Home » Language IDEs » Objectteams » Feedback on examples
Feedback on examples [message #517126] |
Fri, 26 February 2010 11:04  |
Aaron Digulla Messages: 258 Registered: July 2009 Location: Switzerland |
I've quickly browsed the examples. Here are my notes:
Stopwatch:
Why do I have to declare the imported methods abstract? Or rather: Why do I have to declare them twice? Why isn't it enough to simply say "start -> start;"?
If this is just an example and not really necessary, then please omit one of them, so we can see with how little code we can get away.
Observer:
"observers.removeAll(observers);" ... WTF? What's wrong with "observers.clear();"? I guess that this is because clear won't trigger the observers but from the code, this looks extremely inefficient.
In the code for "changeOpMany()", you call "deactivate()" but that method isn't defined anywhere.
Also, this code isn't exception safe: If an exception is thrown in "base.changeOpMany();", then the subject is dead. Therefore, a closure would be much better at this place.
Another optimization: in practice, changeOp should emit the old and the new value (and do nothing is they are equal or compareTo() returns 0). Can OT handle this? If so, by all means, show us. The current example is nice for a textbook but pretty useless in the real world.
Re: Feedback on examples [message #517176 is a reply to message #517126] |
Fri, 26 February 2010 14:01  |
Stephan Herrmann Messages: 1845 Registered: July 2009 |
Hi Aaron,
Aaron Digulla wrote on Fri, 26 February 2010 06:04 | I've quickly browsed the examples. Here are my notes:
Stopwatch:
I've added a paragraph titled "Alternatives". Please check whether it answers your question.
Observer:
Fixed (With True Failthfullness).
This is a good observation. OTOH, there's probably more to say about
exception safety than easily fits into this example. Yet I don't see how
a closure would change anything.
I could enclose the base call in try finally, but that would distract
from the core behaviour shown here. Interestingly, for the inverse,
i.e., temporarily activating a team, the within() { } block takes care of
exceptions, just as you request. Unfortunately, it cannot be used for
deactivation.
That would require some knowledge about which data is being observed,
i.e., which field of the subject. Of course a callin method may do s.t. like
callin void changeOp() {
Object old = getObservedValue();
base.changeOp();
if (!old.equals(getObservedValue()))
for (Observer observer : observers)
observer.update(this);
This would make the pattern slightly less re-usable because now we need to
provide bindings for getObservedValue(), which may not always be feasible.
Also, using type Object for the value may not be optimal. What about primitive
data, e.g.? (not to mention the missing null checks in the above fragment).
Have you seen the specific solution in ObservingClose (the guard predicate)?
So, please consider it as a textbook example
Those are the best for presenting the distilled concepts.
The ObserverPattern explicitly states: "Note, that a well designed program in
Object Teams will usually not require an explicit Observer infrastructure."
So all this is for illustration only.
The real production code you may browse in our SVN, but that's nothing to
be shown in a Wiki for first contact with the language.
Also the other examples (FlightBonus and OrderSystem) are a bit more
complete applications. (While they're not yet documented in the wiki, they're
easily accessible within the tool: New > Example > Object Teams > ...).
Thanks for your feedback,
Stephan
Current Time: Thu May 26 01:28:04 GMT 2022
Powered by FUDForum. Page generated in 0.01665 seconds
