars since BIRT provides pretty much everything...
Ivan
Re: PDF and barcode generation through iText [message #519629 is a reply to message #519487] |
Tue, 09 March 2010 09:34 |
Ivan,
Can you set the image type to a dynamic image(important) an put in an
oncreate script like:
this.data = reportContext.getAppContext().get("imageBarcode");
BTW there may be an issue with the byte[] not storing properly in the
appcontext. If the above does not work try:
change
to
> task.getAppContext().put("imageBarcode", baos);
and the above script to
var ba = reportContext.getAppContext().get("imageBarcode");
this.data = ba.toByteArray();
Jason
Ivan Hoe wrote:
> Jason,
> I found a library to create Barcodes (http://barcode4j.sourceforge.net/)
> var c;
> bytesa.write(c);
> ist.close();
> try {
> narrow bar
> //Open output file
> try {
> canvas.finish();
> } finally {
> baos.close();
> return baos;
> I use a Dynamic Image as the container of this bytes as follows:
> Any suggestion?
> Ivan
Re: PDF and barcode generation through iText [message #519769 is a reply to message #519721] |
Tue, 09 March 2010 16:34 |
Ivan,
Select the image and then hit the script tab. This will not work on any
of the report level events, it needs to be the image.
Jason
Ivan Hoe wrote:
> Hi Jason.
> I'm trying just that with no luck.
> I can't find the onCreate section of the report, so I'm using the
> Initialize to place the script:
> But nothing changes.
> Do I need to change anything on expression on the DataBinding dialog?
> (reportContext.getAppContext().get("imageBarcode"); )
> Ivan
Re: PDF and barcode generation through iText [message #519811 is a reply to message #519782] |
Tue, 09 March 2010 22:24 |
Ivan,
It would be great if you could post an example of this in the Birt
Exchange devshare.
Glad all is well.
Jason
Ivan Hoe wrote:
> Jason!!!! My man the first approach from your last code suggestions
> works alright!!!
> Using the bytes[] array and nothing more than plain old iText.
> Damn what a pain but thanks a lot!!!
> Ivan, pleased and happy 8)
Re: PDF and barcode generation through iText [message #664848 is a reply to message #664800] |
Tue, 12 April 2011 09:23 |
Adam,
Have you also put this write-up on Birt-exchange.org as a dev share item?
It would be good if you could.
Jason
On 4/12/2011 2:39 AM, Adam Barlow wrote:
> I have applied the BIRT Barcode Plugin to generate barcodes in BIRT
> reports.You can try BIRT Barcode
> Pluginhttp://www.onbarcode.com/products/birt_barcode/.It's easy to
> integrate.You can follow the 6 steps BIRT Barcode Generation
> Guidehttp://www.onbarcode.com/tutorial/java-barcode-eclipse- birt.html:
> 1.Download BIRT Barcode free Trial Version
> 2.Copy com.onbarcode.barcode.birt_2.2.1.jar to your Eclipse plugins
> directory ""\eclipse\plugins\""
> 3.Create a new BIRT report, and open ""Palette"", you can find a report
> item named ""Barcode"".
> 4.Drag and drop the ""Barcode"" report item to your report
> 5.It's done. You have added a barcode to your BIRT report successfully.
> 6.View more details about how to set BIRT barcode properties using BIRT
> Barcode
> Hope it's helpful for you.
Re: PDF and barcode generation through iText [message #969536 is a reply to message #941653] |
Sat, 03 November 2012 09:55 |
Muzammil A A Messages: 3 Registered: October 2012 |
Junior Member |
My code is
public static ByteArrayOutputStream getFolioBC (String key) throws IOException, DocumentException
Barcode128 code128 = new Barcode128 ();
code128.setCode(key);
code128.setAltText(key);
code128.setCodeType(Barcode.CODE128);
java.awt.Image image = code128.createAwtImage(Color.black, Color.white);
return baos;
I will get ByteArrayOutputstream and put that in appcontext
and in the onCreate script of the image I will put this code
But I am getting only the barcode not the text below it
Current Time: Wed Apr 24 15:30:31 GMT 2024
Powered by FUDForum. Page generated in 0.05828 seconds
