Home » Archived » Test and Performance Tools Platform (TPTP) » PrivilegedActionException when using TPTP(PrivilegedActionException when using TPTP)
PrivilegedActionException when using TPTP [message #517075] Fri, 26 February 2010 05:24 Go to next message
Keith H is currently offline Keith HFriend
I'm using TPTP 4.6.1 with Galileo, running Tomcat 6 inside of Eclipse, and I'm getting a PrivilegedActionException in my code when monitoring with TPTP. The exception happens when I try to do dozer mapping, which attempts to use reflection. I don't have security enabled on the server properties page. The exception only occurs when monitoring is on. If I pause monitoring, it works fine.
[Updated on: Fri, 26 February 2010 17:17]
Report message to a moderator
Re: PrivilegedActionException when using TPTP [message #517659 is a reply to message #517075] Mon, 01 March 2010 15:53 Go to previous message
Eugene Chan is currently offline Eugene ChanFriend
Hi Keith,
Could you try configure the profiling filter such that the involvled class
and pacakges is filter out and see if you continue the profile without
having the error?
Eugene
"Keith H" <khamburg@gmail.com> wrote in message
news:hm7lu7$ej9$1@build.eclipse.org...
Previous Topic:DatapoolSuggestedType with "valueOjbectExtension" and "valueObjectValidatorExtension&
Next Topic:Object Allocation analysis on JVM 1.5
Current Time: Thu Sep 19 08:26:09 GMT 2019
Powered by FUDForum. Page generated in 0.02094 seconds
